    MMM-Navigate, Navigation inside MagicMirror with Rotary Encoder
    45 Posts 6 Posters 22.9k Views 5 Watching
      AxLed Module Developer
      @Eisblume
      Did you use the right Pin (either in config or on the pi) for the ‘press’ signal of the rotary encoder?
      Is the module MMM-Remote-Control installed and working?
      AxLED
      • E Offline
        Eisblume
        yes Pin 19, like you suggested. Everything else works fine, only the press action doesn’t work.
        MMM-Remote-Control is installed.
        I ordered a new Rotary Encoder, maybe this one I use has a defect .
        Eisblume
          @Eisblume
          You can also try to put clockwise or counterclockwise signal on pin 19 for testing, so cw or ccw should send the press command. So you can make sure if press switch of your rotary encoder is bad.
          AxLED
          • E Offline
            Eisblume
            Thx for support !!
            I will try and report !!
            • E Offline
              Eisblume
              @AxLED
              I bought some new Rotary Encoders and with each one i had the same result. No press result will send, when i press the button :-( !
              But when i put cw or cww on pin 19, the press signal will send when i turn cw or cww.
              I tried other Pins for the press Signal, but it also doesn´t work.
              I am confused…! Any ideas what i can try to solve my Problem?
              Greets
              Eisblume
                @Eisblume
                So the pin is correct. Some ideas.
                Press contains two operations, pressing and release. Did you try press and release in different speeds?
                How long are your cables between rotary and pi? Could also be a debouncing problem. Which pi are you using? (I tested the module on pi 1 and pi 3).
                AxLED
                • E Offline
                  Eisblume
                  @AxLed
                  I use a Raspberry Pi 3 b+. The F2F cables between the rotary and the pi are 20cm long.
                  I tried different speeds for pressing and releasing.
                  When i debug the code, no action arrives when i press the button.
                  Is it possible that there are problem with other modules I use ??
                  Eisblume
                    @Eisblume
                    Conflicts with other modules are possible, but i dont think so, because press on cw/ccw works. You can try to change debounce time in node helper (i think, i am not sure about as i am on the road right now). I will check for the final line in node helper and let you know if i am in front of my computer.
                    AxLED
                      @Eisblume
                      I found the line in node_helper.js, its line 35
                      const C = new Gpio(self.config.GPIOPins[2], 'in', 'both',{debounceTimeout : 20 }); //BCM Pin 19
                      Here you can try to increase/reduce the debounceTimeout between 10 and 50 (in steps of 10) and see if there is a difference for your “pressed” problem.
                      AxLED
                      • E Offline
                        Eisblume
                        @AxLed
                        I tried every very with different press speed. It doesn’t work. No press Signal will be sent :-(
                        I don´t understand why cw and cww works fine, but not the press - Button?
                        Edit:
                        I test the Rotary with this: https://github.com/martinohanlon/KY040
                        Here the press button works fine.
                        pi@raspberrypi:~/EncoderTest/KY040/examples $ python python3.py
                        turned - 0
                        turned - 0
                        turned - 1
                        turned - 1
                        button pressed
                        button pressed
                        button pressed
                        button pressed
                        button pressed
                        button pressed
                        • 2 / 5
