    Microphone/MMM-voice Help
    31 Posts 7 Posters 15.4k Views 7 Watching
      sdetweil @tnp0327
      @tnp0327 minimize the mirror window (alt-spacebar, n) and the terminal windows used to start the mirror will be shown… the debug is in that window…
      least thats how I do it!..
      this debugs the node_helper
      ctrl-shift-i will open the mirror debug window (select console tab) this will show the module level debug
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @tnp0327
        @tnp0327 the file that gets generated is located at modules/MMM-voice/debug.log
        • T Offline
          tnp0327 @strawberry 3.141
          @strawberry-3-141 here is a snapshot of the directory. I do not see a debug.log file. Do you know why this could happen?
            @tnp0327 can you show me the mmm-voice part of your config js
            • T Offline
              @strawberry-3-141 I originally had it in the config section but moved it up below “position”. However, I am still not seeing a debug.log file. I rebooted and still nothing.
                @tnp0327 it needs to be in the config section
                • T Offline
                  @strawberry-3-141 thanks! I moved it to the config section.
                  I still do not see a debug.log file.
                  When I run MM, the MMM-voice area (bottom left) says Initialising… and underneath that it says undefined.
                    sdetweil @tnp0327
                    have u restarted the mirror a few times, without reboot?
                    the sound process does NOT get restarted…
                    get back to the commandline and do
                    ps -ef | grep pocket
                    and then kill that process so it can be restarted…
                    or reboot…
                    i created this little script for a prior mirror runtime that I use here too
                    #!/bin/bash
                    ps -ef | grep pocket | grep -v "color=auto" | awk '{print $2}' | xargs sudo kill -9
                    ps -ef | grep node | grep -v "color=auto"  | awk '{print $2}' | xargs sudo kill -9
                    • T Offline
                      tnp0327 @sdetweil
                      @sdetweil I have restarted the MM process and rebooted the PI - still no debug.log file.
                        sdetweil @tnp0327
                        @tnp0327 can u minimize the mirror and look at the console log of the terminal window… maybe there is some other error…
                        minimize = alt-spacebar, n
                        • T Offline
                          tnp0327
                          @sdetweil @strawberry-3-141 so I did not find a debug file but was able to follow the instructions to look at the console log and the only message I am seeing regarding MMM-voice is:
                          Starting module: MMM-voice MMM-voice.js:82
                          MMM-voice is waiting for voice command registrations. MMM-voice.js:85
                            sdetweil @tnp0327
                            @tnp0327 before the modules is the startup of the node_helpers… if u can scroll back up the console window, you might find something else…
                            have u tested to make sure the mic is working? with the rec command?
                            rec somefile.wav
                            on the bottom of the console window should be a meter like bar that moves when u speak…
                            then you can control-z out of the rec command and then play somefile.wav to see how it sounds…
                            • T Offline
                              tnp0327
                              OMW to work now - will run it again later and update with my feedback. Thanks for the help so far.
                                Abhilash1368 @tnp0327
                                @tnp0327 I am going through same thing,it displays mic flashing symbol and just says initialising and undefined at bottom(if degug:true).Did you resolve it?please let me how to make it work?
                                  strawberry 3.141 Project Sponsor Module Developer @Abhilash1368
                                  @abhilash1368 do you have content in your debug log file?
                                    Abhilash1368 @strawberry 3.141
                                    @strawberry-3-141 I don’t see any content,but its working now.Initially I have my own custom twitter module loaded along with MMM-voice(my twitter.js is not modified yet to support MMM-voice). Once after making changes to my twitter.js according to “Hey Lucy” documentation to receive voice notifications,then it is started working. Thanks
                                    • richland007R Offline
                                      richland007
                                      @strawberry-3-141 Ok so i have a very similar situation i have AlexaPi (and MMM-AlexaPi for visual feedback) and want to use MMM-voice and Hello-Lucy. I have 2 USB microphones (a webcam that i talk to AlexaPI and a USB sound card that i want to use for MMM-voice)
                                      On the config.js i have assigned microphone id of 2 for MMM-voice ( arecord -l and the install of MMM-voice show that alsa as 0 USB webcam as card 1 and USB sound card as card 2)
                                      when i start magic mirror MMM-voice says “initializing” than briefly “Waiting for module commands” than settles on “error”
                                      My questions are:
                                      1. and i am pretty sure i have an answer for this is that AlexaPi and MMM-voice can they use the same mic or not … most likely not .
                                      2. why isn’t using microphone #2 straight forward do i have to twitch anything on alsa config, etc will pulse audio be better and what is the difference ?? how do we mitigate this problem??
                                      I have tested and confirmed that both usb microphones work when they are plugged each by themselves but not when they are both simultaneously plugged in only the webcam would record … i am not sure if i am putting the right parameter here “arecord hw:1,0 -d 10 /tmp/test-mic.wav”
                                      Please any help will be greatly appreciated
                                      Denis
                                      • T Offline
                                        TheGeekfather @richland007
                                        @richland007
                                        I too am trying to get Hello-Lucy/Voice to work with my usb soundcard and microphone. I can record outside of MagicMirror so that works but I have the same problem:
                                        “displays mic flashing symbol and just says initialising and undefined at bottom”
                                        I have tried following the documentation but still no luck
                                        Anyone get Hello-Lucy to work?
                                        S Mykle1M 2 Replies Last reply Reply Quote 0
                                          sdetweil @TheGeekfather
                                          @TheGeekfather use arecord -l and lsusb to find the hw: device id needed…
                                            Mykle1 Project Sponsor Module Developer @TheGeekfather
                                            @TheGeekfather
                                            @cowboysdude
                                            My apologies, gentlemen. There is a problem with the mic upon install that seems to be specific to the Pi. @cowboysdude did an install late last night and he encountered the same issue, so forgive me. I am looking at it right now and will not sleep until it is resolved. Not!
                                            Seriously, it will be fixed ASAP.
                                            Thank you for your patience and interest.
