    MMM-AVStock
    45 Posts 11 Posters 24.8k Views 10 Watching
    • thymonT Offline
      thymon @lavolp3
      @lavolp3 said in MMM-AVStock:
      @thymon Thank you, working on it.
      Hi @lavolp3 some news about this issue ?
      Thx :)
      • lavolp3L Offline
        lavolp3 Module Developer @thymon
        @thymon pushed an update yesterday. Try it out and let meknow if it works now
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        thymonT 1 Reply Last reply Reply Quote 0
        • thymonT Offline
          thymon @lavolp3
          Same issue.
          • lavolp3L Offline
            @thymon
            Can you please post your config?
            Also look if any changes in custom.css or main.css may affect behavior in the region or module. If yes post these entries as well
            • thymonT Offline
              thymon @lavolp3
              @lavolp3
                module: "MMM-AVStock",
                  apiKey : "HIDEN :-) ",
                  coloredCandles : true,
                       symbols : ["C40.PAR"],
                  alias: ["CAC40"],
                      mode : "table",
                      decimals: 2,
                      poolInterval : 5 * 60 * 1000,
                      tickerDuration: 5, // Ticker will be cycled once per this second.
                      timeFormat: "DD-MM-YYYY HH:mm:ss",
              Nothing in custum.css for .MMM-AVStock
              • thymonT Offline
                thymon @thymon
                @lavolp3
                Can you save help me ? :disappointed_but_relieved_face:
                • lavolp3L Offline
                  @thymon
                  Try:
                  1. setting width: 400 or any other value in the config.
                  2. using other regions
                  By default the module should expand to 100% width of it’s region. For some reason it expands to more than you would like.
                  • thymonT Offline
                    thymon @lavolp3
                    width: 400
                    same issue
                    add : width: 400,
                    testing with top left and top right
                    IMG-3560
                    lavolp3L 2 Replies Last reply Reply Quote 0
                    • lavolp3L Offline
                      @thymon if it’s still an issue can you post an issue on github?
                      I forget this when reading it only here.
                      • lavolp3L Offline
                        @thymon as a follow-up explanation:
                        The reason for what you have shown is that the table expands beyond its given width: 400 limit because … well tables don’t behave.
                        Setting a smaller font (classes: 'xsmall') OR using less table headers (to make the table thinner) OR setting a larger width would only solve this.
                        • 4 / 5
