    My first module
    10 Posts 2 Posters 6.7k Views 2 Watching
    • G Offline
      gismo2006
      Hi guys,
      I like to write my first modul. Its a fun modul and didn’t have a reason for anyone. I like to learn to write a module. So I can leaerning a lot I think.
      I have create a folder in modules. Called Sounds I have put it into the config file andy the Mirror stats correctly Juhuuuu! :-) First step reached. :-D But now the Problem… Th module didn’t work. For a first test the only think the modul should do is react on a Message which is send by the Voicecontrolmodul by @alexyak. I have creste for this test a new Hotword calles test. I copy the pmdl file and paste the rigt things into my config file. So far, so good. I think the Problem was the Sounds.js file in my own modul folder Sounds. OHH, before I forget. The Sounds.sh skript is only a shell script and worked fine too. I habe write chmod +x Sounds.sh to create a runable file.
      Here the code, maybe someone can look a this and whre my misstake is :-)
      /* global Module */
      /* Magic Mirror
      • Module: HelloWorld
      • By Michael Teeuw http://michaelteeuw.nl
      • MIT Licensed.
      Module.register(“Sounds”,{
      notificationReceived: function(notification, payload, sender) {
          if (notification === "test"){
              exec("sudo /home/pi/MagicMirror/modules/Sounds/Sounds.sh")
      // Override dom generator.
      getDom: function() {
      	wrapper.innerHTML = this.config.text;
      	return wrapper;
      greets gismo
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @gismo2006
        @gismo2006 you’re missing a { and , (instead of semicolon)
                exec("sudo /home/pi/MagicMirror/modules/Sounds/Sounds.sh");
        • G Offline
          gismo2006
          @strawberry-3-141 Thank you for your help. but it didn’t change anything. The problem is the same. Everythink started fine but they didn’t play the Sounds.sh…
            @gismo2006 try to debug where you’re module is getting stuck like this
                    Log.info("test notification received");
            if you don’t see this message in the dev console you propably misconfigured your voice command
            • G Offline
              gismo2006
              Ok I will do what you say.
              Ok I have done
              I have found the Problem. the dev consoles says
              Sounds.js:15 Uncaught ReferenceError: exec is not defined.
              Can i delete the word exec? But I think I have to use it to run the script, right?
              greets gismo
                @gismo2006 yeah you have to create a node_helper to run the script and send a socketnotification t the node_helper and there you can run the script
                • G Offline
                  gismo2006
                  Ok, Thank you for your help. I will try myself to go this next step…
                  strawberry 3.141S 1 Reply Last reply Reply Quote 1
                    @gismo2006 https://github.com/fewieden/MMM-voice/blob/f9eb4cd4bde5c64ef894e8625250c4092aa0d4a7/node_helper.js
                    line 10, 23-31, 213 will help you
                    • G Offline
                      gismo2006
                      Thank you I have looked in the notification Node_helper.js code which was posted in the Voicecontrol post from @tyho. And it works now fine. Now I can learning something new. To grow up my modul and finding a really reason for my module :-D
                      But I like to say Thank you. You helped me a lot. :-)
                      greets gismo
                        @gismo2006 no worries, if you come up with more questions don’t hesitate to ask
