    Mmm-Wunderlist can't show individual lists
    6 Posts 2 Posters 2.4k Views 2 Watching
    • C
      cptkex
      Hi. Second question today.
      I am trying to set up Wunderlist and I have gotten it working, but I can’t solve this problem.
      I have two lists I want to display, a, shopping list and a to do list. I add them both to the array but the module shows them both in the same list. So instead of two lists with entries, I get only one with the entries from both lists in the array. I will add the config. Js code from the pi in a minute, see below
      C 1 Reply Last reply
      • C
        cptkex @cptkex
        @cptkex
                        module: 'MMM-Wunderlist',
                        position: 'bottom_left',// This can be any of the regions. Best$
                        header: 'Matinköp', // This is optional
                        config: {// See 'Configuration options' for more information.
                                accessToken: '******************',
                                clientID: '****************',   //example clientID
                                lists: ['Att göra', 'Matinköp'],
                                interval: 3500,
                                ShowDeadline: true,
                                fade: true,
        • C
          cptkex @cptkex
          @cptkex @paviro perhaps you can offer some advice? i do love your module very much but there is now a big chance that i might go shopping for a kid to drive to the soccer game on saturday ;)
          • joela85J
            joela85
            One way around this might be to put two modules in your config, as shown below. That way you can have a separate header for each.
            Hope this works.
                            header: 'Att göra', // This is optional
                                    lists: ['Att göra'],
                                    interval: 3500,
                                    ShowDeadline: true,
                                    fade: true,
                                    lists: ['Matinköp'],
                                    interval: 3500,
                                    ShowDeadline: true,
                                    fade: true,
            C 2 Replies Last reply
            • C
              cptkex @joela85
              @joela85 hi, thanks for replying!
              i had the same thought so i tried to copy paste the same information but MM told me there was an error in the config.js and did not boot when i tried that method. Since i am still a beginner at this i might have screwed up somewhere, so i am going to try to paste your code instead tonight and try it.
              • C
                cptkex @joela85
                @joela85 this worked like a charm, I must have screwed up the code. I only have to figure out how to place them to not grow upwards when I add items but have a fixed height. Thanks
                Reply Quote 1
