    Microphone/MMM-voice Help
    31 Posts 7 Posters 14.1k Views 7 Watching
      sdetweil @tnp0327
      @tnp0327 minimize the mirror window (alt-spacebar, n) and the terminal windows used to start the mirror will be shown… the debug is in that window…
      least thats how I do it!..
      this debugs the node_helper
      ctrl-shift-i will open the mirror debug window (select console tab) this will show the module level debug
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @tnp0327
        @tnp0327 the file that gets generated is located at modules/MMM-voice/debug.log
        • T Offline
          tnp0327 @strawberry 3.141
          @strawberry-3-141 here is a snapshot of the directory. I do not see a debug.log file. Do you know why this could happen?
            @tnp0327 can you show me the mmm-voice part of your config js
            • T Offline
              @strawberry-3-141 I originally had it in the config section but moved it up below “position”. However, I am still not seeing a debug.log file. I rebooted and still nothing.
                @tnp0327 it needs to be in the config section
                • T Offline
                  @strawberry-3-141 thanks! I moved it to the config section.
                  I still do not see a debug.log file.
                  When I run MM, the MMM-voice area (bottom left) says Initialising… and underneath that it says undefined.
                    sdetweil @tnp0327
                    have u restarted the mirror a few times, without reboot?
                    the sound process does NOT get restarted…
                    get back to the commandline and do
                    ps -ef | grep pocket
                    and then kill that process so it can be restarted…
                    or reboot…
                    i created this little script for a prior mirror runtime that I use here too
                    #!/bin/bash
                    ps -ef | grep pocket | grep -v "color=auto" | awk '{print $2}' | xargs sudo kill -9
                    ps -ef | grep node | grep -v "color=auto"  | awk '{print $2}' | xargs sudo kill -9
                    • T Offline
                      tnp0327 @sdetweil
                      @sdetweil I have restarted the MM process and rebooted the PI - still no debug.log file.
                        sdetweil @tnp0327
                        @tnp0327 can u minimize the mirror and look at the console log of the terminal window… maybe there is some other error…
                        minimize = alt-spacebar, n
                        • 1 / 4
