    MMM-PIR-Sensor tuning
    40 Posts 7 Posters 40.3k Views 6 Watching
    • O
      open_book @jc21
      @jc21 hi again, thanks for your input so far.
      I’ve had the sensorPIN at 22 previously. And tested it using the python script shared on a few other threads:
      ´´´python
      from gpiozero import MotionSensor
      import os
      pir= MotionSensor(22)
      while True:
      if pir.wait_for_motion(timeout=10*60):
      print(“It lives”)
      else:
      os.system(“/opt/vc/bin/tvservice -0”)
      The result spammed “It lives”. Which I understand to mean that the sensor is working… If I change the if to “os.system(”/opt/vc/bin/tvservice -p")" the screen shutsdown.
      The reason I changed it was based on the results of “gpio readall”. I currently have power in pin 1 (3.3v), ground in pin 6 and data in pin 15
      gpio readall tells me that physical 15 = BCM 22 = GPIO 3 so I decided to try sensorPin: 3.
      I’ve changed it back to 22 now, but the result is still the same.
      Other possible vectors are:
      I’m forcing HDMI output because I’m using a HDMI -> DVI converter and so it seemed like a safe choice.
      With dev tools open I can see that USER_PRESENCE is not being logged anywhere in the console.
      I followed this post and ran:
      “Run npm rebuild --runtime=electron --target=1.3.4 --disturl=https://atom.io/download/atom-shell --abi=49”
      in the MMM-PIR-Sensor folder,
      sudo insert motivational.quote
        jc21
        Sounds like you’re on top of that then.
        Just fyi, the latest code for the original pir sensor module will rebuild the compiled dependencies for you as part of the npm install command in the module. There should be no reason to run npm rebuild manually unless you get those pesky “expected version xx but got xx” errors.
        • O
          open_book @jc21
          @jc21 just for closure here I found the issue. After running the python script again I realised that the PIR was always HIGH even with the sensitivty dialled right down.
          So I checked the leads going into the pi and found that, despite checking it many times, I’d mixed up GND and VCC :(
          The lesson for any other idiots out there when testing is, run this Python script and make sure that the PIR stops broadcasting “Motion Detected!” when you cover it with something:
          import os
          pir= MotionSensor(22) //the gpio pin PIR OUT is connected to
          while True:
                         if pir.motion_detected:
                         print (“Motion Detected!”)
          Code from this site
          With some further adjustments for sensitivity it’s now working great!
            jc21
            Great stuff. People shouldn’t discount a faulty PIR either. The one I had on the shelf for ages wasn’t detecting quite right so I ordered another one and the difference in detection is huge. I’m not sure if these have a shelf life or what but yeah, that was my recent experience.
            • O
              ostfilinchen
              Hi all,
              i have an issue with the PIR Sensor. I get alltime this error:
              1|mm | at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:76:44)
              1|mm | (node:1714) DeprecationWarning: sys is deprecated. Use util instead.
              1|mm | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 50, got 49.
              1|mm | App threw an error during load
              1|mm | Error: Module version mismatch. Expected 50, got 49.
              1|mm | at Error (native)
              1|mm | at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
              1|mm | at Object.Module._extensions…node (module.js:583:18)
              1|mm | at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
              1|mm | at Module.load (module.js:473:32)
              1|mm | at tryModuleLoad (module.js:432:12)
              1|mm | at Function.Module._load (module.js:424:3)
              1|mm | at Module.require (module.js:483:17)
              1|mm | at require (internal/module.js:20:19)
              It’s equal if i have the original from @paviro or the modification.
              Can anybody help me?
              Regards Daniel
              • Y
                yawns Moderator @ostfilinchen
                @ostfilinchen
                1. please run npm list and find out your version number of electron
                2. change into the MMM-PIR-Sensor folder cd ~/MagicMirror/modules/MMM-PIR-Sensor
                3. run npm rebuild --runtime=electron --target=ELECTRONVERSION --disturl=https://atom.io/download/atom-shell --abi=50 and replace ELECTRONVERSION with the version number you found in step 1
                O 1 Reply Last reply Reply Quote 2
                • O
                  ostfilinchen @yawns
                  @yawns. Is it possible that my Version is 1.4.13?
                  • Y
                    yawns Moderator
                    Yes, that is possible. When I had to run this command last time I was using 1.4.0 …
                    Just give it a try. Worst case is you have to delete the MMM-PIR-Sensor folder and git clone it again.
                    • O
                      ostfilinchen @yawns
                      @yawns now i get this error
                      pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ sudo npm rebuild --runtime=electron --target=1.4.13 --disturl=https://atom.io/download/atom-shell --abi=50
                      epoll@0.1.20 install /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
                      node-gyp rebuild
                      gyp ERR! clean error
                      gyp ERR! stack Error: EACCES: permission denied, unlink ‘build/Makefile’
                      gyp ERR! System Linux 4.4.38-v7+
                      gyp ERR! command “/usr/local/bin/node” “/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “rebuild”
                      gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
                      gyp ERR! node -v v7.0.0
                      gyp ERR! node-gyp -v v3.4.0
                      gyp ERR! not ok
                      npm ERR! Linux 4.4.38-v7+
                      npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “rebuild” “–runtime=electron” “–target=1.4.13” “–disturl=https://atom.io/download/atom-shell” “–abi=50”
                      npm ERR! node v7.0.0
                      npm ERR! npm v3.10.8
                      npm ERR! code ELIFECYCLE
                      npm ERR! epoll@0.1.20 install: node-gyp rebuild
                      npm ERR! Exit status 1
                      npm ERR!
                      npm ERR! Failed at the epoll@0.1.20 install script ‘node-gyp rebuild’.
                      npm ERR! If you do, this is most likely a problem with the epoll package,
                      npm ERR! not with npm itself.
                      npm ERR! node-gyp rebuild
                      npm ERR! npm bugs epoll
                      npm ERR! Or if that isn’t available, you can get their info via:
                      npm ERR! npm owner ls epoll
                      npm ERR! /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
                      • Y
                        yawns Moderator
                        why are you running it with sudo??
                        • O
                          ostfilinchen
                          without sudo i get the same error
                          • O
                            ostfilinchen
                            After a few New Installations now the mm starts and the PIR works.
