    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 915.5k Views 74 Watching
      sdetweil @BD0G
      @BD0G the right side should open up as white.
      Do this
      pm2 stop 0
      cd ~/MagicMirror
      npm start dev
      That will start mm with the dev window open
        sdetweil @BD0G
        @BD0G last letter is i , lower case (ice), not L lowercase
          BD0G
          Yup. Thats what I pressed CTRL-SHIFT-lowercase i. Nothing. Strange eh? I will try the method above.
            BD0G
            Well that did not display the DEV console either. Just Magic Mirror standard display. I have my display rotated 90 degree’s if thats a concern. So its in Portrait Mode essentially and not Landscape.
              BD0G
              Ahh looks like the console was behind Magic Mirror and has these entries.
                sdetweil @BD0G
                @BD0G yeh, don’t know what happens in portrait mode
                  BD0G
                  [16:51:14.569] [LOG] Starting MagicMirror: v2.10.0-develop
                  [16:51:14.714] [LOG] Loading config …
                  [16:51:14.985] [LOG] Loading module helpers …
                  0 [LOG] Initializing new module helper …
                  0 [LOG] Module helper loaded: MMM-Remote-Control
                  0 [LOG] No helper found for module: MMM-DarkSkyForecast.
                  0 [LOG] No helper found for module: alert.
                  [16:51:16.448] [LOG] Initializing new module helper …
                  [16:51:16.469] [LOG] Module helper loaded: updatenotification
                  [16:51:16.486] [LOG] No helper found for module: clock.
                  [16:51:21.582] [LOG] Initializing new module helper …
                  [16:51:21.589] [LOG] Module helper loaded: calendar
                  0 [LOG] All module helpers loaded.
                  [16:51:21.619] [LOG] Starting server on port 8080 …
                  [16:51:21.765] [INFO] You’re using a full whitelist configuration to allow for all IPs
                  0 [LOG] Server started …
                  0 [LOG] Connecting socket for: MMM-Remote-Control
                  0 [LOG] Starting node helper for: MMM-Remote-Control
                  0 [LOG] Connecting socket for: updatenotification
                  0 [LOG] Connecting socket for: calendar
                  0 [LOG] Starting node helper for: calendar
                  0 [LOG] Sockets connected & modules started …
                  0 [LOG]
                  Ready to go! Please point your browser to: http://0.0.0.0:8080
                  Starting chromium browser now, have patience, it takes a minute
                  [16:51:23.548] [ERROR] { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                  at Server.setupListenHandle [as _listen2] (net.js:1280:14)
                  at listenInCluster (net.js:1328:12)
                  at doListen (net.js:1461:7)
                  at process._tickCallback (internal/process/next_tick.js:63:19)
                  at Function.Module.runMain (internal/modules/cjs/loader.js:834:11)
                  at startup (internal/bootstrap/node.js:283:19)
                  at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                  code: ‘EADDRINUSE’,
                  errno: ‘EADDRINUSE’,
                  syscall: ‘listen’,
                  address: ‘0.0.0.0’,
                  port: 8080 }
                  [16:51:29.611] [ERROR] ERROR! Could not find main module js file for MMM-darkSkyForecast
                    sdetweil @BD0G
                    @BD0G said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                    ah, you have the old one running still
                    pm2 start 0
                    check to make sure its shut down
                    ps -ef | grep node
                      BD0G
                      How about I do a full shut down /power off?
                        sdetweil @BD0G
                        @BD0G no… it will autostart on reboot (at least it should)
                          @BD0G but this could be a clue
                          the system is case sensitive…
                          so, the module name in config.js is 'MMM-DarkSkyForecast"
                          (notice u have a lowercase d)
                          the folder in modules, should be the same MMM-DarkSkyForecast ( created from the git clone)
                            BD0G
                            Just checked and the module name in the module directory is
                            MMM-darkSkyForecast and that was created by git cloning as stated in the instructions from the GitHub Repository.
                            So the name of the directory DOES have a lowercase d in it.
                              sdetweil @BD0G
                              @BD0G can’t be
                              git clone https://github.com/jclarke0000/MMM-DarkSkyForecast.git
                              will produce folder MMM-DarkSkyForecast
                                sdetweil @BD0G
                                @BD0G what are the filenames INSIDE the folder?
                                  BD0G
                                  When I issue the ps -ef | grep node
                                  it returns pi 988 811 3 17:20 pts/0 00:00:00 grep --color=auto node
                                    sdetweil @BD0G
                                    @BD0G ok, and how about
                                    ps -ef | grep chromium
                                      BD0G
                                      Here is the response
                                      pi 904 588 30 17:22 ? 00:00:14 /usr/lib/chromium-browser/chromium-browser --disable-quic --enable-tcp-fast-open --enable-pinch
                                      pi 924 904 3 17:22 ? 00:00:01 /usr/lib/chromium-browser/chromium-browser --type=zygote
                                      pi 926 924 0 17:22 ? 00:00:00 /usr/lib/chromium-browser/chromium-browser --type=zygote
                                      pi 947 904 21 17:22 ? 00:00:08 /usr/lib/chromium-browser/chromium-browser --type=gpu-process --field-trial-handle=7332482715831649297,2455911672236890155,131072 --gpu-preferences=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 --service-request-channel-token=5493558882893021086
                                      pi 951 904 6 17:22 ? 00:00:02 /usr/lib/chromium-browser/chromium-browser --type=utility --field-trial-handle=7332482715831649297,2455911672236890155,131072 --lang=en-US --service-sandbox-type=network --disable-quic --service-request-channel-token=14967951688445977275 --shared-files=v8_context_snapshot_data:100,v8_natives_data:101
                                      pi 1034 926 6 17:23 ? 00:00:01 /usr/lib/chromium-browser/chromium-browser --type=renderer --field-trial-handle=7332482715831649297,2455911672236890155,131072 --lang=en-US --instant-process --enable-offline-auto-reload --enable-offline-auto-reload-visible-only --num-raster-threads=1 --service-request-channel-token=17867901049141360113 --renderer-client-id=7 --no-v8-untrusted-code-mitigations --shared-files=v8_context_snapshot_data:100,v8_natives_data:101
                                      pi 1135 926 15 17:23 ? 00:00:03 /usr/lib/chromium-browser/chromium-browser --type=renderer --field-trial-handle=7332482715831649297,2455911672236890155,131072 --lang=en-US --extension-process --enable-offline-auto-reload --enable-offline-auto-reload-visible-only --num-raster-threads=1 --service-request-channel-token=8805285444412210348 --renderer-client-id=4 --no-v8-untrusted-code-mitigations --shared-files=v8_context_snapshot_data:100,v8_natives_data:101
                                      pi 1189 926 16 17:23 ? 00:00:03 /usr/lib/chromium-browser/chromium-browser --type=renderer --field-trial-handle=7332482715831649297,2455911672236890155,131072 --lang=en-US --extension-process --enable-offline-auto-reload --enable-offline-auto-reload-visible-only --num-raster-threads=1 --service-request-channel-token=2818717241021702166 --renderer-client-id=5 --no-v8-untrusted-code-mitigations --shared-files=v8_context_snapshot_data:100,v8_natives_data:101
                                      pi 1210 947 0 17:23 ? 00:00:00 /usr/lib/chromium-browser/chromium-browser --type=broker
                                      pi 1217 811 0 17:23 pts/0 00:00:00 grep --color=auto chromium
                                        BD0G @sdetweil
                                        Pinky Swear!
                                        It did produce a directory with a lowercase d in the name.
                                        Here is listing of the directories under modules
                                        pi@raspberrypi:~/MagicMirror/modules $ dir
                                        default MMM-darkSkyForecast MMM-Remote-Control node_modules README.md
                                          sdetweil @BD0G
                                          @BD0G ok,
                                          pm2 stop 0
                                          should have worked
                                          sudo killall chromium-browser
                                            sdetweil @BD0G
                                            MMM-darkSkyForecast
                                            thanks…
                                            ls ~/MagicMirror/modules/MMM-darkSkyForecast
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
