    Microphone/MMM-voice Help
    31 Posts 7 Posters 13.9k Views 7 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @tnp0327
      @tnp0327 the file that gets generated is located at modules/MMM-voice/debug.log
      • T Offline
        tnp0327 @strawberry 3.141
        @strawberry-3-141 here is a snapshot of the directory. I do not see a debug.log file. Do you know why this could happen?
          @tnp0327 can you show me the mmm-voice part of your config js
          • T Offline
            @strawberry-3-141 I originally had it in the config section but moved it up below “position”. However, I am still not seeing a debug.log file. I rebooted and still nothing.
              @tnp0327 it needs to be in the config section
              • T Offline
                @strawberry-3-141 thanks! I moved it to the config section.
                I still do not see a debug.log file.
                When I run MM, the MMM-voice area (bottom left) says Initialising… and underneath that it says undefined.
                  sdetweil @tnp0327
                  have u restarted the mirror a few times, without reboot?
                  the sound process does NOT get restarted…
                  get back to the commandline and do
                  ps -ef | grep pocket
                  and then kill that process so it can be restarted…
                  or reboot…
                  i created this little script for a prior mirror runtime that I use here too
                  #!/bin/bash
                  ps -ef | grep pocket | grep -v "color=auto" | awk '{print $2}' | xargs sudo kill -9
                  ps -ef | grep node | grep -v "color=auto"  | awk '{print $2}' | xargs sudo kill -9
                  • T Offline
                    tnp0327 @sdetweil
                    @sdetweil I have restarted the MM process and rebooted the PI - still no debug.log file.
                      sdetweil @tnp0327
                      @tnp0327 can u minimize the mirror and look at the console log of the terminal window… maybe there is some other error…
                      minimize = alt-spacebar, n
                      • T Offline
                        tnp0327
                        @sdetweil @strawberry-3-141 so I did not find a debug file but was able to follow the instructions to look at the console log and the only message I am seeing regarding MMM-voice is:
                        Starting module: MMM-voice MMM-voice.js:82
                        MMM-voice is waiting for voice command registrations. MMM-voice.js:85
                        • 4 / 4
