    Problem with the Module "email"
    57 Posts 4 Posters 36.9k Views 4 Watching
    • CyruS1337C Offline
      CyruS1337 Project Sponsor
      I have a problem with the module “email”.
      Unfortunately, the module shows me no emails. It is always “loading”
      I do not know any more and hope you can help me.
      That would be the pm2 log:
      > magicmirror@2.5.0 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.5.0
      Loading config ...
      Loading module helpers ...
      Module helper loaded: MMM-SystemStats
      Module helper loaded: MMM-MyCommute
      Module helper loaded: MMM-GoogleMapsTraffic
      No helper found for module: MMM-PIR-Sensor.
      Module helper loaded: MMM-SoccerLiveScore
      Module helper loaded: MMM-MyCalendar
      Module helper loaded: email
      All module helpers loaded.
      Server started ...
      Connecting socket for: MMM-SystemStats
      Connecting socket for: MMM-MyCommute
      ====================== Starting node_helper for module [MMM-MyCommute]
      Starting module: newsfeed
      Connecting socket for: MMM-GoogleMapsTraffic
      Starting node_helper for module: MMM-GoogleMapsTraffic
      Connecting socket for: MMM-SoccerLiveScore
      MMM-SoccerLiveScore helper started...
      Connecting socket for: MMM-MyCalendar
      Starting node helper for: MMM-MyCalendar
      Connecting socket for: email
      email helper started ...
      Launching application.
      Create new news fetcher for url: https://api.20min.ch/rss/view/1 - Interval: 300000
      Create new news fetcher for url: https://api.20min.ch/rss/view/67 - Interval: 300000
      Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload:  { style: 'standard' }
      Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/gmail.com/private-75149d8982f910a209e0fe7d0363d75f/basic.ics - Interval: 300000
      listening for emails...
        sdetweil @CyruS1337
        @cyrus1337 press ctrl-shift-i (letter i)
        To open the dev console, then select the console tab. Scroll to see if error on module.js side
        CyruS1337C 1 Reply Last reply Reply Quote 0
          CyruS1337 Project Sponsor @sdetweil
          @sdetweil Sorry, but where do I have to execute the command.
          Sorry, I’m really a beginner …
            I hope this helps:
            0|MagicMirror  | Email notifier error:  { Error: Please log in via your web browser: https://support.google.com/mail/accounts/answer/78754 (Failure)
            0|MagicMirror  |     at Connection._resTagged (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Connection.js:1502:11)
            0|MagicMirror  |     at Parser.<anonymous> (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Connection.js:194:10)
            0|MagicMirror  |     at emitOne (events.js:116:13)
            0|MagicMirror  |     at Parser.emit (events.js:211:7)
            0|MagicMirror  |     at Parser._resTagged (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:175:10)
            0|MagicMirror  |     at Parser._parse (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:139:16)
            0|MagicMirror  |     at Parser._tryread (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:82:15)
            0|MagicMirror  |     at TLSSocket.Parser._cbReadable (/home/pi/MagicMirror/modules/email/node_modules/imap/lib/Parser.js:53:12)
            0|MagicMirror  |     at emitNone (events.js:106:13)
            0|MagicMirror  |     at TLSSocket.emit (events.js:208:7) type: 'no', textCode: 'ALERT', source: 'authentication' }
            That does not stop and it always comes back to the mistake itself
              sdetweil @CyruS1337
              @cyrus1337 I don’t know anything about this module, but I would guess that your email config is wrong.
              The error means the module failed parsing the email data, because there was a connection or permissions error (tls implies ssl connection problem)
                I have the config as described on the page https://github.com/ronny3050/email-mirror
                		        module: 'email',
                                position: 'top_left',
                                header: 'Email',
                                    accounts: [
                                            user: 'name@gmail.com',
                                            password: 'pw',
                                            host: 'imap.gmail.com',
                			    port: 993,
                                            tls: true,
                                            authTimeout: 10000,
                                            numberOfEmails: 5,
                                    fade: true,
                                    maxCharacters: 30
                  sdetweil @CyruS1337
                  @cyrus1337 and password: ‘pw’ where pw is YOUR EMAIL password, right?
                  And name@gmail.com is YOUR Gmail username
                    @sdetweil said in Problem with the Module "email":
                    Genau, das ist das Passwort für den Emailaccount.
                    Bei user habe ich meine Emailadresse angegeben.
                    • cirdanC Offline
                      cirdan
                      Did you set google security lower than the default. Something with allow third party apps?
                      Modules MMM-rainfc, MMM-bustimes, MMM-Harmony, MMM-Rijks
                        @cirdan said in Problem with the Module "email":
                        Yey, i have set
                        cirdanC 1 Reply Last reply Reply Quote 0
                        • cirdanC Offline
                          cirdan @CyruS1337
                          @cyrus1337 its an authentication problem. My best guess is an error in typing your userid or password. You can try it with username, without the @gmail.com part
                            CyruS1337 Project Sponsor @cirdan
                            @cirdan Ok, you mean I should just enter the name: Adriano B …
                            • cirdanC Offline
                              cirdan @CyruS1337
                              @cyrus1337 what I mean is e.g. your email is namexxx@gmail.com that you use namexxx as an username in the config. I remember playing with that when getting to module to work
                                @cirdan I did that. My username in config is adriano.b .....@gmail.com or am I mistaken you?
                                		        module: 'email',
                                                header: 'Email',
                                                    accounts: [
                                                            user: '...@gmail.com',
                                                            password: '...',
                                			    port: 993,
                                                            tls: true,
                                                            authTimeout: 10000,
                                                            numberOfEmails: 5,
                                                    fade: true,
                                                    maxCharacters: 30
                                  sdetweil
                                  usually when we show our config.js with personal stuff removed, we use … or xxx instead of the default ‘name’ and ‘pw’.
                                  this lets others looking at your issue know you have changed the content
                                    ok, i changed it. Thanks for the information
                                      sdetweil @CyruS1337
                                      @cyrus1337 thank you…
                                        But I have not come further. Is there something wrong with my config?
                                          sdetweil @CyruS1337
                                          @cyrus1337 ok, I cut/pasted your config, changed to my userid and password…
                                          failed… module imap not found…
                                          had to run npm install from the modules/email folder…
                                          restart mirror…
                                          note: this only shows NEWLY arriving email… i don’t know how the mail drops off, as it hasn’t updated for me… 5 emails shown…
                                            @sdetweil I did that you’ve got. Unfortunately without success
                                            pi@raspberrypi2:~ $ cd MagicMirror
                                            pi@raspberrypi2:~/MagicMirror $ cd modules
                                            pi@raspberrypi2:~/MagicMirror/modules $ cd email
                                            pi@raspberrypi2:~/MagicMirror/modules/email $ npm install
                                            npm WARN email@0.0.1 No repository field.
                                            npm WARN email@0.0.1 No license field.
                                            audited 24 packages in 4.491s
                                            found 0 vulnerabilities
                                            pi@raspberrypi2:~/MagicMirror/modules/email $ sudo reboot
                                            login as: pi
                                            pi@192.168.1.102's password:
                                            Linux raspberrypi2 4.14.67-v7+ #1139 SMP Wed Aug 29 15:17:05 BST 2018 armv7l
                                            The programs included with the Debian GNU/Linux system are free software;
                                            the exact distribution terms for each program are described in the
                                            individual files in /usr/share/doc/*/copyright.
                                            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                            permitted by applicable law.
                                            Last login: Thu Nov  8 20:03:08 2018 from 192.168.1.134
                                            pi@raspberrypi2:~ $
                                            • 1 / 3
