    Problem with the Module "email"
    57 Posts 4 Posters 28.1k Views 4 Watching
      sdetweil @CyruS1337
      @cyrus1337 ok , open a command prompt so we can look at the error output…
      then cd MagaicMirror and type
      npm start
      i see stuff like this
      > magicmirror@2.5.0 start /home/odroid/Magi
      > sh run-start.sh
      Starting MagicMirror: v2.5.0
      Loading config ...
      Loading module helpers ...
      handler helper in init
      Module helper loaded: MMM-SleepWake
      Module helper loaded: MMM-ImagesPhotos
      Module helper loaded: MMM-BMW-DS
      All module helpers loaded.
      Starting server on port 8086 ...
      You're using a full whitelist configuration
      Server started ...
      Starting module: newsfeed
      Connecting socket for: MMM-SleepWake
      handler helper in start
      Connecting socket for: MMM-ImagesPhotos
      Starting node helper for: MMM-ImagesPhotos
      Connecting socket for: MMM-BMW-DS
      Starting node_helper for: MMM-BMW-DS
      Launching application.
      CyruS1337C 1 Reply Last reply Reply Quote 0
      • CyruS1337C Offline
        CyruS1337 Project Sponsor @sdetweil
        @sdetweil Thanks for the help, I will post my log tonight
          I also see things like you. Here are my logs:
          pi@raspberrypi2:~ $ cd MagicMirror
          pi@raspberrypi2:~/MagicMirror $ npm start
          > magicmirror@2.5.0 start /home/pi/MagicMirror
          > sh run-start.sh
          Loading config ...
          Module helper loaded: MMM-SystemStats
          Module helper loaded: MMM-MyCommute
          Module helper loaded: MMM-GoogleMapsTraffic
          No helper found for module: MMM-PIR-Sensor.
          Module helper loaded: MMM-SoccerLiveScore
          Module helper loaded: MMM-MyCalendar
          Module helper loaded: email
          Server started ...
          Connecting socket for: MMM-SystemStats
          Connecting socket for: MMM-MyCommute
          ====================== Starting node_helper for module [MMM-MyCommute]
          Connecting socket for: MMM-GoogleMapsTraffic
          Starting node_helper for module: MMM-GoogleMapsTraffic
          Connecting socket for: MMM-SoccerLiveScore
          MMM-SoccerLiveScore helper started...
          Connecting socket for: MMM-MyCalendar
          Starting node helper for: MMM-MyCalendar
          Connecting socket for: email
          email helper started ...
          Create new news fetcher for url: https://api.20min.ch/rss/view/1 - Interval: 300000
          Create new news fetcher for url: https://api.20min.ch/rss/view/67 - Interval: 300000
          Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload:  { style: 'standard' }
          Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/zeptrion%40gmail.com/private-75149d8982f910a209e0fe7d0363d75f/basic.ics - Interval: 300000
          listening for emails...
          • cirdanC Offline
            cirdan
            Looks good. What happens when you send a new mail to the emailaddress when the logs shows listening for email?
            Modules MMM-rainfc, MMM-bustimes, MMM-Harmony, MMM-Rijks
              @cirdan said in Problem with the Module "email":
              I could try that :) Also, I have 1 unread email in the folder. But I’m trying to send an email to myself tonight and see what happens.
              I’ll call you tonight
                I sent you an email earlier. Unfortunately, the module still does not show an email and it still says “load”
                  I deleted the folder “email” again and then reinstalled the module. I do not know what the warnings after npm install mean:
                  pi@raspberrypi2:~ $ cd MagicMirror/modules
                  pi@raspberrypi2:~/MagicMirror/modules $ git clone https://github.com/ronny3050/e        mail-mirror.git email
                  Klone nach 'email' ...
                  remote: Enumerating objects: 60, done.
                  remote: Total 60 (delta 0), reused 0 (delta 0), pack-reused 60
                  Entpacke Objekte: 100% (60/60), Fertig.
                  pi@raspberrypi2:~/MagicMirror/modules $ cd email
                  pi@raspberrypi2:~/MagicMirror/modules/email $ npm install
                  npm WARN deprecated mailparser@0.6.2: Mailparser versions older than v2.3.0 are        deprecated
                  npm WARN deprecated mimelib@0.3.1: This project is unmaintained
                  npm notice created a lockfile as package-lock.json. You should commit this file.
                  npm WARN email@0.0.1 No repository field.
                  npm WARN email@0.0.1 No license field.
                  added 21 packages from 18 contributors and audited 24 packages in 9.564s
                  found 0 vulnerabilities
                    sdetweil @CyruS1337
                    @cyrus1337 the warnings mean nothing for users.
                    This module will ONLY show email that arrives AFTER it is started.
                      @sdetweil said in Problem with the Module "email":
                      ok, all right :) but I am not yet. The module will simply not load an email
                        sdetweil @CyruS1337
                        @cyrus1337 I had to reboot to get it to work.
                        • 6
                        • 3 / 6
