    • Search
    MagicMirror² v2.20.0 is available! For more information about this release, check out this topic.
    UNSOLVED Multiples of same module?
    Troubleshooting
    • I
      isabellaalstrom last edited by
      I’m trying to have multiple modules of the same kind, but it doesn’t seem to work. What I’ve tried with is MMM-homeassistant-sensors and MMM-SL-PublicTransport. No error messages, just that the second module doesn’t work. Is this not possible?
        A Former User @isabellaalstrom last edited by A Former User
        @isabellaalstrom
        Some modules cannot work with multiple instances.
        Usually, If the module has node_helper.js, that kind of module wouldn’t work normally.
        Besides, If the module is using a unique DOM id or using singleton pattern in its code, that kind also has the possibility of not working properly.
        • I
          isabellaalstrom @Guest last edited by isabellaalstrom
          @sean Alright, thank you! Both of these has node_helper.js, so I guess it’s that then!
          • D
            doubleT Module Developer last edited by
            If you want a quick and dirty solution, copy the module folder, rename the copy and then change the module’s name to match the new module/folder name in all occurances (file names and within the code).
            I 1 Reply Last reply Reply Quote 1
            • M
              maxbachmann last edited by
              Haha yeah thats the solution I use aswell 😉
              • I
                isabellaalstrom @doubleT last edited by
                @doublet I will try this! I really want them on several places in the mirror 🙂
