    MMM-PIR-Sensor tuning
    40 Posts 7 Posters 39.4k Views 6 Watching
      jc21
      Do you experience the same thing with paviro’s original module? https://github.com/paviro/MMM-PIR-Sensor
        shgmongohh @jc21
        @jc21
        No with the “original” PIR-Sensor I don´t have this issues. That´s why I it noticed.
        I have still the issue with the sensor, that it turns on the monitior at night, when nobody is there. I need a programm to track, how often this at night happens. If it is only one or two times at night or more often.
        Sebastian
          jc21 @shgmongohh
          @shgmongohh Ok I’ll take a look at my stuff soon. I’m in the middle of writing another module that takes a photo when this PIR module senses user presence, if you had a camera attached it might be useful to you to see what the pir is detecting, if anything.
            shgmongohh @jc21
            @jc21
            Thank you. I don´t have a camera.
            I don´t know if the sonsor works not correct or if I have another issue.
            When I install your module, have I to delete or uninstall the other pir-module?
            I only have renamed the folder.
            If i have to delete it, how is it done?
            Sebastian
              shgmongohh
              I have found a python programm, where I can track the sensor in a consolen window. Has anybody an idea how i can safe the data into a document? And how I can autostart my python programm?
              # Import required Python libraries
              import RPi.GPIO as GPIO
              import time
              import datetime
              # Use BCM GPIO references
              # instead of physical pin numbers
              GPIO.setmode(GPIO.BCM)
              # Define GPIO to use on Pi
              GPIO_PIR = 23
              print "Bewegungsmelder Test (CTRL-C zum Beenden)"
              print "========================================="
              # Set pin as input
              GPIO.setup(GPIO_PIR,GPIO.IN)      # Echo
              Current_State  = 0
              Previous_State = 0
              try:
                print "%s: Sensor initialisieren ..." % datetime.datetime.now()
                # Loop until PIR output is 0
                while GPIO.input(GPIO_PIR)==1:
                  Current_State  = 0
                print "%s: Fertig! Warte auf Bewegung..."  % datetime.datetime.now()
                # Loop until users quits with CTRL-C
                while True :
                  # Read PIR state
                  Current_State = GPIO.input(GPIO_PIR)
                  if Current_State==1 and Previous_State==0:
                    # PIR is triggered
                    print " %s: Bewegung erkannt!" % datetime.datetime.now()
                    # Record previous state
                    Previous_State=1
                  elif Current_State==0 and Previous_State==1:
                    # PIR has returned to ready state
                    print " %s: Fertig! Warte auf Bewegung..."  % datetime.datetime.now()
                    Previous_State=0
                  # Wait for 10 milliseconds
                  time.sleep(0.01)
              except KeyboardInterrupt:
                print " Exit"
                # Reset GPIO settings
                GPIO.cleanup()
                shgmongohh @shgmongohh
                It done. I can tune my PIR-Sensor.
                Here is a usefull Link.
                • O Offline
                  open_book
                  Hi, I’very been through a lot of the posts on the White Screen issue, and on this thread. I’m close… I can feel it, but I’ve an uncaught exception that I don’t understand.
                  [TAILING] Tailing last 10 lines for [mm] process (change the value with --lines option)
                  /home/pi/.pm2/logs/mm-error-0.log last 10 lines:
                  0|mm | at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_helper.js:65:18
                  0|mm | at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/onoff/onoff.js:27:5
                  0|mm | at Array.forEach (native)
                  0|mm | at Gpio.pollerEventHandler (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/onoff/onoff.js:26:13)
                  0|mm | TypeError: Cannot read property ‘writeSync’ of undefined
                  0|mm | at Class.activateMonitor (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_helper.js:21:17)
                  0|mm | at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_helper.js:59:18
                  link to screengrab.
                  Anyone offer any tips as to what might be causing this?
                  I’m on a Pi3 Model B v2.
                  Have only installed the standard mirror module, and the MMM-PIR module. The mirror is working fine and the PIR module is loading, but the screen isn’t switching off.
                  sudo insert motivational.quote
                    jc21 @open_book
                    @open_book Few things,
                    1. What version of Raspbian are you using? The onoffnpm module has issues with some releases.
                      Hint: cat /etc/os-release
                    2. What does your config look like for the pir module, exactly?
                    • O Offline
                      open_book @jc21
                      @jc21
                      1.
                      PRETTY_NAME=“Raspbian GNU/Linux 8 (jessie)”
                      NAME=“Raspbian GNU/Linux”
                      VERSION_ID=“8”
                      VERSION=“8 (jessie)”
                      ID=raspbian
                      ID_LIKE=debian
                      		module: 'MMM-PIR-Sensor',
                      			sensorPIN: 3,
                      			powerSaving: true,
                        jc21 @open_book
                        @open_book Very strange, it seems the module is trying to activate/deactive the monitor using the Relay, but you haven’t specified a relay to use.
                        I have noticed however, that sensorPIN of 3 shouldn’t work. This variable is incorrectly named, it is not actually the pin number of the header, but the GPIO number instead. Refer to this Pi 3 image showing which “pins” correspond to “gpio” numbers. You should be using one of 4, 5, 6, 12, 13, 18, 22, 23, 24, 25, 26 or 27.
                        For example, a sensorPIN of 4 would require the PIR io cable plugged in to pin header 7.
                        • O Offline
                          open_book @jc21
                          @jc21 hi again, thanks for your input so far.
                          I’ve had the sensorPIN at 22 previously. And tested it using the python script shared on a few other threads:
                          ´´´python
                          from gpiozero import MotionSensor
                          import os
                          pir= MotionSensor(22)
                          while True:
                          if pir.wait_for_motion(timeout=10*60):
                          print(“It lives”)
                          else:
                          os.system(“/opt/vc/bin/tvservice -0”)
                          The result spammed “It lives”. Which I understand to mean that the sensor is working… If I change the if to “os.system(”/opt/vc/bin/tvservice -p")" the screen shutsdown.
                          The reason I changed it was based on the results of “gpio readall”. I currently have power in pin 1 (3.3v), ground in pin 6 and data in pin 15
                          gpio readall tells me that physical 15 = BCM 22 = GPIO 3 so I decided to try sensorPin: 3.
                          I’ve changed it back to 22 now, but the result is still the same.
                          Other possible vectors are:
                          I’m forcing HDMI output because I’m using a HDMI -> DVI converter and so it seemed like a safe choice.
                          With dev tools open I can see that USER_PRESENCE is not being logged anywhere in the console.
                          I followed this post and ran:
                          “Run npm rebuild --runtime=electron --target=1.3.4 --disturl=https://atom.io/download/atom-shell --abi=49”
                          in the MMM-PIR-Sensor folder,
                            jc21
                            Sounds like you’re on top of that then.
                            Just fyi, the latest code for the original pir sensor module will rebuild the compiled dependencies for you as part of the npm install command in the module. There should be no reason to run npm rebuild manually unless you get those pesky “expected version xx but got xx” errors.
                            • O Offline
                              open_book @jc21
                              @jc21 just for closure here I found the issue. After running the python script again I realised that the PIR was always HIGH even with the sensitivty dialled right down.
                              So I checked the leads going into the pi and found that, despite checking it many times, I’d mixed up GND and VCC :(
                              The lesson for any other idiots out there when testing is, run this Python script and make sure that the PIR stops broadcasting “Motion Detected!” when you cover it with something:
                              import os
                              pir= MotionSensor(22) //the gpio pin PIR OUT is connected to
                              while True:
                                             if pir.motion_detected:
                                             print (“Motion Detected!”)
                              Code from this site
                              With some further adjustments for sensitivity it’s now working great!
                                jc21
                                Great stuff. People shouldn’t discount a faulty PIR either. The one I had on the shelf for ages wasn’t detecting quite right so I ordered another one and the difference in detection is huge. I’m not sure if these have a shelf life or what but yeah, that was my recent experience.
                                • O Offline
                                  ostfilinchen
                                  Hi all,
                                  i have an issue with the PIR Sensor. I get alltime this error:
                                  1|mm | at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:76:44)
                                  1|mm | (node:1714) DeprecationWarning: sys is deprecated. Use util instead.
                                  1|mm | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 50, got 49.
                                  1|mm | App threw an error during load
                                  1|mm | Error: Module version mismatch. Expected 50, got 49.
                                  1|mm | at Error (native)
                                  1|mm | at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
                                  1|mm | at Object.Module._extensions…node (module.js:583:18)
                                  1|mm | at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
                                  1|mm | at Module.load (module.js:473:32)
                                  1|mm | at tryModuleLoad (module.js:432:12)
                                  1|mm | at Function.Module._load (module.js:424:3)
                                  1|mm | at Module.require (module.js:483:17)
                                  1|mm | at require (internal/module.js:20:19)
                                  It’s equal if i have the original from @paviro or the modification.
                                  Can anybody help me?
                                  Regards Daniel
                                  • Y Offline
                                    yawns Moderator @ostfilinchen
                                    @ostfilinchen
                                    1. please run npm list and find out your version number of electron
                                    2. change into the MMM-PIR-Sensor folder cd ~/MagicMirror/modules/MMM-PIR-Sensor
                                    3. run npm rebuild --runtime=electron --target=ELECTRONVERSION --disturl=https://atom.io/download/atom-shell --abi=50 and replace ELECTRONVERSION with the version number you found in step 1
                                    O 1 Reply Last reply Reply Quote 2
                                    • O Offline
                                      ostfilinchen @yawns
                                      @yawns. Is it possible that my Version is 1.4.13?
                                      • Y Offline
                                        yawns Moderator
                                        Yes, that is possible. When I had to run this command last time I was using 1.4.0 …
                                        Just give it a try. Worst case is you have to delete the MMM-PIR-Sensor folder and git clone it again.
                                        • O Offline
                                          ostfilinchen @yawns
                                          @yawns now i get this error
                                          pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ sudo npm rebuild --runtime=electron --target=1.4.13 --disturl=https://atom.io/download/atom-shell --abi=50
                                          epoll@0.1.20 install /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
                                          node-gyp rebuild
                                          gyp ERR! clean error
                                          gyp ERR! stack Error: EACCES: permission denied, unlink ‘build/Makefile’
                                          gyp ERR! System Linux 4.4.38-v7+
                                          gyp ERR! command “/usr/local/bin/node” “/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “rebuild”
                                          gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
                                          gyp ERR! node -v v7.0.0
                                          gyp ERR! node-gyp -v v3.4.0
                                          gyp ERR! not ok
                                          npm ERR! Linux 4.4.38-v7+
                                          npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “rebuild” “–runtime=electron” “–target=1.4.13” “–disturl=https://atom.io/download/atom-shell” “–abi=50”
                                          npm ERR! node v7.0.0
                                          npm ERR! npm v3.10.8
                                          npm ERR! code ELIFECYCLE
                                          npm ERR! epoll@0.1.20 install: node-gyp rebuild
                                          npm ERR! Exit status 1
                                          npm ERR!
                                          npm ERR! Failed at the epoll@0.1.20 install script ‘node-gyp rebuild’.
                                          npm ERR! If you do, this is most likely a problem with the epoll package,
                                          npm ERR! not with npm itself.
                                          npm ERR! node-gyp rebuild
                                          npm ERR! npm bugs epoll
                                          npm ERR! Or if that isn’t available, you can get their info via:
                                          npm ERR! npm owner ls epoll
                                          npm ERR! /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
                                          • Y Offline
                                            yawns Moderator
                                            why are you running it with sudo??
