    MMM-AlarmClock
    alarm clock
    29 Posts 9 Posters 20.9k Views 10 Watching
    • strawberry 3.141S Offline
      Based on a request from @cowboysdude I created this alarm clock a month ago
      It works for touch and non touch mirrors
      alt text
      alt text
      [card:fewieden/MMM-AlarmClock]
      • cowboysdudeC Offline
        cowboysdude Module Developer
        AND it IS awesome!!! HUGE Thanks @strawberry-3-141 !!!
          Changelog:
          • alarm sound can now be a http/s stream (thanks to mjtice)
          • fixed german tanslation file
          N 1 Reply Last reply Reply Quote 1
          • O Offline
            omega
            hi. please can you help me .
            How to execute script test.sh wen alarme activet ?
            NM.
              strawberry 3.141 Project Sponsor Module Developer @omega
              @omega this is currently not supported
              • O Offline
                omega
                I lose I need urgent. ok tnks strawberry 3.141
                • G Offline
                  gable74
                  Hello and thank you for the Module. I am trying to learn to add modules to my MM and could use some help please. I have cloned the folders in to my /modules/default directory as well as modified my config.js file but the alarm object is still not showing on the mirror. Here is my config.js file if someone could see if I have done something wrong. Thanks.
                  		module: "alert",
                  		module: "updatenotification",
                  		position: "top_bar"
                  		module: "clock",
                  		position: "top_left"
                  		header: "US Holidays",
                  					symbol: "calendar-check-o ",
                  					url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                  		module: "compliments",
                  		position: "lower_third"
                  		module: "currentweather",
                  			locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                  			appid: "YOUR_OPENWEATHER_API_KEY"
                  		module: "weatherforecast",
                  		header: "Weather Forecast",
                  			locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                      		module: 'MMM-AlarmClock',
                      		position: 'top_right',
                          			alarms: [
                              		{time: "18:30", days: [2,4], title: "Soccer", message: "Get ready for soccer training!"},
                  		module: "newsfeed",
                  		position: "bottom_bar",
                  			feeds: [
                  					title: "New York Times",
                  			showSourceTitle: true,
                  			showPublishDate: true
                  if (typeof module !== “undefined”) {module.exports = config;}
                    strawberry 3.141 Project Sponsor Module Developer @gable74
                    @gable74 it has to be cloned in modules not modules/default
                    • G Offline
                      gable74
                      Thank you. Sorry for the noob errors, I am trying…lol. To sound even more stupid, I also figured out you need to remove the “-Master” from the folder name as well. At least I figured that out on my own…LOL.
                      “MMM-AlarmClock”…not “MMM-AlarmClock-Master” :)
                        @gable74 thats because you downloaded it manually
                          v1.1.0 Changelog
                          • Volume fade in (see config options fade, fadeTimer and fadeStep). (thanks to @mjtice)
                          • French translations (thanks to Plosxh)
                          • Indonesian translations (thanks to @slametps)
                          • N Offline
                            nobita @strawberry 3.141
                            @strawberry-3.141 , Because I adjust so big font display (in css of alert module) but the border around display alarm font not expand (It’s fix), I would like to know how to expand border?
                            Thanks for all help
                              strawberry 3.141 Project Sponsor Module Developer @nobita
                              @nobita the .ns-alert class makes use of a fixed with of 40% so you have to change the value of this class in the custom.css
                              • N Offline
                                @strawberry-3.141 OK,IT work Thanks for your hint
                                • axellejamousA Offline
                                  axellejamous
                                  Thank you so much for this module, it’s amazing and really easy to use!
                                  I was wondering however, if I would want to let’s say set the alarm through some buttons attached to my pi, would it be best to try and inject lines into the config file (which seems sloppy to me) or can I set it through the js file directly? Or do I just make a second setnextalarm function?
                                    strawberry 3.141 Project Sponsor Module Developer @axellejamous
                                    @axellejamous you cannot do that via the config. I suggest you to create a module which is handling your buttons and sending a SET_ALARM notification. Then you need to enhance the alarm module by listening to that notification and set the alarm accordingly.
                                    axellejamousA 1 Reply Last reply Reply Quote 1
                                      axellejamous @strawberry 3.141
                                      @strawberry-3.141 I understand, that’s actually really useful thank you! Can I pass parameters with a socketnotification?
                                        @axellejamous yes additional data gets passed in the payload, see documentation https://github.com/MichMich/MagicMirror/blob/master/modules/README.md#thissendnotificationnotification-payload
                                          I refactored the module and switched to nunjuck templates.
                                          I’m looking for people who are willing to test it:
                                          • combinations of config options
                                          • new config option popup
                                          how to test:
                                          • if not already done, clone the repository to your modules cd ~/MagicMirror/modules/ && git clone https://github.com/fewieden/MMM-AlarmClock.git
                                          • go to the module cd ~/MagicMirror/modules/MMM-AlarmClock
                                          • run git checkout develop
                                          • test various config options
                                          • N Offline
                                            @fewieden
                                            If I would like to add repeat time again like as
                                            1st alarm alert at 8:00 am
                                            2nd alarm alert at 12:00 pm
                                            3rd alarm alart at 5:00 pm
                                            How can i config
