    MMM-Modal
    modaldialogtouch controlvoice control
    14 Posts 5 Posters 7.1k Views 4 Watching
    • strawberry 3.141S
      I tweaked my modal that I’m using in some of my modules. Instead of duplicating this all over the place I created a new module for a single source of truth and so it can also be used by other devs/users.
      [card:fewieden/MMM-Modal]
      Modal and dialog windows with touch, voice and non input support.
      I just started building it so it might still have some bugs.
      Developer Guide
      1 Reply Last reply Reply Quote 5
      • cowboysdudeC
        cowboysdude Module Developer
        • strawberry 3.141S
          [1.0.1]
          Fixed
          • Modal positioning
          • Blur on render error
          Added
          • List of depending modules
          • Callback option after render for developers
          Changed
          • ESLint ruleset from airbnb to recommended
          • Moved nunjuck templates in separate directory
          • node versions for travis
          Removed
          • doclet integration
          https://github.com/fewieden/MMM-Modal
            skuethe
            I really like this module, especially with touch screen usage.
            The implementation is easy but still very powerful.
            F.e. I added support for the following two modules:
            • https://github.com/TeraTech/MMM-WiFiPassword
            • https://github.com/skuethe/MMM-Spotify
            In MMM-Spotify it is used to display account / device selection popups on screen. The available callback payload function makes this work in the first place, as we (of course) need to react on the made user selections :)
            So again, great module, thanks!
            • strawberry 3.141S
              With MMM-ip another module has now integrated the modals. See the full list at https://github.com/fewieden/MMM-Modal/wiki/Depending-Modules
              • strawberry 3.141S
                With MMM-soccer another module has now integrated the modals.
                Standings modal
                  A Former User
                  This post is deleted!
                  S S strawberry 3.141S 3 Replies Last reply Reply Quote 0
                    sdetweil @Guest
                    @hango said in MMM-Modal:
                    template: “templates/MyModal.njk”,
                    I think u need
                    template: "../modulename/templates/MyModal.njk",
                    to make it relative to your module
                    instead of the modal module
                      skuethe @Guest
                      I make my modal:
                      this.sendNotification("OPEN_MODAL", {
                      	template: "templates/MyModal.njk",
                      	data: {
                      		title: "Test modal",
                      		message: "Test message"
                      	options: {
                      		isDialog: true
                      in console I get this:
                      nunjucks.min.js:4 GET http://localhost:8081/modules//modal/templates/modal.njk?s=1634300311396 404 (Not Found)
                      templates/MyModal.njk doesn’t really fit with the error message templates/modal.njk?! Sure you have specified the correct path?
                      Referencing it to within your module path works just fine: template: "templates/MyModal.njk",
                      If this is possible…
                      That seems a bit rude. Just look at the linked modules in this thread which have this implemented successfully.
                        A Former User @sdetweil
                          A Former User
                            sdetweil @Guest
                            @hango is a bug, doesn’t use the template name
                            edit the MMM-Modal.js , add the one line below after line 236
                                        if (!sender) {
                                            modal = {
                                                identifier: this.identifier,
                                                senderName: this.name,
                                                template: 'templates/HelpModal.njk',
                                                data: this.voice,
                                                options: {}
                                        } else {
                                            modal.senderName = sender.name;
                                            modal.identifier = sender.identifier;
                                            modal.options = modal.options || {};
                                            modal.data = modal.data || {};
                                            modal.template:  modal.template || 'templates/HelpModal.njk',  // add this line
                            • strawberry 3.141S
                              strawberry 3.141 Project Sponsor Module Developer @Guest
                              @hango I responded with an MVP of a custom module using the modal in the related Github issue https://github.com/fewieden/MMM-Modal/issues/17
                              • strawberry 3.141S
                                With MMM-NFL another module has now integrated the modals.
                                Statistic modal
