    Making changes without stopping MM
    10 Posts 3 Posters 3.7k Views 3 Watching
      jtmoore81
      I"m starting to get things up and running with MM. I do have a question. Is there a way you can develop or make changes to the config file without having to stop the MM, then make the changes, then restart the system?
      Thanks,
      idoodlerI 1 Reply Last reply Reply Quote 0
      • idoodlerI Offline
        idoodler Module Developer @jtmoore81
        @jtmoore81 Not really. Do you use pm2?
          sharmstr Project Sponsor
          If you have a keyboard attached you can Ctrl-R
          • idoodlerI Offline
            idoodler Module Developer @sharmstr
            @sharmstr That’ll only apply the changes to the UI, not to the underlaying node modules.
              jtmoore81 @idoodler
              @idoodler I haven’t installed it on this machine…I guess I should. Thanks.
                Right. The OP specified the config file not modules so I assumed that’s all they wanted.
                • idoodlerI Offline
                  @jtmoore81 Well, this mirror is running pm2 there should be a watcher task running. Try to execute pm2 list to see if your MagicMirror is handled by it.
                  • idoodlerI Offline
                    @sharmstr Yeah, I always prefere to restart the whole MagicMirror using pm2 restart MagicMirror. Also pm2 is watching the config.json file for any changes and will execute the restart the MagicMirror automatically.
                      sharmstr Project Sponsor @idoodler
                      @idoodler Totally agree, but for css and location changes, ctrl r saves a ton of time.
                      idoodlerI 1 Reply Last reply Reply Quote 1
                      • idoodlerI Offline
                        @sharmstr Yep, thats true.
                        • Change *.css or Javascript file => Just reload the Webinterface (ctrl + r)
                        • Change config.json => Reload the Webinterface will do it 90%, else restart MagicMirror
