    Can't find out what I did wrong in my config.js...
    7 Posts 3 Posters 2.5k Views 3 Watching
    • Cr4z33C Offline
      Cr4z33
      First of all why are all online JavaScript linters completely useless for our config.js file? :thinking_face:
      They all report completely no sense mistakes while the REAL error might be located in somewhere else line.
      Now back in topic I might have edited/canceled something that has screwed up the file by ending with the CONFIG.JS screen when launching MM. :face_with_cold_sweat:
      Can someone please help me finding the mistake?
      https://pastebin.com/BAQTi012
      • evroomE Offline
        evroom
        Perhaps this is a start, provided I copy/pasted it right ?
        Although I think you are familiar with this and used other linters to find the ‘mistake’.
        pi@MagicPi:~/MagicMirror $ cd ~/MagicMirror; npm run config:check
        Checking file...  /home/pi/MagicMirror/config/config.js
        Line 213 col 42 Missing semicolon.
        Line 218 col 18 Missing semicolon.
        Line 222 col 5 Expected '}' to match '{' from line 190 and instead saw '{'.
        Line 223 col 7 Expected ']' to match '[' from line 28 and instead saw 'module'.
        Line 223 col 13 Expected '}' to match '{' from line 11 and instead saw ':'.
        Line 223 col 14 Missing semicolon.
        Line 224 col 7 Expected an assignment or function call and instead saw an expression.
        Line 224 col 15 Missing semicolon.
        Line 224 col 7 Unrecoverable syntax error. (94% scanned).
        I think you missed a } around line 220.
        The “Missing semicolon” messages normally are just nitpicking, but the "Expected ‘}’ to match ‘{’ " are usually true.
        MagicMirror version: 2.35.0
        Test environment:
        MagicMirror version: 2.36.0-develop
        Cr4z33C 2 Replies Last reply Reply Quote 0
        • Cr4z33C Offline
          Cr4z33 @evroom
          @evroom thanks for the help I give it immediately a look. :)
          Also didn’t know that terminal command.
          • Cr4z33C Offline
            Cr4z33 @evroom
            @evroom found out the mistake thanks to your suggestion:
            I missed to add an additional close curly bracket after line 213!
            • evroomE Offline
              evroom
              Glad to help.
              So many errors after only one mistake (the most common to make; we all did it sometime I guess) :slightly_smiling_face:
              Test environment:
              • Cr4z33C Offline
                Cr4z33 @evroom
                @evroom lol indeed! :grinning_face_with_smiling_eyes:
                • BKeyportB Offline
                  BKeyport Module Developer
                  Wait, you can audit the config file right from NPM?
                  Daaaaaaaaaaaaaaaaaaaang.
