    MMM-GooglePhotos
    294 Posts 56 Posters 383.2k Views 59 Watching
    • Alex2020A Offline
      Alex2020
      Mi è comparsa una scritta sul Mirror che è disponibile un aggiornamento del modulo MMM-GooglePhoto come si fa l’aggiornamento?Grazie.
        sdetweil @Alex2020
        @Alex2020 vai alla cartella del modulo nella finestra del terminale ed emetti, git pull. se il modulo ha un file package.json, eseguire anche ‘npm install’
        • Alex2020A Offline
          Alex2020
          Salve mi compare un messaggio sul Mirror che ce una versione più recente come si aggiorna il modulo MMM-GooglePhotos ,come si fa l’aggiornamento?Grazie.
            Samwise
            my auth_and_test is not working. it worked like a year ago, but I haven’t used it since. I’m really new and don’t really know what I’m doing. this is what i get:
            pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ node auth_and_test.js
            (node:698) UnhandledPromiseRejectionWarning: Error: invalid_grant
            at createError (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/core/createError.js:16:15)
            at settle (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/core/settle.js:18:12)
            at IncomingMessage.handleStreamEnd (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/adapters/http.js:201:11)
            at IncomingMessage.emit (events.js:198:15)
            at endReadableNT (_stream_readable.js:1139:12)
            at processTicksAndRejections (internal/process/task_queues.js:81:17)
            (node:698) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
            (node:698) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
            Any suggestions?
            S ? 2 Replies Last reply Reply Quote 0
              sdetweil @Samwise
              @Samwise usually means the authentication code has expired.
              • ? Offline
                [[global:former-user]] @Samwise
                @Samwise
                remove your current token.json and try again.
                • L Offline
                  lucBtrl
                  Dear Sean,
                  It seems the node auth_and_test.js command throws an error on my side :
                  /home/pi/MagicMirror/modules/MMM-GooglePhotos/auth.js:32
                    const oauthClient = new OAuth2Client(key.client_id, key.client_secret, key.redirect_uris[0]);
                  TypeError: Cannot read property 'client_id' of undefined
                      at new Auth (/home/pi/MagicMirror/modules/MMM-GooglePhotos/auth.js:32:44)
                      at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-GooglePhotos/auth_and_test.js:16:14)
                      at Module._compile (internal/modules/cjs/loader.js:778:30)
                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                      at Module.load (internal/modules/cjs/loader.js:653:32)
                      at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                      at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                      at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                      at startup (internal/bootstrap/node.js:283:19)
                      at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                  It seems it cannot read my client_id from credentials.json file… do you have an idea ?
                  Thanks a lot for your help !
                  • ? Offline
                    [[global:former-user]] @lucBtrl
                    @lucBtrl first, remove your credentials and create it again.
                      Samwise
                      ok, so it worked, but then when i tried to set which album i wanted, it said this:
                      pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ nano MMM-GooglePhotos.js
                      nano: error while loading shared libraries: libncursesw.so.5: cannot open shared object file: No such file or directory
                      • ? Offline
                        @Samwise
                        I can’t understand why you did this;
                        You don’t need to (and shouldn’t) modify source code. use your config/config.js.
                        And, the error
                        comes from your system, not my module. Maybe your system has been missing something.
                          Samwise
                          ok i think everything is in order, but the pictures don’t actually show up…
                          • ? Offline
                            @Samwise
                            Don’t know what happens without details. What does the log say?
                              Samwise @Guest
                              @Sean where do i find the log?
                              Also, this popped up: pi@raspberrypi:~/MagicMirror $ npm start
                              magicmirror@2.7.1 start /home/pi/MagicMirror
                              sh run-start.sh
                              /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgconf-2.so.4: cannot open shared object file: No such file or directory
                              npm ERR! file sh
                              npm ERR! code ELIFECYCLE
                              npm ERR! errno ENOENT
                              npm ERR! syscall spawn
                              npm ERR! magicmirror@2.7.1 start: sh run-start.sh
                              npm ERR! spawn ENOENT
                              npm ERR!
                              npm ERR! Failed at the magicmirror@2.7.1 start script.
                              npm ERR! /home/pi/.npm/_logs/2020-02-29T10_46_17_131Z-debug.log
                              • L Offline
                                lucBtrl @Guest
                                @Sean
                                Thanks a lot Sean !
                                It appears indeed that the credentials generated was not the right type (I may have not selected the right option in google api console). Worked better the second time !
                                Marvelous results of the module
                                  ayangu
                                  @Sean I logged into my google account and allowed consent. However, once I input the code back into the terminal, all I get is auth_and_test started.
                                  What am I doing wrong?
                                  • ? Offline
                                    [[global:former-user]] @ayangu
                                    @ayangu
                                    when you did auth_and_test, token.json was created?
                                    • ? Offline
                                      New Updates
                                      [2.0.0] - 2020/03/23
                                      • Notice: Whole new build from scratch. new installation and configuration is needed.
                                      • Removed: deprecated dependency request. Instead, using Axios and https
                                      • Changed: More stable displaying photos
                                      • Changed: New looks.
                                      • Changed: Access album by name not by id.
                                      • Added: You can filter photos by condition.
                                      • Added: GPHOTO_NEXT, GPHOTO_PREVIOUS notifications are supported.
                                      • Added: GPHOTO_UPLOAD notification is supported. Now MMM-Selfieshot and MMM-TelegramBot can upload pictures with this module.
                                      • Removed: mode, scanInterval, opacity is removed because no more necessary.
                                      Screenshot
                                      G 1 Reply Last reply Reply Quote 1
                                        roccodicarlo
                                        I am running MM on a RP zero W and I only have the RPi command line. It is running in server mode. When I execute node generate_token.js, it does not bring up a browser window where I can authorize for a token. Do I need to do something different?
                                          sdetweil @roccodicarlo
                                          @roccodicarlo open the chromium-browser to localhost:8080 to get the UI (if this is a graphical desktop pi 0)
                                          when/how did u install? my automated script does the setup to run chromium if the graphical desktop exists
                                            roccodicarlo
                                            No this is not the graphical desktop, it is all CLI.
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 14
                                            • 15
                                            • 9 / 15
