    how to pull new element added to an array?
    57 Posts 4 Posters 26.5k Views 4 Watching
    • ? Offline
      A Former User @justjim1220
      @justjim1220 @sdetweil
      First, in line 18 of MMM-NewsFeedTicker.js
      Module.register("MMM-NewsFeedTicker", {
      • ? Offline
        A Former User
        I don’t know what @justjim1220 expect(So, I don’t request PR), but anyway, it’s executable now.
        https://github.com/eouia/MMM-NewsFeedTicker
        https://github.com/justjim1220/MMM-NewsFeedTicker/commit/64f5aae290682725ce2b8a1a64dd2771dfbd83c3
        Just executable. I think there might be many things to improve or fix.
        justjim1220J 1 Reply Last reply Reply Quote 0
        • ? Offline
          A Former User
          I think this is similar with what you really want to get.
          https://www.dropbox.com/s/9u4bjaimhlrnzfj/MMM-NewsFeedTickerX.zip?dl=0
          At first, I tried with your repository, but it seems so many things to modify. So I worked with original newsfeed. I wish you good luck.
          S justjim1220J 2 Replies Last reply Reply Quote 0
            sdetweil @Guest
            @justjim1220 thanks. Woke in the middle of the night thinking that needed to match module name…
            Haven’t tried it yet!
              sdetweil
              i have posted my almost working code to your github project in a new branch.
              the image url is extracted, saved and added to each rss feed response item.
              that url is used in the image.src attribute for the getDom function…
              BUT… the url is the FULL url, and I think the web engine under MM only allows src= from LOCAL files…
              when u look at the debug data items, the web server base is
              http://0.0.0.0:configured_port
              meaning adding a full url on to the end of that will fail…
              i posted info in an issue on github on what it might take to solve that…
              |edit: I see that Sean has used a different ui widget (Ticker) that seems to solve this problem
                sdetweil @Guest
                @sean nicely done…
                • justjim1220J Offline
                  justjim1220 Module Developer @sdetweil
                  LOL, I woke up early this morning thinking I could get something like this to work…
                  But, of course, I probably had something wrong somewhere, because it didn’t!!!
                  Jim Hallock - 1995
                    justjim1220 Module Developer @Guest
                    @sean
                    Not sure why, but this didn’t work for me, I will try it again in a little while, probably something I’m doing wrong!
                    Thank You!!!
                    Jim Hallock - 1995
                      @sean
                      This is ABSOLUTELY WONDERFUL!!!
                      THANK YOU, THANK YOU, THANK YOU!!! :smiling_face: :smiling_face: :smiling_face:
                      (still gonna try to get the first one going you sent link for in previous post!) :winking_face:
                      Jim Hallock - 1995
                        sdetweil
                        @sean and I have the same solution to GET the image url, the use of the tickertape widget which supports image is the key trick
                          Thank You for ALL your help on this, I think I have learned a lot doing this module!
                          THANK YOU! THANK YOU ! THANK YOU! !!! :smiling_face: :smiling_face: :smiling_face:
                          I’m looking at doing a bit of tweaking with each solution and when I get them done, I will commit to the repository and add to 3rd party list! :smiling_face_with_sunglasses:
                          Jim Hallock - 1995
                            sdetweil @justjim1220
                            @justjim1220 the key for all these callbacks and .on() routines, is that you cannot WAIT for things to happen in a browser, else it stops functioning… click,… nothing happens…
                            so, you have all these little event handlers… and YOU have to think about WHEN the happen relative to each other in time…
                              I get that now. Thanks!
                              My only issue at the moment is getting the speed of the animation to go faster on my original that Sean fixed to work. His re-worked one is adjustable, mine won’t budge!
                              I’ve even tried to incorporate some od the same coding he used in his, and I can’t figure it out! It is very weird!!!
                              Jim Hallock - 1995
                                ok, so here are some of the differences between the one we have been working on, and the one Sean reworked:
                                His truncates the description, I cannot figure out how to make it not truncate.
                                His images are set to height and width, Mine, I can set the height and the width is auto configured for aspect-ratio.
                                His shows the same message repeatedly for a period of time, then changes, Mine changes after each message.
                                with his, I can adjust the scroll speed, mine, I can’t figure out why it won’t change.
                                So, I am trying to figure out how to make the scroll adjustable as it goes really slow.
                                Jim Hallock - 1995
                                • ? Offline
                                  @justjim1220
                                  I’ve just modified
                                  • extracting logo from feed or config
                                  • dom for ticker
                                  Other features are derived from original or just side effects. As possible I can, I tried to remain the originals, but some features could be affected or changed.
                                  If you want explains, I can do that next weekdays.
                                    @sean
                                    its no problem, I was able to figure it all out by comparing code.
                                    Thank you so much for ALL your help!!!
                                    Jim Hallock - 1995
                                      I think I have it done!
                                      Repository updated.
                                      Put on list in 3rd Party Modules page
                                      MMM-NewsFeedTicker
                                      Now, If only I can remember how to make those gh-cards!!! LMAO!!!
                                      Thanks Everyone who helped me with this!!!
                                      Jim Hallock - 1995
                                      • 3 / 3
