    Calendar Not Loading
    10 Posts 6 Posters 10.8k Views 6 Watching
    • C Offline
      clumsy_ninja
      Hi, I’m having trouble getting my Calendar to load in the default calendar module.
      i have checked the link the and curl/wget downloads it just fine however when MM starts it just shows “Loading…” forever.
      I have two calendars, a google calendar and a office365 calendar. The google calendar loads fine but the office365 displays the issue above.
      Here is my obfuscated config file.
                              module: 'calendar',
                              header: 'Calendar',
                              position: 'top_left',
                                      maximumNumberOfDays: 14,
                                              //      symbol: 'home',
                                              //      url: 'https://calendar.google.com/calendar/ical/username%40gmail.com/private-4342c3561aea50c145ab3ab8320a/basic.ics'
                                                      symbol: 'home',
                                                      url: 'https://outlook.office365.com/owa/calendar/cd2245088f5b4dbfa64ef416b080@company.com.au/cf65756c71a8465e97bb5470c536cce55697333579349617917$
      When i start it with the google one uncommented it loads google fine, but no office365.
      When i start it with the google one commented out, I get:
      pi@raspberrypi:~/MagicMirror $ DISPLAY=:0  npm start
      > magicmirror@2.0.0 start /home/pi/MagicMirror
      > electron js/electron.js
      Loading config ...
      Loading module helpers ...
      All module helpers loaded.
      Starting server op port 8080 ...
      Server started ...
      Starting module: newsfeed
      Launching application.
      Create new calendar fetcher for url: https://outlook.office365.com/owa/calendar/cd2245088f5b4dbfa64ef28e2416@company.com.au/cf65756c71a8465e97bb5470c536cce55697333579349617917/calendar.ics - Interval: 300000
      Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      Create new news fetcher for url: http://feeds.smh.com.au/rssheadlines/top.xml - Interval: 300000
      TypeError: curr.start.toISOString is not a function
          at Object.ical.objectHandlers.END (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:39:40)
          at Object.handleObject (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/ical.js:257:41)
          at Object.parseICS (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/ical.js:298:20)
          at Request._callback (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:11:24)
          at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:186:22)
          at emitTwo (events.js:106:13)
          at Request.emit (events.js:191:7)
          at Request.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1060:10)
          at emitOne (events.js:96:13)
          at Request.emit (events.js:188:7)
      Thanks in advance.
      • C Offline
        clumsy_ninja
        Bump, anyone? Should I put an issue ticket in GitHub?
          andrewchumchal
          @clumsy_ninja I believed the link needs to end in .ics or .rss there should be a way in Office 365 to make a .ics link. I hope this help
          • C Offline
            clumsy_ninja
            @andrewchumchal Sorry, the link does, its just been cut off from how nano has displayed it.
            If i do a wget or curl I get the file just fine.
            • T Offline
              tajno
              No, you dont need an .ics file - I’ve also included four calendars which two without a ics or rss. But its not a wrong idea.
              The followed sounds silly, sorry for that but maybe its a hint: On your posted code I miss a -> ’ <- at the end of the office calendar link, it starts with it but does not close. Maybe the app just ignore the not working value in the URL instead of reply with an error…
              At least I could not find any wrong, but Im not a developer, sorry.
                bhepler Module Developer @clumsy_ninja
                @clumsy_ninja Is there a reason why the URL in your config file is different than the one in your log file? The one in your log file gives me a 404.
                • C Offline
                  clumsy_ninja
                  @tajno the URL is cut off at the “$” sign in the config file because that is how nano displayed it when i copied it. I have double checked it has a ->'<- at the end.
                  @bhepler Again, cut off with the $, sorry. The one in my log file is anonymised, it has the company name changed as I can’t post that calendar URL publicly.
                  • C Offline
                    christopherm
                    having the same issue with the office 365 calender.
                    curl the url works, mm is not displaying it. Any ideas? @clumsy_ninja have you been able to fix it?
                    • C Offline
                      clumsy_ninja
                      @christopherm No, I don’t think I solved it. I actually left that work so didn’t need it anymore.
                      have you checked your output for errors? I was getting the same error as shown in this thread: https://forum.magicmirror.builders/topic/256/typeerror-curr-start-toisostring-is-not-a-function
                      I assume it was the same issue, something todo with a bad ics file.
                        Bangee Module Developer
                        I had the same problem.
                        I was not using https. now it works for me.
