    MMM-Modal
    modaldialogtouch controlvoice control
    14 Posts 5 Posters 7.1k Views 4 Watching
      skuethe
      I really like this module, especially with touch screen usage.
      The implementation is easy but still very powerful.
      F.e. I added support for the following two modules:
      • https://github.com/TeraTech/MMM-WiFiPassword
      • https://github.com/skuethe/MMM-Spotify
      In MMM-Spotify it is used to display account / device selection popups on screen. The available callback payload function makes this work in the first place, as we (of course) need to react on the made user selections :)
      So again, great module, thanks!
      • strawberry 3.141S
        With MMM-ip another module has now integrated the modals. See the full list at https://github.com/fewieden/MMM-Modal/wiki/Depending-Modules
        • strawberry 3.141S
          With MMM-soccer another module has now integrated the modals.
          Standings modal
            A Former User
            S S strawberry 3.141S 3 Replies Last reply
              sdetweil @Guest
              @hango said in MMM-Modal:
              template: “templates/MyModal.njk”,
              I think u need
              template: "../modulename/templates/MyModal.njk",
              to make it relative to your module
              instead of the modal module
              ? 1 Reply Last reply
                skuethe @Guest
                I make my modal:
                this.sendNotification("OPEN_MODAL", {
                	template: "templates/MyModal.njk",
                	data: {
                		title: "Test modal",
                		message: "Test message"
                	options: {
                		isDialog: true
                in console I get this:
                nunjucks.min.js:4 GET http://localhost:8081/modules//modal/templates/modal.njk?s=1634300311396 404 (Not Found)
                templates/MyModal.njk doesn’t really fit with the error message templates/modal.njk?! Sure you have specified the correct path?
                Referencing it to within your module path works just fine: template: "templates/MyModal.njk",
                If this is possible…
                That seems a bit rude. Just look at the linked modules in this thread which have this implemented successfully.
                  A Former User @sdetweil
                    A Former User
                      sdetweil @Guest
                      @hango is a bug, doesn’t use the template name
                      edit the MMM-Modal.js , add the one line below after line 236
                                  if (!sender) {
                                      modal = {
                                          identifier: this.identifier,
                                          senderName: this.name,
                                          template: 'templates/HelpModal.njk',
                                          data: this.voice,
                                          options: {}
                                  } else {
                                      modal.senderName = sender.name;
                                      modal.identifier = sender.identifier;
                                      modal.options = modal.options || {};
                                      modal.data = modal.data || {};
                                      modal.template:  modal.template || 'templates/HelpModal.njk',  // add this line
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @Guest
                        @hango I responded with an MVP of a custom module using the modal in the related Github issue https://github.com/fewieden/MMM-Modal/issues/17
                        • strawberry 3.141S
                          With MMM-NFL another module has now integrated the modals.
                          Statistic modal
