    MMM-News
    55 Posts 15 Posters 52.3k Views 14 Watching
    • swvalentiS Offline
      swvalenti Project Sponsor
      @Bugsounet ok thanks, let me know if I can do anything to help.
        Anything I can do in the mean time to troubleshoot to help get this resolved. It is happening now, I looked in the dev window but didn’t see any errors. I don’t know where else to look. Attached should show the news on the bottom bar but nothing there. Thanks, Scott
          @Bugsounet Just circling back on this…would it be easier if I created an issue on github or leave it here?
            sdetweil @swvalenti
            @swvalenti whos news? did u look in the console window where u started MM?
            or pm2 logs if using pm2?
            news and calendar use the node_helper to fetch info…
              Thanks Sam, checked the pm2 logs and unbeknownst to me…they now went to a paid tier api it seems!
              1|MagicMir | [2020-11-17 16:23:16.523] [LOG]    [NEWS] Error :  https://newsapi.org/v2/top-headlines?country=us&pageSize=20&apiKey=99d1bd76c7f140f58c237d54c41ab334 result.code:You have made too many requests recently. Developer accounts are limited to 100 requests over a 24 hour period (50 requests available every 12 hours). Please upgrade to a paid plan if you need more requests.
                sdetweil @swvalenti
                @swvalenti said in MMM-News:
                change the refresh rate to 15 minutes that would be 48 per 12 hours
                  @sdetweil I don’t see that as an option in the config…
                    sdetweil @swvalenti
                    @swvalenti edit line 48 of node_helper.js
                    change
                        this.scanInterval = 1000*60*10
                    to this
                        this.scanInterval = 1000*60*15
                    • ? Offline
                      A Former User @sdetweil
                      @sdetweil yes, it’s new they have limited request. So I will add new part of code for define interval, quickly
                      • ? Offline
                        A Former User
                        Hi, I have upgraded to v2.1.2 with personal fetch interval.
                        By default i put 30 min in default config
                          @Bugsounet thank you very much
                            @Bugsounet still getting the same error in the logs and news not displaying because of it. Below is my config. Any ideas?
                              		module: "MMM-News",
                              		position: "bottom_bar",
                                		apiKey : "XXXXXXXXX",
                                		type: "horizontal",
                                		query : [
                                    	sources: "fox-news, fox-sports",
                                    country: "us",
                                    className: "redTitle",
                            	touchable: false,
                            	scanInterval: 1000*60*15
                              Not sure what it means but says initialized with 10 query
                              /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                              1|MagicMir | [2020-11-22 18:00:23.595] [LOG]    MMM-PGA Retrieving Tounament List
                              1|MagicMir | [2020-11-22 18:00:24.198] [LOG]    MMM-PGA retrieving Tournament Data
                              1|MagicMir | [2020-11-22 18:05:22.126] [LOG]    Use existing calendar fetcher for url: https://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
                              1|MagicMir | [2020-11-22 18:05:22.134] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
                              1|MagicMir | [2020-11-22 18:05:22.391] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
                              1|MagicMir | [2020-11-22 18:05:24.044] [LOG]    MMM-PGA retrieving Tournament Data
                              1|MagicMir | [2020-11-22 18:05:24.437] [LOG]    MMM-PGA Retrieving Tounament List
                              1|MagicMir | [2020-11-22 18:07:49.476] [LOG]    Use existing calendar fetcher for url: https://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
                              1|MagicMir | [2020-11-22 18:07:49.477] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
                              1|MagicMir | [2020-11-22 18:07:49.481] [LOG]    MMM-PGA config received
                              1|MagicMir | [2020-11-22 18:07:49.485] [LOG]    [NEWS] MMM-News Version: 2.1.2
                              1|MagicMir | [2020-11-22 18:07:49.486] [LOG]    [NEWS] Initialized with 10 query
                              1|MagicMir | [2020-11-22 18:07:49.720] [LOG]    MMM-PGA Retrieving Tounament List
                              1|MagicMir | [2020-11-22 18:07:49.804] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
                              1|MagicMir | [2020-11-22 18:07:50.969] [LOG]    MMM-PGA retrieving Tournament Data
                              • ? Offline
                                A Former User
                                limited to 100 query by day and 50 query for 12 hours
                                It’s not me who have set this limit but it’s news api
                                and sorry, i don’t work in news api too ! :)
                                so now just a little calc…
                                you have 10 query and refresh is set to 15m
                                for one query for one hour (every 15min) => 4 query
                                for 10 query for one hour (every 15 min) => 4*10 = 40 query
                                in 12 hours with one query => 12 * 4 = 48 query / 50 max
                                in 12 hours with 10 query => 12* 40 = 480 query / 50 max
                                in 24 hours with one query => 24 * 4 => 96 query / 100 Max
                                in 24 hours with 10 query => 24*40 => 960 query / 100 max
                                That why you have this error… and I just calc the number of query
                                –> result: it take 9 query (take a lot of resource)
                                   country: "us",
                                –> result: it take just one query
                                Note: personnaly, i use only redTitle of my country
                                Note 2: i will add soon a counter for calc if number of query is correct
                                  @Bugsounet Ok thanks for the detailed explanation. Here is my config now so hopefully this should resolve it.
                                    		module: "MMM-News",
                                      		apiKey : "XXXXXXXXXXXXXXXXXXX",
                                      		type: "horizontal",
                                      		query : [
                                          country: "us",
                                  	touchable: false,
                                  	scanInterval: 1000*60*30
                                  • ? Offline
                                    A Former User
                                    perfect, it should work perfectly now
                                      Oddly the sizing of the module just randomly changed and got smaller. How do I make the entire module bigger to fill out the bottom_bar? I went into CSS but nothing I did seem to change anything.
                                        I added this to custom css but just doesn’t look right. What could have changed the sizing as nothing was updated from the default install? I uninstalled and re-installed and same thing.
                                        body  {
                                        transform:scale(1.0);
                                        .MMM-News {
                                        transform:scale(1,1.75);
                                        • ? Offline
                                          A Former User
                                          “Oddly”, i have not touch to the css code
                                          and “Oddly” i don’t touche the main code
                                          and “Oddly” I run this module in 3 differents RPI
                                          and “Oddly” … this is no problem !
                                          so try to disable all module one by one (except this modules), disable custom.css too
                                          and “Oddly”, you will see : it works…
                                          swvalentiS 1 Reply Last reply Reply Quote -1
                                            swvalenti Project Sponsor @Guest
                                            @Bugsounet said in MMM-News:
                                            You need a snickers bar or something? Take it down a notch keyboard warrior
                                            cowboysdudeC Mykle1M 2 Replies Last reply Reply Quote 1
                                            • 2 / 3
