    Mirror and bright conditions
    mirrorlight
    4 Posts 2 Posters 2.8k Views 1 Watching
    • AzraelA
      Azrael
      Hello all,
      Today I finished building my first MM (soon I will post pictures with description in the appropriate section). However, what I found is that in the bright conditions the content is not very well visible. Display settings are maximum brightness and maximum contrast. I have standard 23" ASUS computer display I bought for about 100€.
      My question is what do you think would be the best way to tackle it? I have a glass semi-transparent mirror. Unfortunately a glazier couldn’t tell me the parameters of glass (but at least it was cheap - 25€). What I see is the mirror is maximum 30% transparent and a bit brownish. Should I change a mirror glass to something different - maybe acrilic?
      If I change mirror to more transparent are there any drawbacks?
      Thank you for the suggestions.
      • B
        broberg Project Sponsor
        You need a mirror with a higher lighttransmission. The drawback is that more of the monitors backlight will show when it gets darker in the room.
        30% is a really high number for lighttransmission (I have 3% and that is as you describe hard to see when in a light room). 12-20% will work well in normal lighting conditions.
        • AzraelA
          Azrael
          Thank you for the answer. I tried to ask couple of glaziers about lighttransmission but none could tell me what percentage that is (I don’t know how to measure it). Have you bought your mirror at a normal glazier? I will try to find some company that can sell me 12-20% lighttransmission mirror.
          Monitor backlight is also something I was thinking that may be a problem.
          • B
            broberg Project Sponsor @Azrael
            @azrael yes, from a regular glass shop, Ask for manufacturer and product name, that way you can google the specs yourself. (Thats what I did)
