    MMM-AssistantMk2
    421 Posts 61 Posters 634.3k Views 57 Watching
    • ? Offline
      A Former User @citizendevpi
      @citizendevpi
      More details are needed for detail answer.
      you can set record.verbose: true for checking your mic works properly. But before that, you should confirm there was any other error to issue. Check your error log.
      citizendevpiC 1 Reply Last reply Reply Quote 0
      • citizendevpiC Offline
        citizendevpi @Guest
        @sean arecord: main:788: audio open error: Device or resource busy and where is my error log?
        ? 2 Replies Last reply Reply Quote 0
        • ? Offline
          @citizendevpi
          Your system seems not properly configured to use audio device. that might be not the issue of module itself.
          And you can see the log with
          pm2 log mm #or your registered process name for MagicMirror
          or
          stop pm2 then npm start dev in your MM directory.
          • ? Offline
            @citizendevpi
            Anyway,
            You should confirm to check your audio device card and name, and your RPI should be able to run below commands (or similar)
            arecord -d 5 test.wav
            or
            arecord --device plughw:1,0 -d 5  test.wav
            (plughw:1,0 might be different. You should find your proper device card and number with arecord -l)
              citizendevpi
              @sean said in MMM-AssistantMk2 & MMM-GAction:
              ? citizendevpiC 2 Replies Last reply Reply Quote 0
              • ? Offline
                @citizendevpi said in MMM-AssistantMk2 & MMM-GAction:
                That works? If so, you can set your config record.device: "plughw:1,0",
                  citizendevpi @citizendevpi
                  @citizendevpi pi@raspberrypi:~ $ arecord -d 5 test.wav
                  Recording WAVE ‘test.wav’ : Unsigned 8 bit, Rate 8000 Hz, Mono
                  pi@raspberrypi:~ $ arecord -l)
                  bash: syntax error near unexpected token )' pi@raspberrypi:~ $ arecord -1 arecord: invalid option -- '1' Try arecord --help’ for more information.
                  pi@raspberrypi:~ $ arecord --device plughw:1,0 -d 5 test.wav
                  ALSA lib pcm_hw.c:1713:(_snd_pcm_hw_open) Invalid value for card
                  arecord: main:788: audio open error: No such file or directory
                  • ? Offline
                    @citizendevpi
                    Ok. forget my previous answer.
                    arecord -l
                    It’s l (small L), not 1 (one)
                      citizendevpi @Guest
                      @sean **** List of CAPTURE Hardware Devices ****
                      card 0: sndrpigooglevoi [snd_rpi_googlevoicehat_soundcar], device 0: Google voiceHAT SoundCard HiFi voicehat-hifi-0 []
                      Subdevices: 0/1
                      Subdevice #0: subdevice #0
                      • ? Offline
                        @citizendevpi
                        Your recording device is plughw:0,0. or default. Remember it.
                        Then try this.
                        arecord -d 10 test.wav
                        Say something. It will be record your voice to test.wav on 10 secs.
                        Works?
                        If so, then,
                        aplay test.wav
                        It should play previous recording from arecord. Can you hear anything?
                          citizendevpi @Guest
                          @sean yes barley
                          but yes
                          • ? Offline
                            @citizendevpi
                            Your Mic and Speaker are both the default. So, Now, show your config to me.
                              citizendevpi @Guest
                              This post is deleted!
                              • ? Offline
                                A Former User
                                UPDATE
                                2.1.0 demo
                                [2.1.0] - 2018.11.14
                                • Customizable command feature is added. Now you can control your device and MM without other module’s help.
                                  And notification system of transcriptionHook is changed. New configuration is needed.
                                • Prepared hook commands. Say these (Or customize them in configuration)
                                  • hide all : modules on screen will be hidden
                                  • show all : hidden modules will be shown again
                                  • reboot yourself : reboot device
                                  • shutdown yourself : shutdown device
                                  • go to sleep : LCD power off (you might need to modify /scripts/screenoff.sh)
                                  • wake up : LCD power on (you might need to modify /scripts/screenon.sh)
                                • onIdle feature be added. After timer without no query after last query, command will be activated. (By default, after 30min All modules will be hidden.)
                                • And onActivate feature is added. When you activate Assistant, this command will be executed after timer. (By default, modules hidden by onIdle will be shown again)
                                • For update from 2.0.0
                                cd ~/MagicMirror/modules/MMM-AssistantMk2
                                git pull
                                • Cr4z33C Offline
                                  Cr4z33 @Guest
                                  @sean thanks for the update, but what are those fireworks?
                                  Nothing to do with your module or? :grinning_face:
                                  • ? Offline
                                    A Former User @Cr4z33
                                    @cr4z33 I wanted someone to ask about Fireworks. :D. I’m making that module for my X-mas eyecandy.
                                    But unfortunately, on RPI the speed is crazy slow. I’m doing optimization, but hard. :D. If I get a success, I’ll release.
                                    • Cr4z33C Offline
                                      Cr4z33 @Guest
                                      @sean lol alright although I personally wouldn’t use it. :grinning_face_with_smiling_eyes:
                                      • T Offline
                                        teitlebot
                                        @Sean
                                        Thanks for the update. I have two small issues after update.
                                        For some weird reason most of my modules go blank after some time and only turn back on after I trigger assistant with voice.
                                        Also the feedback window only shows up at the bottom if the speaker icon is top right of screen but if I try moving icon the feedback window ends up being in very small areas of screen.
                                        I can post video if I’m not explaining well.
                                        • ? Offline
                                          A Former User @teitlebot
                                          @teitlebot
                                          • onIdle feature be added. After “timer” is passed without no query from last query, command will be activated. (By default, after 30min All modules will be hidden.)
                                            => set configuration like this.
                                          onIdle: {
                                          timer: 0, // if you don’t want to use this feature, just set timer as 0 or command as “”
                                          command: “”
                                          • ? Offline
                                            @teitlebot
                                            Second might be css adjustments needed. I don’t know your whole module and css structure, so currently can’t answer. Tomorrow I’ll test and reply to you.
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 21
                                            • 22
                                            • 9 / 22
