    MMM-PIR-Sensor tuning
    40 Posts 7 Posters 36.8k Views 6 Watching
    • O Offline
      open_book @jc21
      @jc21 just for closure here I found the issue. After running the python script again I realised that the PIR was always HIGH even with the sensitivty dialled right down.
      So I checked the leads going into the pi and found that, despite checking it many times, I’d mixed up GND and VCC :(
      The lesson for any other idiots out there when testing is, run this Python script and make sure that the PIR stops broadcasting “Motion Detected!” when you cover it with something:
      from gpiozero import MotionSensor
      import os
      pir= MotionSensor(22) //the gpio pin PIR OUT is connected to
      while True:
                     if pir.motion_detected:
                     print (“Motion Detected!”)
      Code from this site
      With some further adjustments for sensitivity it’s now working great!
      sudo insert motivational.quote
        jc21
        Great stuff. People shouldn’t discount a faulty PIR either. The one I had on the shelf for ages wasn’t detecting quite right so I ordered another one and the difference in detection is huge. I’m not sure if these have a shelf life or what but yeah, that was my recent experience.
        • O Offline
          ostfilinchen
          Hi all,
          i have an issue with the PIR Sensor. I get alltime this error:
          1|mm | at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:76:44)
          1|mm | (node:1714) DeprecationWarning: sys is deprecated. Use util instead.
          1|mm | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 50, got 49.
          1|mm | App threw an error during load
          1|mm | Error: Module version mismatch. Expected 50, got 49.
          1|mm | at Error (native)
          1|mm | at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
          1|mm | at Object.Module._extensions…node (module.js:583:18)
          1|mm | at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
          1|mm | at Module.load (module.js:473:32)
          1|mm | at tryModuleLoad (module.js:432:12)
          1|mm | at Function.Module._load (module.js:424:3)
          1|mm | at Module.require (module.js:483:17)
          1|mm | at require (internal/module.js:20:19)
          It’s equal if i have the original from @paviro or the modification.
          Can anybody help me?
          Regards Daniel
          yawnsY 1 Reply Last reply Reply Quote 0
          • yawnsY Offline
            yawns Moderator @ostfilinchen
            @ostfilinchen
            1. please run npm list and find out your version number of electron
            2. change into the MMM-PIR-Sensor folder cd ~/MagicMirror/modules/MMM-PIR-Sensor
            3. run npm rebuild --runtime=electron --target=ELECTRONVERSION --disturl=https://atom.io/download/atom-shell --abi=50 and replace ELECTRONVERSION with the version number you found in step 1
            O 1 Reply Last reply Reply Quote 2
            • O Offline
              ostfilinchen @yawns
              @yawns. Is it possible that my Version is 1.4.13?
              • yawnsY Offline
                yawns Moderator
                Yes, that is possible. When I had to run this command last time I was using 1.4.0 …
                Just give it a try. Worst case is you have to delete the MMM-PIR-Sensor folder and git clone it again.
                • O Offline
                  ostfilinchen @yawns
                  @yawns now i get this error
                  pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ sudo npm rebuild --runtime=electron --target=1.4.13 --disturl=https://atom.io/download/atom-shell --abi=50
                  epoll@0.1.20 install /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
                  node-gyp rebuild
                  gyp ERR! clean error
                  gyp ERR! stack Error: EACCES: permission denied, unlink ‘build/Makefile’
                  gyp ERR! System Linux 4.4.38-v7+
                  gyp ERR! command “/usr/local/bin/node” “/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “rebuild”
                  gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
                  gyp ERR! node -v v7.0.0
                  gyp ERR! node-gyp -v v3.4.0
                  gyp ERR! not ok
                  npm ERR! Linux 4.4.38-v7+
                  npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “rebuild” “–runtime=electron” “–target=1.4.13” “–disturl=https://atom.io/download/atom-shell” “–abi=50”
                  npm ERR! node v7.0.0
                  npm ERR! npm v3.10.8
                  npm ERR! code ELIFECYCLE
                  npm ERR! epoll@0.1.20 install: node-gyp rebuild
                  npm ERR! Exit status 1
                  npm ERR!
                  npm ERR! Failed at the epoll@0.1.20 install script ‘node-gyp rebuild’.
                  npm ERR! If you do, this is most likely a problem with the epoll package,
                  npm ERR! not with npm itself.
                  npm ERR! node-gyp rebuild
                  npm ERR! npm bugs epoll
                  npm ERR! Or if that isn’t available, you can get their info via:
                  npm ERR! npm owner ls epoll
                  npm ERR! /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
                  • yawnsY Offline
                    yawns Moderator
                    why are you running it with sudo??
                    • O Offline
                      ostfilinchen
                      without sudo i get the same error
                      • O Offline
                        ostfilinchen
                        After a few New Installations now the mm starts and the PIR works.
                        • 4 / 4
