    MMM-Modal
    modaldialogtouch controlvoice control
    14 Posts 5 Posters 5.2k Views 4 Watching
    • ? Offline
      A Former User
      This post is deleted!
        sdetweil @Guest
        @hango is a bug, doesn’t use the template name
        edit the MMM-Modal.js , add the one line below after line 236
                    if (!sender) {
                        modal = {
                            identifier: this.identifier,
                            senderName: this.name,
                            template: 'templates/HelpModal.njk',
                            data: this.voice,
                            options: {}
                    } else {
                        modal.senderName = sender.name;
                        modal.identifier = sender.identifier;
                        modal.options = modal.options || {};
                        modal.data = modal.data || {};
                        modal.template:  modal.template || 'templates/HelpModal.njk',  // add this line
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @Guest
          @hango I responded with an MVP of a custom module using the modal in the related Github issue https://github.com/fewieden/MMM-Modal/issues/17
            With MMM-NFL another module has now integrated the modals.
            Statistic modal
            See the full list at https://github.com/fewieden/MMM-Modal/wiki/Depending-Modules
