    Why keeps MM2 starting even when I've pressed ctrl+Q?
    4 Posts 3 Posters 1.8k Views 3 Watching
    • M
      MWel1977
      I just have installed MM2 and I would like to make changes now to the setup of MM2 but when I press Alt and close the MM2 (or use Ctrl+Q) after a few seconds MM2 is up and running agian!!
      How can I stop this? I would like to have MM2 to start after the Pi has booted or after I started it from the commanline. Not on it’s own!
      S lavolp3L 2 Replies Last reply
        sdetweil @MWel1977
        @mwel1977 I use an ssh session from my Windows box and kill the npm start process. Actually a little script kills all node related tasks
        • M
          MWel1977
          @sdetweil: I’m just starting with a raspberry pi (well… I have Domoticz running on a Pi zero W to check my plants) so I have no idea how to make/write a script like that.
          But I just rebooted my pi and MM2 didn’t start. So I can make changes to the setting now and start MM2 via the commandline.
          • lavolp3L
            lavolp3 Module Developer @MWel1977
            @mwel1977 The reason seems to be pm2. You seem to have that installed. It runs a script always restarting MagicMirror after you close it.
            To close MagicMirror properly if you have pm2 running do a
            pm2 stop mm
            or however your process was called. You can find the name of the process running
            pm2 status
            Other useful commands
            pm2 restart mm
            pm2 start mm.sh //Name of the shell file that has been created by YOU!
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
