    Black screen after starting
    13 Posts 4 Posters 12.2k Views 3 Watching
    • CyruS1337C Offline
      CyruS1337 Project Sponsor @lavolp3
      @lavolp3 Ok, I will try tonight. Thank you and then give feedback
        So, when I run npm run this comes:
        > magicmirror@2.5.0 config:check /home/pi/MagicMirror
        > node tests/configs/check_config.js
        Checking file...  /home/pi/MagicMirror/config/config.js
        Your configuration file doesn't contain syntax errors :)
        Here is the pm2 log:
        [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
        /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
        0|MagicMir |     at Object._errnoException (util.js:1024:11)
        0|MagicMir |     at _exceptionWithHostPort (util.js:1046:20)
        0|MagicMir |     at Server.setupListenHandle [as _listen2] (net.js:1334:19)
        0|MagicMir |     at listenInCluster (net.js:1392:12)
        0|MagicMir |     at doListen (net.js:1501:7)
        0|MagicMir |     at _combinedTickCallback (internal/process/next_tick.js:141:11)
        0|MagicMir |     at process._tickCallback (internal/process/next_tick.js:180:9)
        0|MagicMir |     at Function.Module.runMain (module.js:685:11)
        0|MagicMir |     at startup (bootstrap_node.js:196:16)
        0|MagicMir |     at bootstrap_node.js:622:3
        0|MagicMir |   code: 'EADDRNOTAVAIL',
        0|MagicMir |   errno: 'EADDRNOTAVAIL',
        0|MagicMir |   syscall: 'listen',
        0|MagicMir |   address: '192.168.1.154',
        0|MagicMir |   port: 8080 }
        /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
        0|MagicMir | Connecting socket for: newsfeed
        0|MagicMir | Starting module: newsfeed
        0|MagicMir | Connecting socket for: MMM-GoogleMapsTraffic
        0|MagicMir | Starting node_helper for module: MMM-GoogleMapsTraffic
        0|MagicMir | Connecting socket for: MMM-SoccerLiveScore
        0|MagicMir | MMM-SoccerLiveScore helper started...
        0|MagicMir | Connecting socket for: MMM-MyCalendar
        0|MagicMir | Starting node helper for: MMM-MyCalendar
        0|MagicMir | Connecting socket for: email
        0|MagicMir | email helper started ...
        0|MagicMir | Sockets connected & modules started ...
        0|MagicMir | Whoops! There was an uncaught exception...
        0|MagicMir | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        0|MagicMir | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        0|MagicMir | Launching application.
        pm2 restart MagicMirror brought no success
          @cyrus1337 said in Black screen after starting:
          EADDRNOTAVAIL
          says that the mm config is trying to listen on a specific address, which is NOT the same as on the machine MM is running on…
          show us your config.js
            Here is my config
            /* Magic Mirror Config Sample
             * MIT Licensed.
            var config = {
            	address: "192.168.1.154", // Address to listen on, can be:
            	port: 8080,
            	ipWhitelist: ["127.0.0.1", "192.168.1.0/24", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses
            	language: "de",
            	timeFormat: 24,
            	units: "metric",
            			module: "alert",
            			module: "updatenotification",
            			position: "top_bar"
            			module: "clock",
            			position: "top_left"
            			module: "compliments",
            			position: "lower_third"
            		module: 'MMM-SystemStats',
            		position: 'top_right', // This can be any of the regions.
            		classes: 'small dimmed', // Add your own styling. Optional.
            			updateInterval: 10000,
            			animationSpeed: 0,
            			align: 'right', // align labels
            			//header: 'System Stats', // This is optional
              module: 'MMM-MyCommute',
              position: 'top_left',
              header: 'Verkehrssituation',
                apikey: 'API',
                origin: 'Dingerten 21, 4624 Härkingen',
                startTime: '00:00',
                endTime: '23:59',
            	travelTimeFormat: 'h[h]:m[min]',
            	colorCodeTravelTime: true,
            	showSummary: true,
                hideDays: [0,6],
                destinations: [
                    destination: 'Südstrasse 5, 8952 Schlieren',
                    label: 'Adriano Arbeit',
            		mode: 'driving',
                    color: '#82E5AA',
            		startTime: '05:00',
            		endTime: '08:00',
            		alternatives: true,
            		waypoints: 'via:Bernerstrasse Süd, 8048 Zürich'
                    destination: 'Zugerstrasse 13, 6030 Ebikon',
                    label: 'Ebikon',
            		startTime: '05:00',
            		endTime: '08:00',
            		alternatives: 'ture'
            			module: "newsfeed",
            			position: "bottom_center",
            				feeds: [
            						title: "20min Sport",
            						url: "https://api.20min.ch/rss/view/67",
            				showSourceTitle: true,
            				showPublishDate: true
            			module: "newsfeed",
            				feeds: [
            						title: "20min Front",
            						url: "https://api.20min.ch/rss/view/1",
                        module: 'MMM-GoogleMapsTraffic',
                        position: 'bottom_center',
                            key: 'API',
                            lat: 47.3855987,
                            lng: 8.1395006,
                            height: '450px',
                            width: '1000px',
            				zoom: 10,
                    module: 'MMM-PIR-Sensor',
            		powerSavingDelay: 5,
            		powerSaving: true,
            		sensorPin: 22,/*
            		powerSavingMessage: "Monitor will be turn Off by PIR module",
            		sensorState: 1,
            		alwaysOffState: 1,
            		powerSaving: true,
            		powerSavingNotification: false,
            		module: 'MMM-ImageSlideshow',
            		position: 'middle_center',
            			imagePaths: ['modules/MMM-ImageSlideshow/exampleImages'],
            			fixedImageWidth: '500',
            			fixedImageHeight: '350',
            			slideshowSpeed: '25000',
            			randomizeImageOrder: true,
            	module: 'MMM-SoccerLiveScore',
            	header: 'Fussball Rangliste',
            		leagues: [215,399,1],
                    showNames: true,
                    showLogos: true,
                    displayTime: 60 * 1000,
                    showTables: true
            		module: "MMM-MyCalendar",
            		position: "top_left",	// This can be any of the regions. Best results in left or right regions.
            		header: 'Kalender Adri',
                    colored: true,
            		maxTitleLength: 30,
            		maximumEntries: 5,
            		timeFormat: "HH:mm",
            		dateFormat: "DD:MM:YYYY",
            		joiningWord: "um",
            			url: 'ics',
            			color: "#ff5070",
            			symbol: 'calendar',
            			auth: {
            			    user: 'username',
            			    pass: 'superstrongpassword',
            			    method: 'basic'
            		module: 'email',
                            header: 'Email',
                                accounts: [
                                        user: 'user',
                                        password: 'pw',
                                        host: 'imap.gmail.com',
                                        port: 993,
                                        tls: true,
                                        authTimeout: 50000,
                                        numberOfEmails: 2,
                                fade: true,
                                maxCharacters: 30
                module: 'MMM-forecast-io',
                position: 'top_left',  // This can be any of the regions.
            	  apiKey: 'API', // Dark Sky API key.
                  // Only required if geolocation doesn't work:
                  latitude:   47.3097176,
                  longitude: 7.8106514
              aaaaaaaaaaaaaa I found it, thanks to your note.
              My router has given the PI a new IP, now I have changed the new IP in the config and behold, he works again !!!
              Thank you so much @sdetweil
                sdetweil @CyruS1337
                @cyrus1337 better to use 0.0.0.0, which means any …
                Then it won’t fail again if the address changes
                  But do not I have to enter the IP to run the Remte Module or the MMM NetworkScanner?
                  I still have another problem :) I do not know if I would like to open a new topic or if I can place it here.
                  It’s about the module email-mirror, it always shows only “load”, I don’t know what I’m doing wrong
                  • lavolp3L Offline
                    lavolp3 Module Developer @CyruS1337
                    The “listening” address in the config does not affect the behaviour of the other modules. It does not determine the IP of your mirror!
                    The other modules get the mirror’s IP from somewhere else, don’t worry.
                    The address e’re talking about here is there to determine on which network device to listen (if I understand correctly!).
                    0.0.0.0 specifies “use them all”
                    You won’t do any harm using that.
                    How to troubleshoot modules
                    MMM-soccer v2, MMM-AVStock
                      Ok thank you. Then I will use 0.0.0.0
                      Thanks again for your help !!! That’s really great
