    LG FLatron 2242PE check signal cable PIR Sensor
    pirsensor
    3 Posts 3 Posters 2.1k Views 2 Watching
      Justinvd0203
      I had a small “problem”, i got the PIR motion sensor to work, when there is no motion the signal to the monitor gets closed. However when this happens my monitor shows the message: Check signal cable. Is there a way to turn this off or is there a work-around?
      • MarosM Offline
        Maros
        Monitor should get to sleep if there is no signal … this should be configurable somewhere in monitor menu / configuration (try buttons on monitor to set it up)
          AxLed Module Developer
          @Justinvd0203
          I had a similar problem with my LG Monitor and PIR-Sensor.
          In my case i had the following behavior:
          • Using HDMI Connection: switching off was possible, wake up not
          • Using VGA Connection (with HDMI->VGA adapter on RPI side): switching off an wake up was possible
          Details see post.
          No worry using HDMI->VGA adapter: VGA can also deliver FullHD Resolution.
          Maybe your problem could be solved with an adapter.
          AxLED
