    MMM-Navigate, Navigation inside MagicMirror with Rotary Encoder
    45 Posts 6 Posters 24.3k Views 5 Watching
      AxLed Module Developer
      @Eisblume
      You need two things:
      • first: a modules which is able to stream 100Sec Tagesschau, i made a fork see MMM-Podcast2
      • second: the right config (i posting only the relevant part)
      			module: 'MMM-Podcast2',
      				omxargs: ' --win 0,0,1920,1080  -o both '
      			module: "MMM-Navigate",
      			header: "Navigation",
      					Alias: [
      						'Tagesschau 100 Sekunden',
      						'Herunterfahren'
      					Action: [
      						{notification:'BUTTON_PRESSED',payload:''},
      						{notification: "REMOTE_ACTION", payload: {action: "SHUTDOWN"}}
      					GPIOPins: [26,20,19]//rotary cw, rotary ccw, rotary press (BCM Numbering)
      AxLED
      • E Offline
        Eisblume @AxLed
        @AxLed said in MMM-Navigate, Navigation inside MagicMirror with Rotary Encoder:
        {notification:‘BUTTON_PRESSED’,payload:‘’},
        Thanks. Works perfect !!!
        • K Offline
          keineAhnung123
          Hello @AxLed ,
          Two things:
          First
          I have the same issue like @Eisblume :
          The click doesnt work.
          When i then start a sample code to test the rotary encoder (from like here), the click works in the sample code.
          If i start the Magic Mirror after that again, then the click works there too.
          Maybe there is a missing initialization of the rotary encoder in your code?
          Second
          Is there a possibility to get more config possibilities?
          Like starting the module hidden or shortening the time of the hiding process?
          Thanks in advance :)
            @keineAhnung123,
            to your first issue:
            • is only click not working or is rotation also not working?
              Because rotation and click (Button press) uses the same library (onOff).
            • on which pin is click connected, as the pi GPIO Pins have different features?
            • what versions you are using (pi, OS, MM-Version)?
            To your second issue.
            • MMM-Navigate uses the MM notification system, so you can do almost everything you want. What are you trying to to, maybe i can give you a sample for your config.js
            • for shortening time of hidding see MM Docs -> search for hide, there is a parameter for speed.
            Regards
            AxLED
            • K Offline
              keineAhnung123
              Hello @AxLed , thanks for your reply
              first
              • rotation works fine but the button press does not
              • i use your standard configuration so it seems to be BCM 19
              • PI 3 B+, stretch, MM 2.14.0
              I tried MMM-Buttons too. Same problem there. I first have to run a sample script with python and after that the button works in MM too. It uses the onoff library too.
              I found a strange behaviour:
              I start MM -> button click doesnt work
              I start python test script and after that MM -> button click works
              When i restart the Raspberry PI and start MM (without the python test script) -> button click works
              When i shutdown the Raspberry PI and cut off the connection to an electricity source and restart the PI after that -> button click doesnt work
              Thats strange isnt it?
              second
              I changed the hiding time from 10000 to 2000 cause i prefer a shorter time.
              Is there a way to start the module hidden?
              I tried following:
                  // Define start sequence.
                  start: function() {
                      Log.info("Starting module: " + this.name);
                      this.sendConfig();//pass config to node_helper.js
                      this.hide();
              and this
                  //Helper, to use module without Rotary Encoder and without GPIO Pins, like developing in Pixel VM
                  notificationReceived: function(notification, payload) {
                      if(notification === "CW" || notification === "CCW" || notification === "PRESSED"){
                          this.naviaction({inputtype: ""+ notification +""});
                      if(notification === "SHELLCOMMAND"){
                           this.sendSocketNotification(notification, payload);
                      if(notification === "MODULE_DOM_CREATED"){
                           this.hide();
              but both didnt take effect :(
              third
              I found an reproducable error:
              When i start MM and first rotate counterclockwise there is an error in the MM console:
              [09.01.2021 09:11.07.337] [LOG]   MMM-Navigate, listen on GPIO PINs (BCM): 26,20,19
              [09.01.2021 09:11.18.306] [ERROR] Whoops! There was an uncaught exception...
              [09.01.2021 09:11.18.321] [ERROR] ReferenceError: lastdir is not defined
                  at tick (/home/pi/MagicMirror/modules/MMM-Navigate/node_helper.js:92:39)
                  at /home/pi/MagicMirror/modules/MMM-Navigate/node_helper.js:66:4
                  at /home/pi/MagicMirror/modules/MMM-Navigate/node_modules/onoff/onoff.js:135:9
                  at Array.forEach (<anonymous>)
                  at pollerEventHandler (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/onoff/onoff.js:134:32)
              It doesnt effect the functionality but just wanted to mention it… ;)
                @keineAhnung123,
                thanks for feedback.
                first:
                Idea A:
                • maybe the pin 19 is the problem, because it is not only a GPIO pin rather it has SPI features. Can you change to BCM16 (and change it in config.js as well) and try it?
                Idea B:
                • Do you use capacitors for debouncing? If not, you can change debouncing value of following line: https://github.com/Ax-LED/MMM-Navigate/blob/master/node_helper.js#L37
                second:
                • Which module should start hidden? MMM-Navigate?
                third:
                I tried to reproduce on my pi 3 and get no error, so i checked the code.
                You can add following line as new line 19 in node_helper.js
                var lastdir = '';
                AxLED
                • K Offline
                  keineAhnung123
                  @AxLed
                  I will try that later. Thanks
                  And yes, i want to start MMM-Navigate hidden. Is that possible?
                    @keineAhnung123 ,
                    informations to your second issue:
                    Your request is not provided by MMM-Navigate, maybe it is possible with one of the following modules (untested):
                    • MMM-ModuleScheduler
                    • MMM-ModuleToggle
                    AxLED
                    • K Offline
                      keineAhnung123
                      Hello @AxLed
                      first
                      • Idea A: didnt solve the problem. Still no click
                      • Idea B: I tried capacitors and software debouncing. Still no click
                      I will use this python script to get the click working:
                      import RPi.GPIO as GPIO
                      GPIO.setmode(GPIO.BCM)
                      BUTTON_PIN = 16
                      GPIO.setup(BUTTON_PIN, GPIO.IN, pull_up_down = GPIO.PUD_UP)
                      and start it within node_helper.js:
                      var child_process = require('child_process');
                      	// Subclass start method.
                        start: function() {
                      		var self = this;
                      		this.loaded = false;
                      		this.createRoutes();
                      		child_process.execFile('python', ['/home/pi/MagicMirror/modules/MMM-Navigate/ky-040-initialisieren.py']);
                      Now it works.
                      Btw: In intializeRotary-function (node_helper.js) there ist a CLK and DT.read and also a CLK and DT.watch instruction. For the SW there is only a SW.watch but not a read instruction. Is that right? Just wanted to mention. Im not an expert in programming.
                      third
                      Yes, the error is gone :)
                        @keineAhnung123 ,
                        thanks for your patience.
                        to first:
                        it seems to be something with the pullup / pulldown resistors, see also https://github.com/fivdi/onoff#configuring-pullup-and-pulldown-resistors
                        See also the new “gpio” config command (https://www.raspberrypi.org/forums/viewtopic.php?f=117&t=208748)
                        So here is another idea, can you try (based on informations mentione above):
                        • (i suppose your SW pin is 16)
                        • add following line in /boot/config.txt
                          gpio=16=ip,pu
                          Meaning: sets your GPIO 16 as input (ip) and pull up (pu)
                        • if this doesnt work try:
                          gpio=16=ip,pd
                          Meaning: sets your GPIO 16 as input (ip) and pull down (pd)
                        Maybe this way MMM-Navigate works without the python script.
                        To SW.watch you mentioned, this is ok, as i dont need to know the initial state of SW.
                        to third:
                        • i added the line in node_helper.js in the github repo.
                        Regards
                        AxLED
                        • 4 / 5
