    Quick Syntax Error
    20 Posts 5 Posters 6.0k Views 5 Watching
      A Former User @smartsoldier
      @smartsoldier I’ve copied from your post and nothing changed except some private values(tokens)
        @smartsoldier
        Most of the syntax errors could be raised by missing or exceeding bracket, comma.
        I suggest you remove configuration of modules one-by-one and try.
        Or you should upload a complete config.js here.
        • evroomE Offline
          evroom
          I also do not get an error when copy/pasting your config lines.
          $ npm run config:check
          does not give an error.
          You should try it yourself; a very useful command.
          Perhaps the error does not apply to the MMM-DropboxWallpaper config ?
          MagicMirror version: 2.37.0
            smartsoldier
            Ok well I used npm run config:check and it found no errors, but I still get the syntax error message is red when I start up the MM. What is happening!??!
              @smartsoldier We don’t know. Remove all the modules in config.js and add one-by-one. Let’s see what happens.
                smartsoldier @Guest
                @sean If I remove this module everything runs fine, then if I put it back this happens. Does that mean its this module or no?
                • evroomE Offline
                  evroom
                  Are you willing to share the syntax error with us?
                  I thought you were referring to the “create config file” message at startup.
                    @smartsoldier Of course, it could be the fails of that module configuration.
                      smartsoldier
                        @smartsoldier
                        No error at all. I didn’t modify anything.
                          smartsoldier
                          Well I guess that settles that. I’ll just do a reinstall. Thanks for all the help though. You responded really quickly :)
                          • evroomE Offline
                            evroom
                            @smartsoldier Please edit the post with the config.js and remove your private api keys, like apiKey and dropboxAccessToken.
                            • evroomE Offline
                              evroom
                              @smartsoldier
                              I personally would not do a complete re-install, but I would re-install the modules according to their instructions.
                              Those modules would be:
                              MMM-forecast-io
                              MMM-DailyBibleVerse
                              In that order.
                              Btw, are all modules under the MagicMirror/modules directory ?
                              You yourself proofed that most stuff works.
                              @Sean proofed that your config is okay.
                              Btw, a simple ‘trick’ to disable a module is to put
                              disabled: true,
                              under the module name
                              and
                              disabled: false,
                              to enable it again.
                              Disabled:
                              module: 'MMM-DropboxWallpaper',
                              disabled: true,
                              Enabled:
                              disabled: false,
                              This gives you a faster way of excluding ‘wrong’ modules.
                              Or simply to test a module, whilst leaving the config when the module is not needed.
                                sdetweil @smartsoldier
                                @smartsoldier cut and paste your code in the www.jslint.com
                                check single quotes, spaces
                                and test it… you should find your error quickly
                                fix, and cut/paste the results back into the config.js
                                • justjim1220J Offline
                                  justjim1220 Module Developer @smartsoldier
                                  @smartsoldier
                                  Did you try to remove the comma as I suggested?
                                  Those give me fits everytime… no errors. black screen
                                  Jim Hallock - 1995
