    MMM-Hotword
    60 Posts 20 Posters 34.8k Views 17 Watching
    • Cr4z33C Offline
      Cr4z33
      This post is deleted!
        Manfred
        Can’t figure out why hotword detection stops on the 2nd run.
        First detection is ok and GA responds as expected. I am a bit lost - any help is much appreciated
        MagicMirror: 2.5.0
        NodeJS: 9.11.2
        npm: 6.4.1
        MMM-AssistantMk2: 2.1.0
        I am using the full detailled config from MMM-AssistantMk2
        • ? Offline
          [[global:former-user]] @Manfred
          @manfred
          You might missed this in your MMM-AssistantMk2 configuration
          notifications: {
          ASSISTANT_ACTIVATED: “HOTWORD_PAUSE”,
          ASSISTANT_DEACTIVATED: “HOTWORD_RESUME”,
          Or MMM-Hotword is not updated yet.
            Manfred @Guest
            @sean Thank you very much!! That did the trick!
              s.monti.74
              Hi , I can’t really use this module. I Have also done a minimal config.js with only this module but the mirror starts black (totally) and I have to reboot the RaspPi (I can’t close the Mirror)
              What can I check ?
              I have done correctly the installation of the module
              Please help me
              thanks from Italy
              • ? Offline
                [[global:former-user]] @s.monti.74
                @s-monti-74
                I need an error log to examine. I doubt you missed electron-rebuild step on installation.
                  s.monti.74 @Guest
                  @sean please telle me which log I have to activate and how, thanks
                    s.monti.74
                    OH, I missed electron-rebuild . thanks
                    I try…
                    • C Offline
                      cjdzombie
                      I’m trying to install Hotword to work with the Assistant Module. I’m stuck at the install because I keep getting an error with Snowboy. What is the issue here. I’m new to this type of codind and would appreciate some help. Here are the errors.
                      pi@raspberrypi:~ $ cd ~/MagicMirror/modules/
                      pi@raspberrypi:~/MagicMirror/modules $ sudo apt-get install libmagic-dev libatlas-base-dev sox libsox-fmt-all
                      Reading package lists... Done
                      Building dependency tree
                      Reading state information... Done
                      libatlas-base-dev is already the newest version (3.10.3-1+rpi1).
                      libmagic-dev is already the newest version (1:5.30-1+deb9u2).
                      libsox-fmt-all is already the newest version (14.4.1-5).
                      sox is already the newest version (14.4.1-5).
                      The following packages were automatically installed and are no longer required:
                        erlang-base erlang-crypto erlang-syntax-tools fonts-lato
                        libboost-thread1.62.0 libc-ares2 libhttp-parser2.8 libqt5opengl5
                        libqt5scintilla2-12v5 libqt5scintilla2-l10n libqwt-qt5-6 libruby2.3
                        libscsynth1 libsctp1 libuv1 libyaml-0-2 nodejs-doc rake realpath ruby
                        ruby-did-you-mean ruby-minitest ruby-net-telnet ruby-power-assert
                        ruby-test-unit ruby2.3 rubygems-integration
                      Use 'sudo apt autoremove' to remove them.
                      0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
                      pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/eouia/MMM-Hotword.git
                      Cloning into 'MMM-Hotword'...
                      remote: Enumerating objects: 3, done.
                      remote: Counting objects: 100% (3/3), done.
                      remote: Compressing objects: 100% (3/3), done.
                      remote: Total 116 (delta 0), reused 0 (delta 0), pack-reused 113
                      Receiving objects: 100% (116/116), 7.93 MiB | 4.19 MiB/s, done.
                      Resolving deltas: 100% (64/64), done.
                      pi@raspberrypi:~/MagicMirror/modules $ cd MMM-Hotword
                      pi@raspberrypi:~/MagicMirror/modules/MMM-Hotword $ npm install
                      npm WARN deprecated boom@2.10.1: This version is no longer maintained. Please upgrade to the latest version.
                      npm WARN deprecated hoek@2.16.3: This version is no longer maintained. Please upgrade to the latest version.
                      npm WARN deprecated cryptiles@2.0.5: This version is no longer maintained. Please upgrade to the latest version.
                      > snowboy@1.3.1 install /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                      > node-pre-gyp install --fallback-to-build
                      node-pre-gyp ERR! Tried to download(403): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v67-linux-arm.tar.gz
                      node-pre-gyp ERR! Pre-built binaries not found for snowboy@1.3.1 and node@11.8.0 (node-v67 ABI, glibc) (falling back to source compile with node-gyp)
                      node-pre-gyp ERR! Tried to download(undefined): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v67-linux-arm.tar.gz
                      internal/modules/cjs/loader.js:613
                          throw err;
                      Error: Cannot find module 'nan'
                          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:611:15)
                          at Function.Module._load (internal/modules/cjs/loader.js:537:25)
                          at Module.require (internal/modules/cjs/loader.js:665:17)
                          at require (internal/modules/cjs/helpers.js:20:18)
                          at [eval]:1:1
                          at Script.runInThisContext (vm.js:123:20)
                          at Object.runInThisContext (vm.js:312:38)
                          at Object.<anonymous> ([eval]-wrapper:6:22)
                          at Module._compile (internal/modules/cjs/loader.js:736:30)
                          at evalScript (internal/process/execution.js:56:25)
                          throw err;
                          at [eval]:1:1
                      gyp: Call to 'node -e "require('nan')"' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
                      gypgyp  ERR!ERR!  configure error
                      configure error
                      gypgyp  ERR!ERR! stack  Error: `gyp` failed with exit code: 1
                      stackgyp Error: `gyp` failed with exit code: 1
                       ERR!gyp  stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
                      ERR!gyp  stackERR!      at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
                      stack     at ChildProcess.emit (events.js:197:13)
                      gypgyp  ERR!ERR!  stackstack     at Process.ChildProcess._handle.onexit (internal/child_process.js:254:12)
                      gyp ERR! stackgyp      at Process.ChildProcess._handle.onexit (internal/child_process.js:254:12)
                      ERR! System Linux 4.14.79-v7+
                      gypgyp  ERR! ERR!command  "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm/snowboy.node" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm"
                      gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                      gypgyp ERR!  node -vERR! v11.8.0
                       commandgyp  "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm/snowboy.node" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm"
                      ERR! node-gyp -v v3.8.0
                      gyp gyp ERR!ERR!  not okcwd
                      gyp ERR! node -v v11.8.0
                      gyp ERR! node-gyp -v v3.8.0
                      gyp ERR! not ok
                      node-pre-gyp ERR! build error
                      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm/snowboy.node --module_name=snowboy --module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v67-linux-arm' (1)
                      node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:197:13)
                      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:978:16)
                      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:265:5)
                      node-pre-gyp ERR! System Linux 4.14.79-v7+
                      node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                      node-pre-gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                      node-pre-gyp ERR! node -v v11.8.0
                      node-pre-gyp ERR! node-pre-gyp -v v0.6.39
                      node-pre-gyp ERR! not ok
                      npm WARN MMM-Hotword@1.1.0 No repository field.
                      npm ERR! code ELIFECYCLE
                      npm ERR! errno 1
                      npm ERR! snowboy@1.3.1 install: `node-pre-gyp install --fallback-to-build`
                      npm ERR! Exit status 1
                      npm ERR!
                      npm ERR! Failed at the snowboy@1.3.1 install script.
                      npm ERR!     /home/pi/.npm/_logs/2019-01-29T21_16_15_265Z-debug.log
                      • ? Offline
                        [[global:former-user]] @cjdzombie
                        @cjdzombie
                        ‘npm install nan’ then do ‘npm install’ again
                        • C Offline
                          cjdzombie @Guest
                          @sean said in MMM-Hotword:
                          npm install
                          Thanks for your reply. I ran the suggested commands.
                          pi@raspberrypi:~/MagicMirror/modules/MMM-Hotword $ npm install nan
                          and then
                          Unfortunately I got the same result. It seems that Snowboy is the issue. It just wont install in the process. When I try the next command in the process I get this result.
                          cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                          I get the reply
                          pi@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                          bash: cd: /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy: No such file or directory
                          I’ve been at this since last weekend. It’s fun , but frustrating. Any other help would be awesome.
                          Thanks!
                          ? S 3 Replies Last reply Reply Quote 0
                          • ? Offline
                            @cjdzombie
                            and then
                            Same result? Your prior issue Error: Cannot find module 'nan' should be solved by npm install nan. If not so, that is an issue of another level. It means your npm is not valid. So check again same result.
                            • ? Offline
                              @cjdzombie
                              You can contact me with mail : eouia0819@gmail.com or Telegram: @eouia for the details.
                              • C Offline
                                costascontis
                                @Sean i nicely use assistantmk2 with Hotword and i noticed that if i trigger assistant with hotword and for some reason get “conversation error” then hotword stops triggering but assistant works fine if i press the icon with the mouse.I have to restart MM to get hotword working again.Its not happening all the time but 1 maybe 2 times in the day.Any advice?
                                • ? Offline
                                  [[global:former-user]] @costascontis
                                  @costascontis
                                  I need error logs and configurations for details.
                                    sdetweil @cjdzombie
                                    @cjdzombie i just installed MMM-Hotword, and had the errors documented in the install.
                                    I followed the steps exactly, cutting and pasting, and those issues were resolved… MMM-Hotword works perfectly now
                                      Artech
                                      @Sean at first thank you for your module however I have some difficulties in installing the snowboy library if you or someone else has a procedure I will follow it
                                        berne
                                        mmm i notis i have a update, how do i get it?
                                        • ? Offline
                                          [[global:former-user]] @berne
                                          @berne If you have no issue on your usage, you don’t need to update. Nothing important is not updated.
                                            berne
                                            @Sean
                                            running MM v2.8.0
                                            dont running 2.0 on this
                                            ? B 2 Replies Last reply Reply Quote 0
                                            • 2 / 3
