    Black screen after starting
    13 Posts 4 Posters 12.9k Views 3 Watching
    • CyruS1337C Offline
      CyruS1337 Project Sponsor
      Hello everybody
      When I start the PI I see the desktop and after 2-3 seconds later the MagicMirror starts. The screen just stays black. The MaigcMirror has worked for 2 months without any problems, that problem is only 2 days.
      I can also post logs here if you tell me which logs are relevant. I can access the PI via putty.
      Thank you very much for your help
        bhepler Module Developer @CyruS1337
        @cyrus1337 - Let’s start with the mirror logs. Try pm2 log MagicMirror and let us know what it shows.
          @bhepler said in Black screen after starting:
          Ok, thanks for the help. I will post the logs in the evening
          • lavolp3L Offline
            lavolp3 Module Developer
            Also, it’s always important to check the config file. Do a
            npm run config:check
            inside the MagicMirror folder.
            And then, I would always test to just restart it, last time I had the problem it was magically solved by this
            pm2 restart mm
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
            CyruS1337C 1 Reply Last reply Reply Quote 0
              CyruS1337 Project Sponsor @lavolp3
              @lavolp3 Ok, I will try tonight. Thank you and then give feedback
                So, when I run npm run this comes:
                > magicmirror@2.5.0 config:check /home/pi/MagicMirror
                > node tests/configs/check_config.js
                Checking file...  /home/pi/MagicMirror/config/config.js
                Your configuration file doesn't contain syntax errors :)
                Here is the pm2 log:
                [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
                /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                0|MagicMir |     at Object._errnoException (util.js:1024:11)
                0|MagicMir |     at _exceptionWithHostPort (util.js:1046:20)
                0|MagicMir |     at Server.setupListenHandle [as _listen2] (net.js:1334:19)
                0|MagicMir |     at listenInCluster (net.js:1392:12)
                0|MagicMir |     at doListen (net.js:1501:7)
                0|MagicMir |     at _combinedTickCallback (internal/process/next_tick.js:141:11)
                0|MagicMir |     at process._tickCallback (internal/process/next_tick.js:180:9)
                0|MagicMir |     at Function.Module.runMain (module.js:685:11)
                0|MagicMir |     at startup (bootstrap_node.js:196:16)
                0|MagicMir |     at bootstrap_node.js:622:3
                0|MagicMir |   code: 'EADDRNOTAVAIL',
                0|MagicMir |   errno: 'EADDRNOTAVAIL',
                0|MagicMir |   syscall: 'listen',
                0|MagicMir |   address: '192.168.1.154',
                0|MagicMir |   port: 8080 }
                /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                0|MagicMir | Connecting socket for: newsfeed
                0|MagicMir | Starting module: newsfeed
                0|MagicMir | Connecting socket for: MMM-GoogleMapsTraffic
                0|MagicMir | Starting node_helper for module: MMM-GoogleMapsTraffic
                0|MagicMir | Connecting socket for: MMM-SoccerLiveScore
                0|MagicMir | MMM-SoccerLiveScore helper started...
                0|MagicMir | Connecting socket for: MMM-MyCalendar
                0|MagicMir | Starting node helper for: MMM-MyCalendar
                0|MagicMir | Connecting socket for: email
                0|MagicMir | email helper started ...
                0|MagicMir | Sockets connected & modules started ...
                0|MagicMir | Whoops! There was an uncaught exception...
                0|MagicMir | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                0|MagicMir | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                0|MagicMir | Launching application.
                pm2 restart MagicMirror brought no success
                  sdetweil
                  @cyrus1337 said in Black screen after starting:
                  EADDRNOTAVAIL
                  says that the mm config is trying to listen on a specific address, which is NOT the same as on the machine MM is running on…
                  show us your config.js
                    Here is my config
                    /* Magic Mirror Config Sample
                     * MIT Licensed.
                    var config = {
                    	address: "192.168.1.154", // Address to listen on, can be:
                    	port: 8080,
                    	ipWhitelist: ["127.0.0.1", "192.168.1.0/24", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses
                    	language: "de",
                    	timeFormat: 24,
                    	units: "metric",
                    			module: "alert",
                    			module: "updatenotification",
                    			position: "top_bar"
                    			module: "clock",
                    			position: "top_left"
                    			module: "compliments",
                    			position: "lower_third"
                    		module: 'MMM-SystemStats',
                    		position: 'top_right', // This can be any of the regions.
                    		classes: 'small dimmed', // Add your own styling. Optional.
                    			updateInterval: 10000,
                    			animationSpeed: 0,
                    			align: 'right', // align labels
                    			//header: 'System Stats', // This is optional
                      module: 'MMM-MyCommute',
                      position: 'top_left',
                      header: 'Verkehrssituation',
                        apikey: 'API',
                        origin: 'Dingerten 21, 4624 Härkingen',
                        startTime: '00:00',
                        endTime: '23:59',
                    	travelTimeFormat: 'h[h]:m[min]',
                    	colorCodeTravelTime: true,
                    	showSummary: true,
                        hideDays: [0,6],
                        destinations: [
                            destination: 'Südstrasse 5, 8952 Schlieren',
                            label: 'Adriano Arbeit',
                    		mode: 'driving',
                            color: '#82E5AA',
                    		startTime: '05:00',
                    		endTime: '08:00',
                    		alternatives: true,
                    		waypoints: 'via:Bernerstrasse Süd, 8048 Zürich'
                            destination: 'Zugerstrasse 13, 6030 Ebikon',
                            label: 'Ebikon',
                    		startTime: '05:00',
                    		endTime: '08:00',
                    		alternatives: 'ture'
                    			module: "newsfeed",
                    			position: "bottom_center",
                    				feeds: [
                    						title: "20min Sport",
                    						url: "https://api.20min.ch/rss/view/67",
                    				showSourceTitle: true,
                    				showPublishDate: true
                    			module: "newsfeed",
                    				feeds: [
                    						title: "20min Front",
                    						url: "https://api.20min.ch/rss/view/1",
                                module: 'MMM-GoogleMapsTraffic',
                                position: 'bottom_center',
                                    key: 'API',
                                    lat: 47.3855987,
                                    lng: 8.1395006,
                                    height: '450px',
                                    width: '1000px',
                    				zoom: 10,
                            module: 'MMM-PIR-Sensor',
                    		powerSavingDelay: 5,
                    		powerSaving: true,
                    		sensorPin: 22,/*
                    		powerSavingMessage: "Monitor will be turn Off by PIR module",
                    		sensorState: 1,
                    		alwaysOffState: 1,
                    		powerSaving: true,
                    		powerSavingNotification: false,
                    		module: 'MMM-ImageSlideshow',
                    		position: 'middle_center',
                    			imagePaths: ['modules/MMM-ImageSlideshow/exampleImages'],
                    			fixedImageWidth: '500',
                    			fixedImageHeight: '350',
                    			slideshowSpeed: '25000',
                    			randomizeImageOrder: true,
                    	module: 'MMM-SoccerLiveScore',
                    	header: 'Fussball Rangliste',
                    		leagues: [215,399,1],
                            showNames: true,
                            showLogos: true,
                            displayTime: 60 * 1000,
                            showTables: true
                    		module: "MMM-MyCalendar",
                    		position: "top_left",	// This can be any of the regions. Best results in left or right regions.
                    		header: 'Kalender Adri',
                            colored: true,
                    		maxTitleLength: 30,
                    		maximumEntries: 5,
                    		timeFormat: "HH:mm",
                    		dateFormat: "DD:MM:YYYY",
                    		joiningWord: "um",
                    			url: 'ics',
                    			color: "#ff5070",
                    			symbol: 'calendar',
                    			auth: {
                    			    user: 'username',
                    			    pass: 'superstrongpassword',
                    			    method: 'basic'
                    		module: 'email',
                                    header: 'Email',
                                        accounts: [
                                                user: 'user',
                                                password: 'pw',
                                                host: 'imap.gmail.com',
                                                port: 993,
                                                tls: true,
                                                authTimeout: 50000,
                                                numberOfEmails: 2,
                                        fade: true,
                                        maxCharacters: 30
                        module: 'MMM-forecast-io',
                        position: 'top_left',  // This can be any of the regions.
                    	  apiKey: 'API', // Dark Sky API key.
                          // Only required if geolocation doesn't work:
                          latitude:   47.3097176,
                          longitude: 7.8106514
                      aaaaaaaaaaaaaa I found it, thanks to your note.
                      My router has given the PI a new IP, now I have changed the new IP in the config and behold, he works again !!!
                      Thank you so much @sdetweil
                        sdetweil @CyruS1337
                        @cyrus1337 better to use 0.0.0.0, which means any …
                        Then it won’t fail again if the address changes
                          But do not I have to enter the IP to run the Remte Module or the MMM NetworkScanner?
                          I still have another problem :) I do not know if I would like to open a new topic or if I can place it here.
                          It’s about the module email-mirror, it always shows only “load”, I don’t know what I’m doing wrong
                          • lavolp3L Offline
                            lavolp3 Module Developer @CyruS1337
                            The “listening” address in the config does not affect the behaviour of the other modules. It does not determine the IP of your mirror!
                            The other modules get the mirror’s IP from somewhere else, don’t worry.
                            The address e’re talking about here is there to determine on which network device to listen (if I understand correctly!).
                            0.0.0.0 specifies “use them all”
                            You won’t do any harm using that.
                              Ok thank you. Then I will use 0.0.0.0
                              Thanks again for your help !!! That’s really great
