    MMM-News
    55 Posts 15 Posters 59.1k Views 14 Watching
      sdetweil @Guest
      @Sean yes, I understand. I have made a couple this way , because the use case shows multiple instances very quickly.
      but many do not, if they are hardware constrained…
      • swvalentiS
        swvalenti Project Sponsor
        git pull and npm install says it updated packages but when I check the version in the package.json it shows 2.0.0? What am I doing wrong? Thanks
        pi@raspberrypi:~ $ cd MagicMirror
        pi@raspberrypi:~/MagicMirror $ cd modules pi@raspberrypi:~/MagicMirror/modules $ cd MMM-News pi@raspberrypi:~/MagicMirror/modules/MMM-News $ git pull Updating 081fcb2..bff080d
        pi@raspberrypi:~/MagicMirror/modules/MMM-News $ npm install audited 95 packages in 3.8s found 0 vulnerabilities>\
        • swvalentiS
          Anyone having an issue of news feed working then not working…just a black screen in the mirror portion position.
            A Former User
            Yes, i have this problem this week, don’t know really why.
            i have not read log for debugging it
            Next time, if i have this problem i will see what happen
            • swvalentiS
              @Bugsounet ok thanks, let me know if I can do anything to help.
              • swvalentiS
                Anything I can do in the mean time to troubleshoot to help get this resolved. It is happening now, I looked in the dev window but didn’t see any errors. I don’t know where else to look. Attached should show the news on the bottom bar but nothing there. Thanks, Scott
                • swvalentiS
                  @Bugsounet Just circling back on this…would it be easier if I created an issue on github or leave it here?
                    sdetweil @swvalenti
                    @swvalenti whos news? did u look in the console window where u started MM?
                    or pm2 logs if using pm2?
                    news and calendar use the node_helper to fetch info…
                    • swvalentiS
                      Thanks Sam, checked the pm2 logs and unbeknownst to me…they now went to a paid tier api it seems!
                      1|MagicMir | [2020-11-17 16:23:16.523] [LOG]    [NEWS] Error :  https://newsapi.org/v2/top-headlines?country=us&pageSize=20&apiKey=99d1bd76c7f140f58c237d54c41ab334 result.code:You have made too many requests recently. Developer accounts are limited to 100 requests over a 24 hour period (50 requests available every 12 hours). Please upgrade to a paid plan if you need more requests.
                        sdetweil @swvalenti
                        @swvalenti said in MMM-News:
                        change the refresh rate to 15 minutes that would be 48 per 12 hours
                        • swvalentiS
                          @sdetweil I don’t see that as an option in the config…
                            sdetweil @swvalenti
                            @swvalenti edit line 48 of node_helper.js
                            change
                                this.scanInterval = 1000*60*10
                            to this
                                this.scanInterval = 1000*60*15
                            ? 1 Reply Last reply
                              A Former User @sdetweil
                              @sdetweil yes, it’s new they have limited request. So I will add new part of code for define interval, quickly
                                A Former User
                                Hi, I have upgraded to v2.1.2 with personal fetch interval.
                                By default i put 30 min in default config
                                Reply Quote 2
                                • swvalentiS
                                  @Bugsounet thank you very much
                                  • swvalentiS
                                    @Bugsounet still getting the same error in the logs and news not displaying because of it. Below is my config. Any ideas?
                                      		module: "MMM-News",
                                      		position: "bottom_bar",
                                        		apiKey : "XXXXXXXXX",
                                        		type: "horizontal",
                                        		query : [
                                            	sources: "fox-news, fox-sports",
                                            country: "us",
                                            className: "redTitle",
                                    	touchable: false,
                                    	scanInterval: 1000*60*15
                                    • swvalentiS
                                      Not sure what it means but says initialized with 10 query
                                      /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                                      1|MagicMir | [2020-11-22 18:00:23.595] [LOG]    MMM-PGA Retrieving Tounament List
                                      1|MagicMir | [2020-11-22 18:00:24.198] [LOG]    MMM-PGA retrieving Tournament Data
                                      1|MagicMir | [2020-11-22 18:05:22.126] [LOG]    Use existing calendar fetcher for url: https://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
                                      1|MagicMir | [2020-11-22 18:05:22.134] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
                                      1|MagicMir | [2020-11-22 18:05:22.391] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
                                      1|MagicMir | [2020-11-22 18:05:24.044] [LOG]    MMM-PGA retrieving Tournament Data
                                      1|MagicMir | [2020-11-22 18:05:24.437] [LOG]    MMM-PGA Retrieving Tounament List
                                      1|MagicMir | [2020-11-22 18:07:49.476] [LOG]    Use existing calendar fetcher for url: https://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics
                                      1|MagicMir | [2020-11-22 18:07:49.477] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
                                      1|MagicMir | [2020-11-22 18:07:49.481] [LOG]    MMM-PGA config received
                                      1|MagicMir | [2020-11-22 18:07:49.485] [LOG]    [NEWS] MMM-News Version: 2.1.2
                                      1|MagicMir | [2020-11-22 18:07:49.486] [LOG]    [NEWS] Initialized with 10 query
                                      1|MagicMir | [2020-11-22 18:07:49.720] [LOG]    MMM-PGA Retrieving Tounament List
                                      1|MagicMir | [2020-11-22 18:07:49.804] [INFO]   Calendar-Fetcher: Broadcasting 2 events.
                                      1|MagicMir | [2020-11-22 18:07:50.969] [LOG]    MMM-PGA retrieving Tournament Data
                                        A Former User
                                        limited to 100 query by day and 50 query for 12 hours
                                        It’s not me who have set this limit but it’s news api
                                        and sorry, i don’t work in news api too ! :)
                                        so now just a little calc…
                                        you have 10 query and refresh is set to 15m
                                        for one query for one hour (every 15min) => 4 query
                                        for 10 query for one hour (every 15 min) => 4*10 = 40 query
                                        in 12 hours with one query => 12 * 4 = 48 query / 50 max
                                        in 12 hours with 10 query => 12* 40 = 480 query / 50 max
                                        in 24 hours with one query => 24 * 4 => 96 query / 100 Max
                                        in 24 hours with 10 query => 24*40 => 960 query / 100 max
                                        That why you have this error… and I just calc the number of query
                                        –> result: it take 9 query (take a lot of resource)
                                           country: "us",
                                        –> result: it take just one query
                                        Note: personnaly, i use only redTitle of my country
                                        Note 2: i will add soon a counter for calc if number of query is correct
                                        • swvalentiS
                                          @Bugsounet Ok thanks for the detailed explanation. Here is my config now so hopefully this should resolve it.
                                            		module: "MMM-News",
                                              		apiKey : "XXXXXXXXXXXXXXXXXXX",
                                              		type: "horizontal",
                                              		query : [
                                                  country: "us",
                                          	touchable: false,
                                          	scanInterval: 1000*60*30
                                            A Former User
                                            perfect, it should work perfectly now
                                            • 2 / 3
