    MMM-CalendarExt2
    486 Posts 83 Posters 949.3k Views 83 Watching
    • ? Offline
      A Former User @JHermann
      @JHermann
      Well , this kind of problem is not related to installation. Reinstall might solve the issue, but we don’t know why and how. And there is still possibility of not-solving.
      The most common pitfall might be mistyping.
      position: "top- right",
      This is not a proper symbol of top_right region.
        JHermann @Guest
        @Sean Good point, that was a definite typo.
        • H Offline
          Hram2008
          Multiple Icon in upcoming View
          Please confirm how I can add more then one Icon in the upcoming view, I used the Transform event in "Views"but I can only get one icon to show…
          • ? Offline
            A Former User @Hram2008
            @Hram2008
            Not possible. Why do you need? By the case, I could consider that feature, but normally, why is it needed?
            You can transform the title to use emoji instead icon.
            • H Offline
              Hram2008 @Guest
              @Sean
              Sorry, I am not not able attach an image. What i am trying to do is is the Transform event with specific text to add an emoji to the upcoming view… i.e Calendar event with “Birthday” in name would add a Birthday cake emoji to the event… I want to do this for other text… " Christmas" = x-mas Tree emoji…where other text would display other emoji…
              • ? Offline
                @Hram2008
                First, I’m not sure emoji could be displayable on Electron(Chromium) of Raspbian without any additional things(font?). I have no RPI at this moment, so can’t test.
                But I believe it could, And at least, on my other SBCs, it works.
                Frankly says, How to transform exists already in the wiki of github repository, Anyway, I’ll show it again with another sample.
                Before
                Add transform into your target View. (Or you can apply it globally by defaultSet
                transform: (event) => {
                  event.title = event.title.replace(/FC/g, "⚽")
                  event.title = event.title.replace(" - ", " VS. ")
                  event.title = event.title.replace("(T.B.A.)", "")
                  event.title = event.title.replace("Bayern München", `< img src='https://logodix.com/logo/337534.jpg' height='20px' width='100px' >`)
                  return event
                Then It will show like this;
                After
                • H Offline
                  Hram2008 @Guest
                  @Sean
                  Thank you for taking the time to respond, not quite what i was looking to do but it did point me in the right direction.
                  • C Offline
                    CharlesDS
                    Are they known issues on raspberry pi 2? I’m working on configs without success. Black screen, nothing, but other modules, appears.
                    • ? Offline
                      A Former User @CharlesDS
                      @CharlesDS
                      Without log I cannot tell anything. More detailed info be needed. And Of course, on RPI2, it works.
                      • Z Offline
                        Zinkeler
                        Hello,
                        everything works fine in landscape-mode. If i change to portrait-mode (display_rotate=1
                        avoid_warnings=1 in /boot/config.txt) my calender is not shown. All other modules are on my mirror.
                        Can someone give me a hint?
                        thx
                        Ralph
                        • ? Offline
                          A Former User @Zinkeler
                          @Zinkeler
                          Nothing suspicious.
                          Which view are you using? show me your config about this module.
                          Z 1 Reply Last reply Reply Quote 0
                          • Z Offline
                            Zinkeler @Guest
                            @Sean
                            { module: ‘MMM-CalendarExt2’,
                            scenes:[
                            views: [“upcoming”,“weeks”],
                            views:[
                            mode: “upcoming”,
                            position: “top_left”,
                            slotTitle: “Demnächst”,
                            maxItems: 4,
                            locale: “de-DE”,
                            calendars: [“Ralph”],
                            mode: “week”,
                            title: “Woche”,
                            type: “row”,
                            position: “bottom_bar”,
                            slotCount: 1,
                            locale: “de-DE”,
                            url: “”,
                            • ? Offline
                              @Zinkeler
                              Well, nothing suspicious in configuration.
                              What log says? open dev-tools on MM screen and see what log says.
                              • Z Offline
                                Zinkeler @Guest
                                @Sean
                                sorry, I’ve never done that. how can i do that?
                                thx
                                • ? Offline
                                  @Zinkeler
                                  Ctrl + Shift + i (Or different per environment) on MM Screen.
                                    Doudy @Guest
                                    @Sean
                                    Hello,
                                    I just went from MMM-Calendarext to MMM-calendarExt2
                                    By following your advice: link text
                                    And I have a few questions:
                                    alt text
                                    • 12/04 Dim. - Pâques
                                      It says ‘Tommorow’
                                      Why ?
                                      How else to translate into (french) ‘Demain’
                                    -16/04 and 17/04
                                    The deadline for the period is indicated: 4/19
                                    How to modify in 19/04
                                    -Is it possible to delete the description of the day: “lundi”, “mardi”
                                    but leave if there is an end date on another day (period)
                                    :winking_face:
                                      JohnBachini @Doudy
                                      @Doudy
                                      Did you manage to work out how to change from MM/DD to DD/MM ? As I have same problem.
                                        Doudy @JohnBachini
                                        I have do this :
                                        			locale:"fr-FR",
                                        			slotTitleFormat: "DD/MM",
                                        			slotSubTitleFormat: "ddd",
                                        			slotAltTitleFormat: "DD/MM",
                                          andyriot
                                          while using the “month” view is it possible to hide the previous/next month day slots?
                                          I would like to only show this month Day 1 - Day 30/1
                                            JohnBachini @Doudy
                                            @Doudy
                                            @Doudy Great, ill give that a go Thanks
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 24
                                            • 25
                                            • 17 / 25
