    Wrong font in newsfeed
    10 Posts 6 Posters 3.3k Views 5 Watching
    • MarosM Offline
      Maros
      Hi all,
      i’ve added some modules to my MM and i see that there is some problem with fonts as you can see some characters have different font. (most visible in newsfeed)
      i’ve edited custom.css and added this lines :
      body {
      @font-face {
      font-family: “Verdana”;
      font-style: normal;
      font-weight: 100;
      src:
      local(“Verdana”),
      url(“/fonts/Verdana.ttf”) format(“truetype”);
      .newsfeed {
      font-family: Verdana;
      i’ve downloaded font Verdana.ttf and copied to MagicMirror/fonts folder
      but it’s not working font is still not ok
      Can you please help me how to solve this problem ?
      • MarosM Offline
        Maros
        i’ve tried also woff font Verdana.woff as mentioned here :
        https://forum.magicmirror.builders/topic/4824/i-need-help-to-change-the-fonts/3
        but it’s also not working at all :(
        • MarosM Offline
          Maros
          Noone any idea?
            davidnesbitt7
            Open up your console in dev tools and see if you’re getting any errors
            Do. Or do not. There is no try
            • brobergB Offline
              broberg Project Sponsor @davidnesbitt7
              Folder path is misdirected, try this
              body {
              @font-face {
              font-style: normal;
              font-weight: 100;
              src:
              local(“Verdana”),
              url("../fonts/Verdana.ttf") format(“truetype”);
              .newsfeed {
              • MarosM Offline
                Maros
                @broberg said in Wrong font in newsfeed:
                @font-face {
                font-style: normal;
                font-weight: 100;
                src:
                local(“Verdana”),
                url(“…/fonts/Verdana.ttf”) format(“truetype”);
                .newsfeed {
                i’ve tried but still same
                @davidnesbitt7 i’ve checked error log on pm2 but there nothing mentioned about rss feed font error
                • C Offline
                  cabott
                  @maros Did you fix this issue? I’ve encountered the same with Polish news…
                  edit:
                  solved by installing Roboto fonts into Raspbian (found somewhere here at the forum or in the Internet).
                    radokristof @cabott
                    @cabott I have the same problems. Some characters are not showing properly only on the newsfeed module.
                    I have tried installing roboto fonts with apt, how did you installed it? (And which package).
                    • C Offline
                      cabott @radokristof
                      @radokristof sorry for late answer, I completely missed this topic. For those who still had this issue:
                      I just installed the fonts with
                      sudo apt-get update
                      sudo apt-get install fonts-roboto
                      then
                      fc-cache -fv
                      pm2 restart MagicMirror
                      and voila… works for me.
                      • F Offline
                        Fifin404
                        Work for me. Thank you
