iFrame with username and password
5 Posts 4 Posters 1.7k Views 5 Watching
  • N Offline
    Nox
    im trying to change the iframe module so it can handle password protected sites but it wont work
    any tips?
    /* Magic Mirror Config Sample
     * MIT Licensed.
    var config =
        port: 8080,
        language: "de",
        timeFormat: 24,
        units: "metric",
    		//MODUL
    				module: 'iFrame',
    				position: 'bottom_center',	// This can be any of the regions.
    							url: ["https://www.stundenplan24.de/20070498/vplan/"],  // as many URLs you want or you can just ["ENTER IN URL"] if single URL.
    							//updateInterval: 0.5 * 60 * 1000, // rotate URLs every 30 seconds
    							width: "100%", // Optional. Default: 100%
    							height: "100px" //Optional. Default: 100px
    /* global Module */
    /* Magic Mirror
     * Module: iFrame
     * By Ben Williams http://desertblade.com
     * MIT Licensed.
    Module.register("iFrame",{
    		// Default module config.
    		defaults: {
    				height:"300px",
    				width:"100%"
    	// Override dom generator.
    	getDom: function() {
    		var iframe = document.createElement("iframe");
            iframe.id="framer";
    		iframe.style = "border:0";
    		iframe.width = this.config.width;
    		iframe.height = this.config.height;
    		//iframe.src =  this.config.url;
            /*var iframeURL = this.config.url;
            var iframeID = "framer";
            var req = new XMLHttpRequest();
            req.open("POST",this.iframeURL,false, "username", "password");
            req.send();
            var iFrameWin =document.getElementbyID(this.iframeID);*/
            iFrameWin.src = "google.de";
            //this.iframeURL + "?extraParameters=true";
    		return iframe;
      rudibarani Project Sponsor
      Hi Nox,
      did you find a solution for this?
      Best,
      Phillip
        majdzik84
        Has anyone found a solution?
        • C Offline
          Chris
          Good morning all,
          I also encounter this kind of problem. I would like to insert a frame of a Jeedom design representing the state of my connected objects throughout the house. But at the first connection I am supposed to enter the username and password as well as checked the box “register this computer”
          If I manage to get past this stage and the computer (finally the browser) is registered, I will be able to access this type of design later which will return all the information of the house to me:
          Could someone help me with this fix?
          Thanking you in advance,
          Regards,
            majdzik84
            Chris check this https://support.actiontiles.com/en/communities/12/topics/2916-logging-into-actiontiles-in-iframe-with-no-keyboard
            its work for me
