    MMM-PIR-Sensor tuning
    40 Posts 7 Posters 40.1k Views 6 Watching
      shgmongohh @jc21
      @jc21
      Thank you. I don´t have a camera.
      I don´t know if the sonsor works not correct or if I have another issue.
      When I install your module, have I to delete or uninstall the other pir-module?
      I only have renamed the folder.
      If i have to delete it, how is it done?
      Sebastian
        shgmongohh
        I have found a python programm, where I can track the sensor in a consolen window. Has anybody an idea how i can safe the data into a document? And how I can autostart my python programm?
        # Import required Python libraries
        import RPi.GPIO as GPIO
        import time
        import datetime
        # Use BCM GPIO references
        # instead of physical pin numbers
        GPIO.setmode(GPIO.BCM)
        # Define GPIO to use on Pi
        GPIO_PIR = 23
        print "Bewegungsmelder Test (CTRL-C zum Beenden)"
        print "========================================="
        # Set pin as input
        GPIO.setup(GPIO_PIR,GPIO.IN)      # Echo
        Current_State  = 0
        Previous_State = 0
        try:
          print "%s: Sensor initialisieren ..." % datetime.datetime.now()
          # Loop until PIR output is 0
          while GPIO.input(GPIO_PIR)==1:
            Current_State  = 0
          print "%s: Fertig! Warte auf Bewegung..."  % datetime.datetime.now()
          # Loop until users quits with CTRL-C
          while True :
            # Read PIR state
            Current_State = GPIO.input(GPIO_PIR)
            if Current_State==1 and Previous_State==0:
              # PIR is triggered
              print " %s: Bewegung erkannt!" % datetime.datetime.now()
              # Record previous state
              Previous_State=1
            elif Current_State==0 and Previous_State==1:
              # PIR has returned to ready state
              print " %s: Fertig! Warte auf Bewegung..."  % datetime.datetime.now()
              Previous_State=0
            # Wait for 10 milliseconds
            time.sleep(0.01)
        except KeyboardInterrupt:
          print " Exit"
          # Reset GPIO settings
          GPIO.cleanup()
          shgmongohh @shgmongohh
          It done. I can tune my PIR-Sensor.
          Here is a usefull Link.
          • O Offline
            open_book
            Hi, I’very been through a lot of the posts on the White Screen issue, and on this thread. I’m close… I can feel it, but I’ve an uncaught exception that I don’t understand.
            [TAILING] Tailing last 10 lines for [mm] process (change the value with --lines option)
            /home/pi/.pm2/logs/mm-error-0.log last 10 lines:
            0|mm | at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_helper.js:65:18
            0|mm | at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/onoff/onoff.js:27:5
            0|mm | at Array.forEach (native)
            0|mm | at Gpio.pollerEventHandler (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/onoff/onoff.js:26:13)
            0|mm | TypeError: Cannot read property ‘writeSync’ of undefined
            0|mm | at Class.activateMonitor (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_helper.js:21:17)
            0|mm | at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_helper.js:59:18
            link to screengrab.
            Anyone offer any tips as to what might be causing this?
            I’m on a Pi3 Model B v2.
            Have only installed the standard mirror module, and the MMM-PIR module. The mirror is working fine and the PIR module is loading, but the screen isn’t switching off.
            sudo insert motivational.quote
              jc21 @open_book
              @open_book Few things,
              1. What version of Raspbian are you using? The onoffnpm module has issues with some releases.
                Hint: cat /etc/os-release
              2. What does your config look like for the pir module, exactly?
              • O Offline
                open_book @jc21
                @jc21
                1.
                PRETTY_NAME=“Raspbian GNU/Linux 8 (jessie)”
                NAME=“Raspbian GNU/Linux”
                VERSION_ID=“8”
                VERSION=“8 (jessie)”
                ID=raspbian
                ID_LIKE=debian
                		module: 'MMM-PIR-Sensor',
                			sensorPIN: 3,
                			powerSaving: true,
                  jc21 @open_book
                  @open_book Very strange, it seems the module is trying to activate/deactive the monitor using the Relay, but you haven’t specified a relay to use.
                  I have noticed however, that sensorPIN of 3 shouldn’t work. This variable is incorrectly named, it is not actually the pin number of the header, but the GPIO number instead. Refer to this Pi 3 image showing which “pins” correspond to “gpio” numbers. You should be using one of 4, 5, 6, 12, 13, 18, 22, 23, 24, 25, 26 or 27.
                  For example, a sensorPIN of 4 would require the PIR io cable plugged in to pin header 7.
                  • O Offline
                    open_book @jc21
                    @jc21 hi again, thanks for your input so far.
                    I’ve had the sensorPIN at 22 previously. And tested it using the python script shared on a few other threads:
                    ´´´python
                    from gpiozero import MotionSensor
                    import os
                    pir= MotionSensor(22)
                    while True:
                    if pir.wait_for_motion(timeout=10*60):
                    print(“It lives”)
                    else:
                    os.system(“/opt/vc/bin/tvservice -0”)
                    The result spammed “It lives”. Which I understand to mean that the sensor is working… If I change the if to “os.system(”/opt/vc/bin/tvservice -p")" the screen shutsdown.
                    The reason I changed it was based on the results of “gpio readall”. I currently have power in pin 1 (3.3v), ground in pin 6 and data in pin 15
                    gpio readall tells me that physical 15 = BCM 22 = GPIO 3 so I decided to try sensorPin: 3.
                    I’ve changed it back to 22 now, but the result is still the same.
                    Other possible vectors are:
                    I’m forcing HDMI output because I’m using a HDMI -> DVI converter and so it seemed like a safe choice.
                    With dev tools open I can see that USER_PRESENCE is not being logged anywhere in the console.
                    I followed this post and ran:
                    “Run npm rebuild --runtime=electron --target=1.3.4 --disturl=https://atom.io/download/atom-shell --abi=49”
                    in the MMM-PIR-Sensor folder,
                      jc21
                      Sounds like you’re on top of that then.
                      Just fyi, the latest code for the original pir sensor module will rebuild the compiled dependencies for you as part of the npm install command in the module. There should be no reason to run npm rebuild manually unless you get those pesky “expected version xx but got xx” errors.
                      • O Offline
                        open_book @jc21
                        @jc21 just for closure here I found the issue. After running the python script again I realised that the PIR was always HIGH even with the sensitivty dialled right down.
                        So I checked the leads going into the pi and found that, despite checking it many times, I’d mixed up GND and VCC :(
                        The lesson for any other idiots out there when testing is, run this Python script and make sure that the PIR stops broadcasting “Motion Detected!” when you cover it with something:
                        import os
                        pir= MotionSensor(22) //the gpio pin PIR OUT is connected to
                        while True:
                                       if pir.motion_detected:
                                       print (“Motion Detected!”)
                        Code from this site
                        With some further adjustments for sensitivity it’s now working great!
                          jc21
                          Great stuff. People shouldn’t discount a faulty PIR either. The one I had on the shelf for ages wasn’t detecting quite right so I ordered another one and the difference in detection is huge. I’m not sure if these have a shelf life or what but yeah, that was my recent experience.
                          • O Offline
                            ostfilinchen
                            Hi all,
                            i have an issue with the PIR Sensor. I get alltime this error:
                            1|mm | at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:76:44)
                            1|mm | (node:1714) DeprecationWarning: sys is deprecated. Use util instead.
                            1|mm | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 50, got 49.
                            1|mm | App threw an error during load
                            1|mm | Error: Module version mismatch. Expected 50, got 49.
                            1|mm | at Error (native)
                            1|mm | at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
                            1|mm | at Object.Module._extensions…node (module.js:583:18)
                            1|mm | at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
                            1|mm | at Module.load (module.js:473:32)
                            1|mm | at tryModuleLoad (module.js:432:12)
                            1|mm | at Function.Module._load (module.js:424:3)
                            1|mm | at Module.require (module.js:483:17)
                            1|mm | at require (internal/module.js:20:19)
                            It’s equal if i have the original from @paviro or the modification.
                            Can anybody help me?
                            Regards Daniel
                            • Y Offline
                              yawns Moderator @ostfilinchen
                              @ostfilinchen
                              1. please run npm list and find out your version number of electron
                              2. change into the MMM-PIR-Sensor folder cd ~/MagicMirror/modules/MMM-PIR-Sensor
                              3. run npm rebuild --runtime=electron --target=ELECTRONVERSION --disturl=https://atom.io/download/atom-shell --abi=50 and replace ELECTRONVERSION with the version number you found in step 1
                              O 1 Reply Last reply Reply Quote 2
                              • O Offline
                                ostfilinchen @yawns
                                @yawns. Is it possible that my Version is 1.4.13?
                                • Y Offline
                                  yawns Moderator
                                  Yes, that is possible. When I had to run this command last time I was using 1.4.0 …
                                  Just give it a try. Worst case is you have to delete the MMM-PIR-Sensor folder and git clone it again.
                                  • O Offline
                                    ostfilinchen @yawns
                                    @yawns now i get this error
                                    pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ sudo npm rebuild --runtime=electron --target=1.4.13 --disturl=https://atom.io/download/atom-shell --abi=50
                                    epoll@0.1.20 install /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
                                    node-gyp rebuild
                                    gyp ERR! clean error
                                    gyp ERR! stack Error: EACCES: permission denied, unlink ‘build/Makefile’
                                    gyp ERR! System Linux 4.4.38-v7+
                                    gyp ERR! command “/usr/local/bin/node” “/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “rebuild”
                                    gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
                                    gyp ERR! node -v v7.0.0
                                    gyp ERR! node-gyp -v v3.4.0
                                    gyp ERR! not ok
                                    npm ERR! Linux 4.4.38-v7+
                                    npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “rebuild” “–runtime=electron” “–target=1.4.13” “–disturl=https://atom.io/download/atom-shell” “–abi=50”
                                    npm ERR! node v7.0.0
                                    npm ERR! npm v3.10.8
                                    npm ERR! code ELIFECYCLE
                                    npm ERR! epoll@0.1.20 install: node-gyp rebuild
                                    npm ERR! Exit status 1
                                    npm ERR!
                                    npm ERR! Failed at the epoll@0.1.20 install script ‘node-gyp rebuild’.
                                    npm ERR! If you do, this is most likely a problem with the epoll package,
                                    npm ERR! not with npm itself.
                                    npm ERR! node-gyp rebuild
                                    npm ERR! npm bugs epoll
                                    npm ERR! Or if that isn’t available, you can get their info via:
                                    npm ERR! npm owner ls epoll
                                    npm ERR! /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
                                    • Y Offline
                                      yawns Moderator
                                      why are you running it with sudo??
                                      • O Offline
                                        ostfilinchen
                                        without sudo i get the same error
                                        • O Offline
                                          ostfilinchen
                                          After a few New Installations now the mm starts and the PIR works.
