    MMM-News
    55 Posts 15 Posters 50.8k Views 14 Watching
    • swvalentiS Offline
      swvalenti Project Sponsor
      @Bugsounet thank you very much
        @Bugsounet still getting the same error in the logs and news not displaying because of it. Below is my config. Any ideas?
          		module: "MMM-News",
          		position: "bottom_bar",
            		apiKey : "XXXXXXXXX",
            		type: "horizontal",
            		query : [
                	sources: "fox-news, fox-sports",
                country: "us",
                className: "redTitle",
        	touchable: false,
        	scanInterval: 1000*60*15
          Not sure what it means but says initialized with 10 query
          /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
          1|MagicMir | [2020-11-22 18:00:23.595] [LOG]    MMM-PGA Retrieving Tounament List
          1|MagicMir | [2020-11-22 18:00:24.198] [LOG]    MMM-PGA retrieving Tournament Data
          1|MagicMir | [2020-11-22 18:05:22.126] [LOG]    Use existing calendar fetcher for url: https://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
          1|MagicMir | [2020-11-22 18:05:22.134] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
          1|MagicMir | [2020-11-22 18:05:22.391] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
          1|MagicMir | [2020-11-22 18:05:24.044] [LOG]    MMM-PGA retrieving Tournament Data
          1|MagicMir | [2020-11-22 18:05:24.437] [LOG]    MMM-PGA Retrieving Tounament List
          1|MagicMir | [2020-11-22 18:07:49.476] [LOG]    Use existing calendar fetcher for url: https://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
          1|MagicMir | [2020-11-22 18:07:49.477] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
          1|MagicMir | [2020-11-22 18:07:49.481] [LOG]    MMM-PGA config received
          1|MagicMir | [2020-11-22 18:07:49.485] [LOG]    [NEWS] MMM-News Version: 2.1.2
          1|MagicMir | [2020-11-22 18:07:49.486] [LOG]    [NEWS] Initialized with 10 query
          1|MagicMir | [2020-11-22 18:07:49.720] [LOG]    MMM-PGA Retrieving Tounament List
          1|MagicMir | [2020-11-22 18:07:49.804] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
          1|MagicMir | [2020-11-22 18:07:50.969] [LOG]    MMM-PGA retrieving Tournament Data
          • ? Offline
            A Former User
            limited to 100 query by day and 50 query for 12 hours
            It’s not me who have set this limit but it’s news api
            and sorry, i don’t work in news api too ! :)
            so now just a little calc…
            you have 10 query and refresh is set to 15m
            for one query for one hour (every 15min) => 4 query
            for 10 query for one hour (every 15 min) => 4*10 = 40 query
            in 12 hours with one query => 12 * 4 = 48 query / 50 max
            in 12 hours with 10 query => 12* 40 = 480 query / 50 max
            in 24 hours with one query => 24 * 4 => 96 query / 100 Max
            in 24 hours with 10 query => 24*40 => 960 query / 100 max
            That why you have this error… and I just calc the number of query
            –> result: it take 9 query (take a lot of resource)
               country: "us",
            –> result: it take just one query
            Note: personnaly, i use only redTitle of my country
            Note 2: i will add soon a counter for calc if number of query is correct
              @Bugsounet Ok thanks for the detailed explanation. Here is my config now so hopefully this should resolve it.
                		module: "MMM-News",
                  		apiKey : "XXXXXXXXXXXXXXXXXXX",
                  		type: "horizontal",
                  		query : [
                      country: "us",
              	touchable: false,
              	scanInterval: 1000*60*30
              • ? Offline
                A Former User
                perfect, it should work perfectly now
                  Oddly the sizing of the module just randomly changed and got smaller. How do I make the entire module bigger to fill out the bottom_bar? I went into CSS but nothing I did seem to change anything.
                    I added this to custom css but just doesn’t look right. What could have changed the sizing as nothing was updated from the default install? I uninstalled and re-installed and same thing.
                    body  {
                    transform:scale(1.0);
                    .MMM-News {
                    transform:scale(1,1.75);
                    • ? Offline
                      A Former User
                      “Oddly”, i have not touch to the css code
                      and “Oddly” i don’t touche the main code
                      and “Oddly” I run this module in 3 differents RPI
                      and “Oddly” … this is no problem !
                      so try to disable all module one by one (except this modules), disable custom.css too
                      and “Oddly”, you will see : it works…
                      swvalentiS 1 Reply Last reply Reply Quote -1
                        swvalenti Project Sponsor @Guest
                        @Bugsounet said in MMM-News:
                        You need a snickers bar or something? Take it down a notch keyboard warrior
                        cowboysdudeC Mykle1M 2 Replies Last reply Reply Quote 1
                        • 6
                        • 4 / 6
