    Quick Syntax Error
    20 Posts 5 Posters 5.2k Views 5 Watching
      smartsoldier
      Can someone take a look at the new config setup for MMM-DropboxWallpaper and tell me where the syntax is wrong:
        module: 'MMM-DropboxWallpaper',
        position: 'fullscreen_below', // fullscreen_below is the best position.
        classes: "default everyone", // when you use MMM-ProfileSwitcher.
          refreshInterval: 1000*60,
          search: [".jpg", ".png", ".gif"], // Or you can find target files like "PARTIAL FILENAME". (wildcard or regexp not supported)
          directory: "/Pics", // root of directories of Dropbox to be scanned.
          sort: "random", //"time09", "time90", "nameAZ", "nameZA", "random"
          tokenLocationIQ : "secret", // See http://locationiq.org/#register
          dropboxAccessToken: "secret",
          width: "100%", // 'px' or '%' or valid value for CSS dimensions units.
          height: "100%",
          mode: "contain", // 'cover', 'contain', 'hybrid' or any other values for CSS `background-size`
          dateTimeFormat: "HH:mm MMM Do, YYYY", // See. moment.js .format()
      All I did was change my directory and API codes, but its giving the syntax error during startup. Seeing anything?
      justjim1220J 2 Replies Last reply Reply Quote 0
      • justjim1220J Offline
        justjim1220 Module Developer @smartsoldier
        @smartsoldier said in Quick Syntax Error:
        dateTimeFormat: “HH:mm MMM Do, YYYY”, // See. moment.js .format()
        take out the comma after YYYY"
        "Life's Too Short To Dance With Ugly People"
        Jim Hallock - 1995
          A Former User
          @smartsoldier
          I’ve copied your configuration and tried. but there was no syntax error.
          		    directory: "/MyMirror", // root of directories of Dropbox to be scanned.
          		    tokenLocationIQ : "", // See http://locationiq.org/#register
          		    dropboxAccessToken: "",
          		    height: "100%",
          • evroomE Online
            evroom
            I would try changing this:
            to this:
            tokenLocationIQ: "secret",
            MagicMirror version: 2.33.0
            Test environment:
            MagicMirror version: v2.33.0
              smartsoldier
              I tried taking out the comma after YYYY, and moving the : closer to tokenLocationIQ. Neither worked. I’m not really sure how Sean managed to run without syntax errors when I am using the exact same config…
                A Former User @smartsoldier
                @smartsoldier I’ve copied from your post and nothing changed except some private values(tokens)
                  @smartsoldier
                  Most of the syntax errors could be raised by missing or exceeding bracket, comma.
                  I suggest you remove configuration of modules one-by-one and try.
                  Or you should upload a complete config.js here.
                  • evroomE Online
                    evroom
                    I also do not get an error when copy/pasting your config lines.
                    $ npm run config:check
                    does not give an error.
                    You should try it yourself; a very useful command.
                    Perhaps the error does not apply to the MMM-DropboxWallpaper config ?
                    Test environment:
                      smartsoldier
                      Ok well I used npm run config:check and it found no errors, but I still get the syntax error message is red when I start up the MM. What is happening!??!
                        @smartsoldier We don’t know. Remove all the modules in config.js and add one-by-one. Let’s see what happens.
