    MMM-PIR-Sensor tuning
    40 Posts 7 Posters 39.4k Views 6 Watching
      jc21
      Sounds like you’re on top of that then.
      Just fyi, the latest code for the original pir sensor module will rebuild the compiled dependencies for you as part of the npm install command in the module. There should be no reason to run npm rebuild manually unless you get those pesky “expected version xx but got xx” errors.
      • O Offline
        open_book @jc21
        @jc21 just for closure here I found the issue. After running the python script again I realised that the PIR was always HIGH even with the sensitivty dialled right down.
        So I checked the leads going into the pi and found that, despite checking it many times, I’d mixed up GND and VCC :(
        The lesson for any other idiots out there when testing is, run this Python script and make sure that the PIR stops broadcasting “Motion Detected!” when you cover it with something:
        from gpiozero import MotionSensor
        import os
        pir= MotionSensor(22) //the gpio pin PIR OUT is connected to
        while True:
                       if pir.motion_detected:
                       print (“Motion Detected!”)
        Code from this site
        With some further adjustments for sensitivity it’s now working great!
        sudo insert motivational.quote
          jc21
          Great stuff. People shouldn’t discount a faulty PIR either. The one I had on the shelf for ages wasn’t detecting quite right so I ordered another one and the difference in detection is huge. I’m not sure if these have a shelf life or what but yeah, that was my recent experience.
          • O Offline
            ostfilinchen
            Hi all,
            i have an issue with the PIR Sensor. I get alltime this error:
            1|mm | at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:76:44)
            1|mm | (node:1714) DeprecationWarning: sys is deprecated. Use util instead.
            1|mm | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Module version mismatch. Expected 50, got 49.
            1|mm | App threw an error during load
            1|mm | Error: Module version mismatch. Expected 50, got 49.
            1|mm | at Error (native)
            1|mm | at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
            1|mm | at Object.Module._extensions…node (module.js:583:18)
            1|mm | at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
            1|mm | at Module.load (module.js:473:32)
            1|mm | at tryModuleLoad (module.js:432:12)
            1|mm | at Function.Module._load (module.js:424:3)
            1|mm | at Module.require (module.js:483:17)
            1|mm | at require (internal/module.js:20:19)
            It’s equal if i have the original from @paviro or the modification.
            Can anybody help me?
            Regards Daniel
            • Y Offline
              yawns Moderator @ostfilinchen
              @ostfilinchen
              1. please run npm list and find out your version number of electron
              2. change into the MMM-PIR-Sensor folder cd ~/MagicMirror/modules/MMM-PIR-Sensor
              3. run npm rebuild --runtime=electron --target=ELECTRONVERSION --disturl=https://atom.io/download/atom-shell --abi=50 and replace ELECTRONVERSION with the version number you found in step 1
              O 1 Reply Last reply Reply Quote 2
              • O Offline
                ostfilinchen @yawns
                @yawns. Is it possible that my Version is 1.4.13?
                • Y Offline
                  yawns Moderator
                  Yes, that is possible. When I had to run this command last time I was using 1.4.0 …
                  Just give it a try. Worst case is you have to delete the MMM-PIR-Sensor folder and git clone it again.
                  • O Offline
                    ostfilinchen @yawns
                    @yawns now i get this error
                    pi@raspberrypi:~/MagicMirror/modules/MMM-PIR-Sensor $ sudo npm rebuild --runtime=electron --target=1.4.13 --disturl=https://atom.io/download/atom-shell --abi=50
                    epoll@0.1.20 install /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
                    node-gyp rebuild
                    gyp ERR! clean error
                    gyp ERR! stack Error: EACCES: permission denied, unlink ‘build/Makefile’
                    gyp ERR! System Linux 4.4.38-v7+
                    gyp ERR! command “/usr/local/bin/node” “/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “rebuild”
                    gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
                    gyp ERR! node -v v7.0.0
                    gyp ERR! node-gyp -v v3.4.0
                    gyp ERR! not ok
                    npm ERR! Linux 4.4.38-v7+
                    npm ERR! argv “/usr/local/bin/node” “/usr/local/bin/npm” “rebuild” “–runtime=electron” “–target=1.4.13” “–disturl=https://atom.io/download/atom-shell” “–abi=50”
                    npm ERR! node v7.0.0
                    npm ERR! npm v3.10.8
                    npm ERR! code ELIFECYCLE
                    npm ERR! epoll@0.1.20 install: node-gyp rebuild
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the epoll@0.1.20 install script ‘node-gyp rebuild’.
                    npm ERR! If you do, this is most likely a problem with the epoll package,
                    npm ERR! not with npm itself.
                    npm ERR! node-gyp rebuild
                    npm ERR! npm bugs epoll
                    npm ERR! Or if that isn’t available, you can get their info via:
                    npm ERR! npm owner ls epoll
                    npm ERR! /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
                    • Y Offline
                      yawns Moderator
                      why are you running it with sudo??
                      • O Offline
                        ostfilinchen
                        without sudo i get the same error
                        • O Offline
                          ostfilinchen
                          After a few New Installations now the mm starts and the PIR works.
