    MMM-GroveGestures
    51 Posts 8 Posters 27.4k Views 12 Watching
    • ? Offline
      A Former User @Screech
      @Screech
      I’m not annexpert so I cannot declare, but…
      I think INT means Interrupt, It can give additional feature about interruptions to device. Anyway I think it would work when INT is not connected, but not sure. Sorry.
        Screech @Guest
        @Sean
        Thank you for the info ;) I just command one to test ;)
        Cya in about 1 month (when I receiv and test it) I give you a feedback then :D
          bolish
          @Benjaminh86
          Here is an extract of mine that should help you to understand. You just have to tweak the notification and pages based on your setup.
          			// 22
          			module: "MMM-GroveGestures",
          				autoStart: true, //When Mirror starts, recognition will start.
          				verbose:true, // If set as `true`, useful messages will be logged.
          				recognitionTimeout: 1000, //Gesture sequence will be ended after this time from last recognized gesture.
          				cancelGesture: "WAVE", //If set, You can cancel gesture sequence with this gesture.
          				visible: true, //Recognized gesture sequence will be displayed on position
          				idleTimer: "0", // `0` for disable, After this time from last gesture, onIdle will be executed.
          				defaultCommandSet: "DEFAULT_MODE",
          				commandSet: {
          					"DEFAULT_MODE": {
          							"LEFT": {
          						        notificationExec: {
          						          notification: "PAGE_INCREMENT",
          							"RIGHT": {
          						        notificationExec: {
          						          notification: "PAGE_DECREMENT",
          					"0": { // this corresponds to the page N° sent back by MMM-Pages
          							"LEFT": {
          						        notificationExec: {
          							"RIGHT": {
          						        notificationExec: {
          							"UP": {
          						        notificationExec: {
          						          notification: "CALEXT2_SCENE_NEXT",
                						              payload: null,
          							"DOWN": {
          						        notificationExec: {
          						          notification: "CALEXT2_SCENE_PREVIOUS",
                						              payload: null,
          					"1": {
          						        "LEFT-RIGHT-LEFT": {
          						        notificationExec: {
          						          notification: "REMOTE_ACTION",
          							    payload: {
          							  	action: "SHOW",
          							  	module: "module_13_MMM-BackgroundSlideshow",
          						        "RIGHT-LEFT-RIGHT": {
          						        notificationExec: {
          							    payload: {
          							  	action: "HIDE",
          						        "UP-DOWN-UP": {
          						        notificationExec: {
          							    payload: {
          							  	action: "SHOW",
          							  	module: "module_14_MMM-BackgroundSlideshowInfo",
          		        				"DOWN-UP-DOWN": {
          						        notificationExec: {
          							    payload: {
          							  	action: "HIDE",
          							"LEFT": {
          						        notificationExec: {
          							"RIGHT": {
          						        notificationExec: {
          							"UP": {
          						        notificationExec: {
          						          notification: "ARTICLE_MORE_DETAILS",
          							"DOWN": {
          						        notificationExec: {
          						          notification: "ARTICLE_LESS_DETAILS",
          							"CLOCKWISE": {
          						        notificationExec: {
          						          notification: "BACKGROUNDSLIDESHOW_NEXT",
          							"ANTICLOCKWISE": {
          						        notificationExec: {
          						          notification: "ARTICLE_PREVIOUS",
          					"2": {
          							"LEFT": {
          						        notificationExec: {
          							"RIGHT": {
          						        notificationExec: {
          							"UP": {
          						        notificationExec: {
          						          notification: "SWD_NEXT",
          							"DOWN": {
          						        notificationExec: {
          						          notification: "SWD_PREV",
          							"FORWARD-BACKWARD": {
          						        notificationExec: {
          						          notification: "SWD_PAUSE",
          							"BACKWARD-FORWARD": {
          						        notificationExec: {
          						          notification: "SWD_PLAY",
          					commandSetTrigger: {
          					  "DEFAULT_MODE": "DEFAULT_MODE",
            					  "PAGE_NUMBER_IS": (payload) => { return payload } // this is what set the right command set based on MMM-Pages feedback "PAGE_NUMBER_IS"
          			//22
          			module: "MMM-NotificationTrigger",
          				useWebhook: false,
          				triggers: [
          						// Is hiding the compliments module when newsfeed article is toggled fullscreen
          						trigger: "ARTICLE_MORE_DETAILS",
          						fires: [
          								fire: "REMOTE_ACTION",
          								  payload: {
              									action: "HIDE",
              									module: "module_6_compliments",
          						// Is showing the compliments module again when newsfeed is minimized.
          						trigger: "ARTICLE_LESS_DETAILS",
          						fires: [
          								  payload: {
              									action: "SHOW",
          						// Is triggering PAGE NUMBER NOTIFICATION when pages is changing
          						trigger: "PAGE_DECREMENT",
          						fires: [
          								fire: "QUERY_PAGE_NUMBER",
          						trigger: "PAGE_INCREMENT",
          						fires: [
          						// Slideshow_Show.
          						trigger: "SLIDESHOW_SHOW",
          						fires: [
          								  payload: {
              									action: "SHOW",
          						// Slideshow_Hide.
          						trigger: "SLIDESHOW_HIDE",
          						fires: [
          								  payload: {
              									action: "HIDE",
          						// SlideshowInfo_Show.
          						trigger: "SLIDESHOWINFO_SHOW",
          						fires: [
          								  payload: {
              									action: "SHOW",
          						// SlideshowInfo_Hide.
          						trigger: "SLIDESHOWINFO_HIDE",
          						fires: [
          								  payload: {
              									action: "HIDE",
          						fires: [
          								  payload: {
              									action: "SHOW",
          						// AT START - Is hiding MMM-ImageSlideshow at start.
          						trigger: "ALL_MODULES_STARTED",
          						fires: [
          								  payload: {
              									action: "HIDE",
          								  payload: {
              									action: "HIDE",
          								fire: "PAGE_INCREMENT",
          						// SHUTDONW - turns screen off and shutdown pi
          						trigger: "SCREENOFFSHUTDOWN",
          						fires: [
          								  payload: {
              									action: "MONITOROFF",
          								  payload: {
              									action: "SHUTDOWN",
          B 2 Replies Last reply Reply Quote 0
            Benjaminh86 @bolish
            Hello @bolish,
            thanks for sharing the script. I will watch this carefully ;)
            BenH
              Benjaminh86 @bolish
              @bolish
              I see in your MMM-notificationtrigger module that you have a MONITOROFF action.
              I imagine that we can associate a gesture command in Grove Gestures, for example: I make the gesture high, it turns on the screen.
              I would like to do that but I do not understand how to integrate it into Grove Gestures …
              If I do :
              “UP”: {
              notificationExec: {
              notification: “REMOTE_ACTION”,
              payload: {
              action: “MONITORON”,
              module: “MMM-Remote-Control”,
              And in MMM-notificationtrigger:
              // MONITOR_ON - turns screen on
              trigger: “MONITOR_ON”,
              fires: [
              fire: “REMOTE_ACTION”,
              payload: {
              is it good?..
                bolish
                @Benjaminh86
                Not really…
                “MONITORON” is already an action which is managed by MMM-REMOTECONTROL so you don’t need MMM-Notificationtrigger for that.
                You just need MMM-GroveGesture to send it :
                		        				"UP": {
                						        notificationExec: {
                							    payload: {
                							  	action: "MONITORON",
                								     },	 // you don't need to refer to a module name for the MONITORONN action (only necessary for HIDE and SHOW)
                But you need to make sure that MMM-REMOTEControl is configured in the right way so that when it receives “MONITORON” it sends the right command (depending if you use HDMI, CEC, etc…)
                Regards
                  Benjaminh86 @bolish
                  @bolish
                  thank you
                  when you say: “But you need to make sure that MMM-REMOTEControl is configured in the right way”, when I send the request http://192.168.xxx.xxx:8080…MONITOROFF, it works.
                  is that enough, or do I have to add something to the MMM-Remote-Control script?
                    bolish
                    No, if it’s works by sending the request, it should work with Gesture also!
                      Benjaminh86 @bolish
                      @bolish
                      Great!
                      I will try tonight the adaptation I made of your script.
                      I put the action “MONITOROFF” in the “Default_Mode” part of Grove Gestures, that’s it?
                        Benjaminh86 @bolish
                        Hello @bolish,
                        thanks to you! everything is working!
                        however, I thought Grove Gestures would activate automatically, but I have to make the command line for the sensor to be active:
                        cd ~ / MagicMirror / modules / MMM-GroveGestures / py
                        cp grove_gesture_sensor.py.RPI grove_gesture_sensor.py
                        Is this normal?
                        Another question about MMM-Pages; I would like to display the Google Calendar calendar on page 1 and the holiday calendar on page 2, but I do not know how to differentiate and name them on MMM-Pages …
                        Do you have an idea?
                        • ? Offline
                          A Former User @Benjaminh86
                          @Benjaminh86 said in MMM-GroveGestures:
                          It is described on instruction for installation. And that command is not for activation. I provide 2 scripts for each of Raspberry Pi and Asus TinkerBoard. you need to select one for your device. You don’t need to do that job again after once you did.
                          The real activation would be performed in the module itself on every running of MM.
                            bolish
                            @Benjaminh86
                            You have to search a bit on the forum.
                            One idea could be to create 2 calendars instances.
                            See below post extract :
                            well… I believe it’s far from being perfect…but at least it seems to do the job…
                            I created a “new” module which does exactly same / has the same code as the one I want to use, but has a different name (folder named “MMM-Calendar2” -> file named “MMM-Calendar2.js” -> within the line Module.register(‘MMM_Calendar2’)).
                            Not in the default module folder but into the 3rd party module folder…
                            And put instance 1 on page 1 and isntance 2 on page 2.
                              Benjaminh86 @Guest
                              Hello @Sean,
                              I will look at this in more detail in the module.
                              Thank you again for your work.
                                Benjaminh86 @bolish
                                @bolish
                                I will explore this track.
                                Thanks to you ; you already helped me a lot!
                                  Benjaminh86 @Guest
                                  @Sean
                                  it’s weird; the sensor is not active if I do not order:
                                  would not it come from “chmod + x * .sh” where I hurt something? …
                                    Benjaminh86 @bolish
                                    @bolish
                                    it works!
                                    thanks for your help
                                    • ? Offline
                                      @Benjaminh86
                                      Can’t understand.
                                      Do you need to do that shell command per every execution of MM? Have you reinstalled it?
                                      That commands just need to be done once when you install this module.
                                      And that command isn’t related with chmod + x .sh at all.
                                      Check this.
                                      ls ~/MagicMirror/modules/MMM-GroveGestures/py
                                      There should be grove_gesture_sensor.py besides grove_gesture_sensor.py.RPI and grove_gesture_sensor.py.ATB.
                                      Are those files there?
                                        Benjaminh86 @Guest
                                        @Sean
                                        I have to make this command every start of the pi, knowing that I do not start the MM automatically (pmm2) time to set everything (npm start).
                                        I’ll be watching tonight with
                                        ls ~ / MagicMirror / modules / MMM-GroveGestures / py
                                          Benjaminh86 @Guest
                                          @Sean
                                          That’s what happens :
                                          pi@raspberrypi:~ $ ls ~/MagicMirror/modules/MMM-GroveGestures/py
                                          gesture_print.py grove_gesture_sensor.pyc
                                          grove_gesture_sensor.py grove_gesture_sensor.py.RPI
                                          • ? Offline
                                            @Benjaminh86
                                            If you have those files, you don’t need to execute any manual commands o n MM running
                                            • 2 / 3
