    Microsoft To-Do (wunderlist replacement?)
    45 Posts 17 Posters 34.1k Views 19 Watching
      andyyy
      Hello,
      I am having trouble setting up this module. At the point refresh token generation I am failing.
      https://github.com/thobach/MMM-MicrosoftToDo/#refresh-token-generation-refresh-token
      1). Open terminal app -> I tried the windows console, powershell and secure shell (on the PI), but everywhere I receive just errors as output.
      Can someone give some guidance. Thanks.
      • T Offline
        thobach @andyyy
        @andyyy What error message do you get? Are you on Windows 10 which should have curl pre-installed? I updated the readme file to replace the space symbols with %20 as that seemed to have caused issues for some. Please make sure to preserve the ’ symbol at the end of the call.
        • T Offline
          thobach @binderth
          @binderth The refresh happens every 60s. I don’t plan to implement a fade-option, sorry, it would require quite some effort given the current implementation.
          • T Offline
            thobach @Jan
            @Jan You’re welcome. Have you tried adding the module multiple times in the config file with different listId values?
            • T Offline
              thobach @binderth
              @binderth Did the tips from @ThaliaFromPrussia (https://forum.magicmirror.builders/post/68615) work for you to see what error you are getting on the magic mirror front-end?
                Jan @thobach
                @thobach Thx for your reply. Your solution has not exactly the effect what i want, but it works fine for me ;-)
                  andyyy @thobach
                  @thobach
                  curl -X POST https://login.microsoftonline.com/common/oauth2/v2.0/token
                  Length Required
                  Length Required
                  HTTP Error 411. The request must be chunked or have a content length.
                  I am sure curl is installed since other modules with OAuth are working as well.
                  • G Offline
                    geoffroff
                    Hi
                    Managed to get the default task list to show but cannot get any other list to show. It just States Loading Tasks but never changes. Selected the list from ToDo but the ‘ID’ is a lot shorter than the example given.
                    Is there something I’m missing here?
                    It seems like this should work but just having trouble getting it to link. Not overly impressed with ToDo yet but need a shared environment and this was the simple choice having previously used Wunderlist.
                    Cheers
                    G
                      mherke
                      i followed the README.MD on github step by step and now i got it running :) i tried a few weeks ago several times without success and was pretty close to give up.
                      thanks an kind regards!
                      • W Offline
                        wazzu @geoffroff
                        @geoffroff
                        I had the same problem and I also had a shorter ID than the example. And of course, the status stay on “Loading tasks” for ever.
                        Finally, to solve this and get the full length link, I’ve done the following :
                        • create a share link from the list and open it
                        • click on “Sign in to join list”
                        • on next windows, click on “open”
                          I finally have an error “List not found” but in the url is the correct ID which is working as ListID, e.g :
                          https://to-do.live.com/tasks/AQMkADAwATMwNAItYmQyZS0wNnYxLTAwAi0wMAoALgAAAwyBXwAxHLZDhD1s2yT7wLoBAIZRCieiy1tMpuO70ZBr_R8AA3lr_WoAAAA=
                        Hope it helps,
                        Cheers,
                        G 1 Reply Last reply Reply Quote 1
                        • Z Offline
                          zolabus
                          HI on the refresh token I have this error
                          curl: (6) Could not resolve host:
                          {“error”:“invalid_request”,“error_description”:“AADSTS900144: The request body must contain the following parameter: ‘grant_type’.\r\nTrace ID: c89030f5-7596-4716-b56b-baafdc670100\r\nCorrelation ID: 3c6c0d5a-8928-47f9-8916-30fb1a369a8e\r\nTimestamp: 2020-04-24 23:29:45Z”,“error_codes”:[900144],“timestamp”:“2020-04-24 23:29:45Z”,“trace_id”:“c89030f5-7596-4716-b56b-baafdc670100”,“correlation_id”:“3c6c0d5a-8928-47f9-8916-30fb1a369a8e”,“error_uri”:“https://login.microsoftonline.com/error?code=900144”}curl: (6) Could not resolve host:
                          curl: (6) Could not resolve host: application
                          ‘client_id’ is not recognized as an internal or external command,
                          operable program or batch file.
                          ‘scope’ is not recognized as an internal or external command,
                          ‘redirect_uri’ is not recognized as an internal or external command,
                          ‘client_secret’ is not recognized as an internal or external command,
                          • G Offline
                            geoffroff @wazzu
                            @wazzu Excellent worked a treat… ToDo didn’t like the link (List not Found) but when it returned to screen the list had the long ID. I amended the config file and worked like a charm… Thanks G
                            • T Offline
                              thobach @andyyy
                              @andyyy The call seems to be missing some parameters, please check the full command line from https://github.com/thobach/MMM-MicrosoftToDo/blob/master/README.MD, thanks!
                              • T Offline
                                thobach @zolabus
                                @zolabus It seems you faced the same issue as in https://github.com/thobach/MMM-MicrosoftToDo/issues/18. I updated the instructions in https://github.com/thobach/MMM-MicrosoftToDo/blob/master/README.MD#refresh-token-generation-refresh-token to be more Windows friendly, e.g. all in a single line and using double quotes. Could you please try it again with the updated instructions? Thanks!
                                  smoysauce
                                  @thobach: Do you have recommendations to get the due date to show? I have tried to add element.dueDateTime.dateTime in the MMM-MicrosoftToDo.js like I have in the past, but now the module won’t show with that that. And no matter how I try to format it with moment it still doesn’t like it. I tried it with the simple element.id to see if that would show and it does show the todo ID. Thoughts? I know I am missing something simple. Thanks!
                                  • lavolp3L Offline
                                    lavolp3 Module Developer @smoysauce
                                    @smoysauce if your element does not have a dueDateTime (null) this could lead to an error (cannot get property of undefined).
                                    Maybe something like this?
                                    if (element.dueDateTime) {
                                      var dueDate = moment(element.dueDateTime.dateTime).format("LL");
                                    How to troubleshoot modules
                                    MMM-soccer v2, MMM-AVStock
                                      smoysauce @lavolp3
                                      @lavolp3 Oh good call-out! I tried your example as well as a few other tweaks but it doesn’t seem to like it when I add that snippet in. I don’t know why it’s being so weird. I’ll keep toying around with it, but any other thoughts would be appreciated!
                                        smoysauce @lavolp3
                                        @lavolp3 said in Microsoft To-Do (wunderlist replacement?):
                                        var dueDate = moment(element.dueDateTime.dateTime).format(“LL”);
                                        So after some tinkering, I figured out that the node.js was not pulling in the due date so I removed the ‘select’ filter so the call URL has '/tasks?$top='
                                        After that, I was able to add moment(new Date(element.dueDateTime.dateTime)).format("ddd MMM DD") to the output string and got the date to show. But for the life of me, I cannot get the var or if statements to work. If I try to use either the module doesn’t load. I have tried them in all different spots and it just doesn’t like it.
                                        • lavolp3L Offline
                                          @smoysauce
                                          First, moment(new Date(element.dueDateTime.dateTime)).format("ddd MMM DD") is redundant. You don’t need the new Date part.
                                          moment(element.dueDateTime.dateTime).format("ddd MMM DD")should be enough.
                                          Second, where have you put it?
                                          I had my own problems with the code, that’s why I’m working on an own version including due dates, but it’s not finished.
                                          Here’s how I would try to include it.
                                          if (this.list.length !== 0) {
                                                this.list.forEach(element => (listItemsText += '<li style="list-style-position:inside; white-space: nowrap; overflow: hidden; text-overflow: ellipsis;">' + checkbox + element.subject + ((element.dueDate) ? moment(element.dueDateTime.dateTime).format("ddd MMM DD") : '') + '</li>'))
                                              } else {
                                                // otherwise indicate that there are no list entries
                                                listItemsText += '<li style="list-style-position:inside; white-space: nowrap; overflow: hidden; text-overflow: ellipsis;">' + this.translate('NO_ENTRIES') + '</li>'
                                            smoysauce @lavolp3
                                            this.list.forEach(element => (listItemsText += ‘
                                          • ’ + checkbox + element.subject + ((element.dueDate) ? moment(element.dueDateTime.dateTime).format(“ddd MMM DD”) : ‘’) + ‘
                                            } else {
                                            listItemsText += ‘
                                          • ’ + this.translate(‘NO_ENTRIES’) + ‘
                                            Thanks for pointing that out, I am still figuring things out and piecing things together and if they work I just stick with it! That snippet worked, I had to change the section element.dueDate to element.dueDateTime but other than that seems to be doing the trick. I’ll probably toy around with it a bit more to see if I can learn formatting it with CSS to left align the subject and right align the date. Thanks for the help and tips!
                                            • 2 / 3
