Problem with the Module "email"
57 Posts 4 Posters 25.4k Views 4 Watching
  • S Away
    sdetweil
    i don’t see that on my console… I see
    password
    use your phone
    2-step verification
    M 1 Reply Last reply Sep 5, 2019, 3:09 PM Reply Quote 0
      mumblebaj Module Developer @sdetweil
      @sdetweil Strange. I had to generate a key to get email to work. Not sure why you guys don’t see the option.
      Edit:
      Maybe because your 2FA is turned off.
      S 1 Reply Last reply Sep 5, 2019, 3:17 PM Reply Quote 0
      • S Away
        sdetweil @mumblebaj
        @mumblebaj yes, had to turn on 2fa… hate that
        • C Offline
          CyruS1337 Project Sponsor
          I do not see it either. I see the same as sdetweil. I’ve also approved third-party apps with account access on this page below.
          Can I do something that would help you? Post a log or something. You just have to tell me the command;)
          S M 2 Replies Last reply Sep 5, 2019, 3:24 PM Reply Quote 0
          • S Away
            sdetweil @CyruS1337
            @CyruS1337 you have to turn on 2 step verification (2 factor authentication aka 2fa)
              mumblebaj Module Developer @CyruS1337
              @CyruS1337 I just setup the module and created my app key and email is working for me.
              And my config: I also had to change fade to false in order for email to display properly
                              module: 'email',
                              position: 'top_right',
                              header: 'Email',
                                       accounts: [
                                                      user: 'xxxxxxxxxxxxx@gmail.com',
                                                      password: 'xxxxxxxxxxxxxxxx',
                                                      host:'imap.gmail.com',
                                                      port: 993,
                                                      tls: true,
                                                      authTimeout: 10000,
                                                      numberOfEmails: 5,
                                      fade: false,
                                      maxCharacters: 30
              • C Offline
                Good Morning
                So I activated the 2FA and replaced the generated key with my password. I also took your config and added my username and password from 2FA. Unfortunately, as before, there is still “load” and it does not show any emails.
                M 1 Reply Last reply Sep 6, 2019, 2:05 PM Reply Quote 0
                • C Offline
                  If i enter npm start dev he following will come out:
                  npm ERR! path /home/pi/package.json
                  npm ERR! code ENOENT
                  npm ERR! errno -2
                  npm ERR! syscall open
                  npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                  npm ERR! enoent This is related to npm not being able to find a file.
                  npm ERR! enoent
                  npm ERR!     /home/pi/.npm/_logs/2019-09-06T07_07_27_973Z-debug.log
                  S 1 Reply Last reply Sep 6, 2019, 12:19 PM Reply Quote 0
                  • S Away
                    sdetweil @CyruS1337
                    @CyruS1337 u need to be in the MagicMirror folder before npm start
                    C 1 Reply Last reply Sep 7, 2019, 5:48 AM Reply Quote 0
                      @CyruS1337 I assume that you meant that you replace your password with the generated key? When you run pm2 logs what do you get? Does it show anything for email? Have you in the /modules/email folder run npm install?
                      C 1 Reply Last reply Sep 7, 2019, 5:57 AM Reply Quote 0
                      • 6
                      • 5 / 6
                      5 / 6
