    Quick Syntax Error
    20 Posts 5 Posters 5.3k Views 5 Watching
      smartsoldier
      I tried taking out the comma after YYYY, and moving the : closer to tokenLocationIQ. Neither worked. I’m not really sure how Sean managed to run without syntax errors when I am using the exact same config…
        A Former User @smartsoldier
        @smartsoldier I’ve copied from your post and nothing changed except some private values(tokens)
          @smartsoldier
          Most of the syntax errors could be raised by missing or exceeding bracket, comma.
          I suggest you remove configuration of modules one-by-one and try.
          Or you should upload a complete config.js here.
          • evroomE Offline
            evroom
            I also do not get an error when copy/pasting your config lines.
            $ npm run config:check
            does not give an error.
            You should try it yourself; a very useful command.
            Perhaps the error does not apply to the MMM-DropboxWallpaper config ?
            MagicMirror version: 2.33.0
            Test environment:
            MagicMirror version: v2.33.0
              smartsoldier
              Ok well I used npm run config:check and it found no errors, but I still get the syntax error message is red when I start up the MM. What is happening!??!
                @smartsoldier We don’t know. Remove all the modules in config.js and add one-by-one. Let’s see what happens.
                  smartsoldier @Guest
                  @sean If I remove this module everything runs fine, then if I put it back this happens. Does that mean its this module or no?
                  • evroomE Offline
                    evroom
                    Are you willing to share the syntax error with us?
                    I thought you were referring to the “create config file” message at startup.
                    Test environment:
                      @smartsoldier Of course, it could be the fails of that module configuration.
                        smartsoldier
