    Problem with the Module "email"
    57 Posts 4 Posters 31.7k Views 4 Watching
    • CyruS1337C Offline
      CyruS1337 Project Sponsor @sdetweil
      That’s right, sorry
      > magicmirror@2.8.0 start /home/pi/MagicMirror
      > sh run-start.sh "dev"
      Starting MagicMirror: v2.8.0
      Loading config ...
      Loading module helpers ...
      Module helper loaded: MMM-SystemStats
      Module helper loaded: MMM-Remote-Control
      Module helper loaded: MMM-MyCommute
      Module helper loaded: MMM-AVStock
      Module helper loaded: MMM-GoogleMapsTraffic
      Module helper loaded: MMM-SoccerLiveScore
      Module helper loaded: email
      Module helper loaded: MMM-MyCalendar
      All module helpers loaded.
      Server started ...
      Connecting socket for: MMM-SystemStats
      Connecting socket for: MMM-Remote-Control
      Starting node helper for: MMM-Remote-Control
      Connecting socket for: MMM-MyCommute
      ====================== Starting node_helper for module [MMM-MyCommute]
      Connecting socket for: MMM-AVStock
      Connecting socket for: MMM-GoogleMapsTraffic
      Starting node_helper for module: MMM-GoogleMapsTraffic
      Connecting socket for: MMM-SoccerLiveScore
      MMM-SoccerLiveScore helper started...
      Connecting socket for: email
      email helper started ...
      Connecting socket for: MMM-MyCalendar
      Starting node helper for: MMM-MyCalendar
      { Error: listen EADDRINUSE 0.0.0.0:8080
          at Server.setupListenHandle [as _listen2] (net.js:1330:14)
          at listenInCluster (net.js:1378:12)
          at doListen (net.js:1492:7)
          at process._tickCallback (internal/process/next_tick.js:63:19)
          at Function.Module.runMain (internal/modules/cjs/loader.js:755:11)
          at startup (internal/bootstrap/node.js:241:19)
          at bootstrapNodeJSCore (internal/bootstrap/node.js:579:3)
        errno: 'EADDRINUSE',
        code: 'EADDRINUSE',
        syscall: 'listen',
        address: '0.0.0.0',
        port: 8080 }
      Launching application.
        CyruS1337 Project Sponsor @mumblebaj
        @mumblebaj
        Exactly, I replaced the password with the key. I have also installed npm.
        cd MagicMirror/modules
        cd email
        npm install
        npm WARN email@0.0.1 No repository field.
        npm WARN email@0.0.1 No license field.
        audited 24 packages in 2.521s
        found 0 vulnerabilities
        pm2 logs
        pi@raspberrypi_LOL:~/MagicMirror/modules/email $ pm2 logs
        [TAILING] Tailing last 15 lines for [all] processes (change the value with --lines option)
        /home/pi/.pm2/pm2.log last 15 lines:
        PM2        | 2019-09-07T04:30:05: PM2 log: App [mm:0] online
        PM2        | 2019-09-07T07:40:45: PM2 log: Process 0 in a stopped status, starting it
        PM2        | 2019-09-07T07:40:45: PM2 log: Stopping app:mm id:0
        PM2        | 2019-09-07T07:40:46: PM2 log: pid=20666 msg=failed to kill - retrying in 100ms
        PM2        | 2019-09-07T07:40:46: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
        PM2        | 2019-09-07T07:40:46: PM2 log: pid=20666 msg=process killed
        PM2        | 2019-09-07T07:40:46: PM2 log: App [mm:0] starting in -fork mode-
        PM2        | 2019-09-07T07:40:46: PM2 log: App [mm:0] online
        PM2        | 2019-09-07T07:55:09: PM2 log: Process 0 in a stopped status, starting it
        PM2        | 2019-09-07T07:55:09: PM2 log: Stopping app:mm id:0
        PM2        | 2019-09-07T07:55:10: PM2 log: pid=5504 msg=failed to kill - retrying in 100ms
        PM2        | 2019-09-07T07:55:10: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
        PM2        | 2019-09-07T07:55:10: PM2 log: pid=5504 msg=process killed
        PM2        | 2019-09-07T07:55:10: PM2 log: App [mm:0] starting in -fork mode-
        PM2        | 2019-09-07T07:55:10: PM2 log: App [mm:0] online
        /home/pi/.pm2/logs/mm-error.log last 15 lines:
        0|mm       | SyntaxError: Unexpected token u in JSON at position 0
        0|mm       |     at JSON.parse (<anonymous>)
        0|mm       |     at Request._callback (/home/pi/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js:146:29)
        0|mm       |     at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
        0|mm       |     at Request.emit (events.js:182:13)
        0|mm       |     at Request.onRequestError (/home/pi/MagicMirror/node_modules/request/request.js:881:8)
        0|mm       |     at ClientRequest.emit (events.js:182:13)
        0|mm       |     at TLSSocket.socketErrorListener (_http_client.js:382:9)
        0|mm       |     at TLSSocket.emit (events.js:182:13)
        0|mm       |     at emitErrorNT (internal/streams/destroy.js:82:8)
        0|mm       |     at emitErrorAndCloseNT (internal/streams/destroy.js:50:3)
        0|mm       | ATTENTION: default value of option force_s3tc_enable overridden by environment.
        0|mm       | (node:5525) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
        0|mm       | (node:7860) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
        /home/pi/.pm2/logs/mm-out.log last 15 lines:
        0|mm       | Connecting socket for: email
        0|mm       | email helper started ...
        0|mm       | Connecting socket for: MMM-MyCalendar
        0|mm       | Starting node helper for: MMM-MyCalendar
        0|mm       | Sockets connected & modules started ...
        0|mm       | Launching application.
        0|mm       | [AVSTOCK] Initialized.
        0|mm       | Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload:  { style: 'standard' }
        0|mm       | listening for emails...
        0|mm       | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/zeptrion%40gmail.com/private-75149d8982f910a209e0fe7d0363d75f/basic.ics - Interval: 300000
        0|mm       | NEW MAIL
        0|mm       | NEW MAIL
        0|mm       | NEW MAIL
        0|mm       | NEW MAIL
        0|mm       | NEW MAIL
          sdetweil @CyruS1337
          @CyruS1337 MMM-SoccerLiveScore/ is the one throwing the error… not email
            I have disabled the module, but the mails are still not displayed :(
            	module: 'MMM-SoccerLiveScore',
            	position: 'top_right',
            	header: 'Fussball Rangliste',
            		leagues: [215,399,1],
                    showNames: true,
                    showLogos: true,
                    displayTime: 60 * 1000,
                    showTables: true
              sdetweil @CyruS1337
              @CyruS1337 i don’t know anything about email module, i remember it was hard to get working, i didn;t like the results…
              anyhow… for the commenting out module,
              you can also just add
              disabled: true,
              to the module info, before/after the module name
              disabled: false,
              is the default
                @sdetweil I do not really like the module any more. I’m trying to get it up and running for a year :)
                Thank you very much for your great support
                • mumblebajM Offline
                  mumblebaj Module Developer @CyruS1337
                  @CyruS1337 Please remember, for the emails to display you need to set fade: false.
                  • 6
                  • 6 / 6
