    MMM-Modal
    modaldialogtouch controlvoice control
    14 Posts 5 Posters 7.0k Views 4 Watching
    • strawberry 3.141S Offline
      With MMM-ip another module has now integrated the modals. See the full list at https://github.com/fewieden/MMM-Modal/wiki/Depending-Modules
        With MMM-soccer another module has now integrated the modals.
        Standings modal
          A Former User
          S S strawberry 3.141S 3 Replies Last reply Reply Quote 0
            sdetweil @Guest
            @hango said in MMM-Modal:
            template: “templates/MyModal.njk”,
            I think u need
            template: "../modulename/templates/MyModal.njk",
            to make it relative to your module
            instead of the modal module
              skuethe @Guest
              I make my modal:
              this.sendNotification("OPEN_MODAL", {
              	template: "templates/MyModal.njk",
              	data: {
              		title: "Test modal",
              		message: "Test message"
              	options: {
              		isDialog: true
              in console I get this:
              nunjucks.min.js:4 GET http://localhost:8081/modules//modal/templates/modal.njk?s=1634300311396 404 (Not Found)
              templates/MyModal.njk doesn’t really fit with the error message templates/modal.njk?! Sure you have specified the correct path?
              Referencing it to within your module path works just fine: template: "templates/MyModal.njk",
              If this is possible…
              That seems a bit rude. Just look at the linked modules in this thread which have this implemented successfully.
                A Former User @sdetweil
                  A Former User
                    sdetweil @Guest
                    @hango is a bug, doesn’t use the template name
                    edit the MMM-Modal.js , add the one line below after line 236
                                if (!sender) {
                                    modal = {
                                        identifier: this.identifier,
                                        senderName: this.name,
                                        template: 'templates/HelpModal.njk',
                                        data: this.voice,
                                        options: {}
                                } else {
                                    modal.senderName = sender.name;
                                    modal.identifier = sender.identifier;
                                    modal.options = modal.options || {};
                                    modal.data = modal.data || {};
                                    modal.template:  modal.template || 'templates/HelpModal.njk',  // add this line
                      strawberry 3.141 Project Sponsor Module Developer @Guest
                      @hango I responded with an MVP of a custom module using the modal in the related Github issue https://github.com/fewieden/MMM-Modal/issues/17
                        With MMM-NFL another module has now integrated the modals.
                        Statistic modal
