    MMM-News
    55 Posts 15 Posters 55.6k Views 14 Watching
      sdetweil @Guest
      @Sean I added support in my MyCovid19 module for multiple instances… it was different, but not hard
      on all modlename.js sendSocketNotificatons, add the module identifier
      on all node_helper sendSocketNotifications, send it back
      in modulename.js , CHECK all receiveSocketNotifcation messages to see if its intended for this instance, as the sendSocketNotification from the node_helper goes to ALL modulename.js instances at once.
      then in node_helper I cached the data (as u proposed with the server instance), and for every request fordata from the modulename.js, I check to see if the data has arrived,
      if not, the 1st instance to arrive calls the api to get the data, all others block in Promise
      once the data arrives, all get resolved() with the data
      if the data is already here, then I resolve() with the data
      in my production system I have 11 charts drawn, and have 2 extra browser windows open to the MM server, so 33 charts in all, served by one node_helper all sharing one data source, and only making 1 api call for the data
        A Former User @sdetweil
        I don’t want to make an argument about your success. The difficulty is always relative. :)
        As you’ve said, all cloned modules should manage their own ID by themselves. (not only for the one device but also for each clients if multi-devices are working under server-clients)
        It could not be difficult, frankly, usual web sites/applications/components are developed like that.
        But the MM… hmmm. I always consider MM would be a standalone running device. Even though there exist some server/client usecases, most of the modules are developed as standalone. Using H/W peripheral(like GPIO or mic) is an example.
        Of course, we, developers can make the module clonable from the early stage of development. But I often have a question it’s worthy.
        For an imaginary use-case of other users, should I consider to make module clonable? Always my answer for this MM was… no.
        Because;
        • I’m not using clones. If I need something similar, I would make a new module, which might be able to manage multi-views(like CALEXT2) or to share some resources.(AMK2 and HOTWORDS), but it makes things too complex. I hate this way.
        • I feel some cul-de-sac from MM legacy. MM needs to provide more friendly way to reuse modules. At this moment, not. So that’s why I haven’t considered cloning. and why I lost interest in MM.
        Anyway, to say shortly. This module is not made for that purpose. Unless modification by myself or somebody, not possible. That’s all.
          sdetweil @Guest
          @Sean yes, I understand. I have made a couple this way , because the use case shows multiple instances very quickly.
          but many do not, if they are hardware constrained…
          • swvalentiS Offline
            swvalenti Project Sponsor
            git pull and npm install says it updated packages but when I check the version in the package.json it shows 2.0.0? What am I doing wrong? Thanks
            pi@raspberrypi:~ $ cd MagicMirror
            pi@raspberrypi:~/MagicMirror $ cd modules pi@raspberrypi:~/MagicMirror/modules $ cd MMM-News pi@raspberrypi:~/MagicMirror/modules/MMM-News $ git pull Updating 081fcb2..bff080d
            pi@raspberrypi:~/MagicMirror/modules/MMM-News $ npm install audited 95 packages in 3.8s found 0 vulnerabilities>\
              Anyone having an issue of news feed working then not working…just a black screen in the mirror portion position.
                A Former User
                Yes, i have this problem this week, don’t know really why.
                i have not read log for debugging it
                Next time, if i have this problem i will see what happen
                  @Bugsounet ok thanks, let me know if I can do anything to help.
                    Anything I can do in the mean time to troubleshoot to help get this resolved. It is happening now, I looked in the dev window but didn’t see any errors. I don’t know where else to look. Attached should show the news on the bottom bar but nothing there. Thanks, Scott
                      @Bugsounet Just circling back on this…would it be easier if I created an issue on github or leave it here?
                        sdetweil @swvalenti
                        @swvalenti whos news? did u look in the console window where u started MM?
                        or pm2 logs if using pm2?
                        news and calendar use the node_helper to fetch info…
                          Thanks Sam, checked the pm2 logs and unbeknownst to me…they now went to a paid tier api it seems!
                          1|MagicMir | [2020-11-17 16:23:16.523] [LOG]    [NEWS] Error :  https://newsapi.org/v2/top-headlines?country=us&pageSize=20&apiKey=99d1bd76c7f140f58c237d54c41ab334 result.code:You have made too many requests recently. Developer accounts are limited to 100 requests over a 24 hour period (50 requests available every 12 hours). Please upgrade to a paid plan if you need more requests.
                            sdetweil @swvalenti
                            @swvalenti said in MMM-News:
                            change the refresh rate to 15 minutes that would be 48 per 12 hours
                              @sdetweil I don’t see that as an option in the config…
                                sdetweil @swvalenti
                                @swvalenti edit line 48 of node_helper.js
                                change
                                    this.scanInterval = 1000*60*10
                                to this
                                    this.scanInterval = 1000*60*15
                                  @sdetweil yes, it’s new they have limited request. So I will add new part of code for define interval, quickly
                                    A Former User
                                    Hi, I have upgraded to v2.1.2 with personal fetch interval.
                                    By default i put 30 min in default config
                                      @Bugsounet thank you very much
                                        @Bugsounet still getting the same error in the logs and news not displaying because of it. Below is my config. Any ideas?
                                          		module: "MMM-News",
                                          		position: "bottom_bar",
                                            		apiKey : "XXXXXXXXX",
                                            		type: "horizontal",
                                            		query : [
                                                	sources: "fox-news, fox-sports",
                                                country: "us",
                                                className: "redTitle",
                                        	touchable: false,
                                        	scanInterval: 1000*60*15
                                          Not sure what it means but says initialized with 10 query
                                          /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                                          1|MagicMir | [2020-11-22 18:00:23.595] [LOG]    MMM-PGA Retrieving Tounament List
                                          1|MagicMir | [2020-11-22 18:00:24.198] [LOG]    MMM-PGA retrieving Tournament Data
                                          1|MagicMir | [2020-11-22 18:05:22.126] [LOG]    Use existing calendar fetcher for url: https://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
                                          1|MagicMir | [2020-11-22 18:05:22.134] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
                                          1|MagicMir | [2020-11-22 18:05:22.391] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
                                          1|MagicMir | [2020-11-22 18:05:24.044] [LOG]    MMM-PGA retrieving Tournament Data
                                          1|MagicMir | [2020-11-22 18:05:24.437] [LOG]    MMM-PGA Retrieving Tounament List
                                          1|MagicMir | [2020-11-22 18:07:49.476] [LOG]    Use existing calendar fetcher for url: https://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
                                          1|MagicMir | [2020-11-22 18:07:49.477] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
                                          1|MagicMir | [2020-11-22 18:07:49.481] [LOG]    MMM-PGA config received
                                          1|MagicMir | [2020-11-22 18:07:49.485] [LOG]    [NEWS] MMM-News Version: 2.1.2
                                          1|MagicMir | [2020-11-22 18:07:49.486] [LOG]    [NEWS] Initialized with 10 query
                                          1|MagicMir | [2020-11-22 18:07:49.720] [LOG]    MMM-PGA Retrieving Tounament List
                                          1|MagicMir | [2020-11-22 18:07:49.804] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
                                          1|MagicMir | [2020-11-22 18:07:50.969] [LOG]    MMM-PGA retrieving Tournament Data
                                            A Former User
                                            limited to 100 query by day and 50 query for 12 hours
                                            It’s not me who have set this limit but it’s news api
                                            and sorry, i don’t work in news api too ! :)
                                            so now just a little calc…
                                            you have 10 query and refresh is set to 15m
                                            for one query for one hour (every 15min) => 4 query
                                            for 10 query for one hour (every 15 min) => 4*10 = 40 query
                                            in 12 hours with one query => 12 * 4 = 48 query / 50 max
                                            in 12 hours with 10 query => 12* 40 = 480 query / 50 max
                                            in 24 hours with one query => 24 * 4 => 96 query / 100 Max
                                            in 24 hours with 10 query => 24*40 => 960 query / 100 max
                                            That why you have this error… and I just calc the number of query
                                            –> result: it take 9 query (take a lot of resource)
                                               country: "us",
                                            –> result: it take just one query
                                            Note: personnaly, i use only redTitle of my country
                                            Note 2: i will add soon a counter for calc if number of query is correct
                                            • 2 / 3
