    MMM-WunderGround stuck at Loading
    4 Posts 2 Posters 2.0k Views 2 Watching
      Josephsuun
      Re: mMM-Wunderground
        Mykle1 Project Sponsor Module Developer @Josephsuun
        @josephsuun
        That’s an interesting way to post your request for help. You might want to describe what you’ve done so far and provide us with your config.js entry for the module, pasted into a code block.
          Josephsuun
          Oh I sorry, I Didn’t Know that this was posted. this is my first post on this forum and my first attempt at a magicmirror. For the last week, I have been trying to get the MMM-WunderGound module to load. I tried all the other remedy,but nothing work. The Magicmirror itself load ok, but wunderground get stuck at loading.
          I’d have type “cd ~/MagicMirror/modules/”
          then type “npm run config:check” the terminal returns “Your configuration file doesn’t contain syntax error :)” I’ll include a copy of the config.js file.```
          /* Magic Mirror Config Sample
          • By Michael Teeuw http://michaelteeuw.nl
          • MIT Licensed.
          • For more information how you can configurate this file
          • See https://github.com/MichMich/MagicMirror#configuration
          var config = {
          address: “localhost”, // Address to listen on, can be:
          // - “localhost”, “127.0.0.1”, “::1” to listen on loopback interface
          // - “”, “0.0.0.0”, “::” to listen on any interface
          // Default, when address config is left out, is “localhost”
          port: 8080,
          ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
          // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
          // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
          language: "en",
          timeFormat: 12,
          units: "imperial",
          	module: "alert",
          	module: "updatenotification",
          	position: "top_bar"
          	module: "clock",
          	position: "top_left"
          	header: "US Holidays",
          			symbol: "mycalendar-check-o ",
          			url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
          			symbol: "calendar-check-o ",
          			url: "https://calendar.goole.com/calendar/ical/josephsuun%40chartermi.net/public/basic.ics"
          	module: "calendar_monthly",
          				// The config property is optional
          				// Without a config, a default month view is shown
          				// Please see the 'Configuration Options' section for more information
          	module: "compliments",
          	position: "lower_third"
          	module: "currentweather",
          		locationID: "5007989",  //ID from http://www.openweathermap.org/help/city_list.txt
          		appid: ""
          	module: "weatherforecast",
          	header: "Weather Forecast",
          		appid: ""
                      module: "MMM-WunderGround",
                              apikey: "", // private; don't share!
                              pws: "pws:KTXGRAND18", //culembor
                              hourly: "1",
                              fctext: "1",
                              fcdaycount: "5",
                              fcdaystart: "0",
                              hourlyinterval: "3",
                              hourlycount: "2",
                              alerttime: 10000,
                              alerttruncatestring: "english:",
                          roundTmpDecs: 1,
                          UseCardinals: 0,
                          layout: "horizontal",
                          sysstat: 0
          	module: "newsfeed",
          	position: "bottom_bar",
          		feeds: [
          				title: "New York Times",
          		showSourceTitle: true,
          		showPublishDate: true
          if (typeof module !== “undefined”) {module.exports = config;}
          I hope this help you, help me. I really want MMM-WunderGround to work.
            @josephsuun said in MMM-WunderGround stuck at Loading:
            I took your entry for Wunderground and tested it with my API key. It fired right up.
            Can I ask when you got your API key? There is an issue now with Wunderground. Older API keys still seem to work but the newer ones (before they stopped issuing) don’t.
