    Quick Syntax Error
    20 Posts 5 Posters 5.2k Views 5 Watching
      smartsoldier @Guest
      @sean If I remove this module everything runs fine, then if I put it back this happens. Does that mean its this module or no?
      • evroomE Offline
        evroom
        Are you willing to share the syntax error with us?
        I thought you were referring to the “create config file” message at startup.
        MagicMirror version: 2.33.0
        Test environment:
        MagicMirror version: v2.33.0
        • ? Offline
          A Former User @smartsoldier
          @smartsoldier Of course, it could be the fails of that module configuration.
            smartsoldier
            This post is deleted!
            • ? Offline
              @smartsoldier
              No error at all. I didn’t modify anything.
                smartsoldier
                Well I guess that settles that. I’ll just do a reinstall. Thanks for all the help though. You responded really quickly :)
                • evroomE Offline
                  evroom
                  @smartsoldier Please edit the post with the config.js and remove your private api keys, like apiKey and dropboxAccessToken.
                  Test environment:
                  • evroomE Offline
                    evroom
                    @smartsoldier
                    I personally would not do a complete re-install, but I would re-install the modules according to their instructions.
                    Those modules would be:
                    MMM-DropboxWallpaper
                    MMM-forecast-io
                    MMM-DailyBibleVerse
                    In that order.
                    Btw, are all modules under the MagicMirror/modules directory ?
                    You yourself proofed that most stuff works.
                    @Sean proofed that your config is okay.
                    Btw, a simple ‘trick’ to disable a module is to put
                    disabled: true,
                    under the module name
                    and
                    disabled: false,
                    to enable it again.
                    Disabled:
                    module: 'MMM-DropboxWallpaper',
                    disabled: true,
                    Enabled:
                    disabled: false,
                    This gives you a faster way of excluding ‘wrong’ modules.
                    Or simply to test a module, whilst leaving the config when the module is not needed.
                    Test environment:
                      sdetweil @smartsoldier
                      @smartsoldier cut and paste your code in the www.jslint.com
                      check single quotes, spaces
                      and test it… you should find your error quickly
                      fix, and cut/paste the results back into the config.js
                      • justjim1220J Offline
                        justjim1220 Module Developer @smartsoldier
                        @smartsoldier
                        Did you try to remove the comma as I suggested?
                        Those give me fits everytime… no errors. black screen
                        Jim Hallock - 1995
